virtual void | SetSignedDeviations (int) |
virtual int | GetSignedDeviations () |
int | GetNumberOfAttributeArrays () |
| Return the number of columns available for the current value of AttributeMode. More...
const char * | GetAttributeArrayName (int n) |
| Get the name of the n-th array ffor the current value of AttributeMode. More...
int | GetAttributeArrayStatus (const char *arrName) |
| Get the status of the specified array (i.e., whether or not it is a column of interest). More...
vtkInformationIntegerKey * | MULTIPLE_MODELS () |
| A key used to mark the output model data object (output port 0) when it is a multiblock of models (any of which may be multiblock dataset themselves) as opposed to a multiblock dataset containing a single model. More...
virtual int | GetAttributeMode () |
| Set/get the type of field attribute (cell, point, field) More...
virtual void | SetAttributeMode (int) |
void | EnableAttributeArray (const char *arrName) |
| An alternate interface for preparing a selection of arrays in ParaView. More...
void | ClearAttributeArrays () |
virtual void | SetTrainingFraction (double) |
| Set/get the amount of data to be used for training. More...
virtual double | GetTrainingFraction () |
virtual void | SetController (vtkMultiProcessController *) |
| Get/Set the multiprocess controller. More...
virtual vtkMultiProcessController * | GetController () |
virtual void | SetTask (int) |
| Set/get whether this filter should create a model of the input or assess the input or both. More...
virtual int | GetTask () |
vtkTableAlgorithm * | NewInstance () const |
vtkTable * | GetOutput () |
vtkTable * | GetOutput (int index) |
void | SetInputData (vtkDataObject *obj) |
void | SetInputData (int index, vtkDataObject *obj) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkPSciVizDescriptiveStats () |
| ~vtkPSciVizDescriptiveStats () override |
int | LearnAndDerive (vtkMultiBlockDataSet *model, vtkTable *inData) override |
| Method subclasses must override to calculate a full model from the given input data. More...
int | AssessData (vtkTable *observations, vtkDataObject *dataset, vtkMultiBlockDataSet *model) override |
| Method subclasses must override to assess an input table given a model of the proper type. More...
| vtkSciVizStatistics () |
| ~vtkSciVizStatistics () override |
int | FillInputPortInformation (int port, vtkInformation *info) override |
int | FillOutputPortInformation (int port, vtkInformation *info) override |
int | ProcessRequest (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override |
virtual int | RequestDataObject (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) |
int | RequestData (vtkInformation *request, vtkInformationVector **input, vtkInformationVector *output) override |
virtual int | RequestData (vtkCompositeDataSet *compDataOu, vtkCompositeDataSet *compModelOu, vtkCompositeDataSet *compDataIn, vtkCompositeDataSet *compModelIn, vtkDataObject *singleModel) |
virtual int | RequestData (vtkDataObject *observationsOut, vtkDataObject *modelOut, vtkDataObject *observationsIn, vtkDataObject *modelIn) |
virtual int | PrepareFullDataTable (vtkTable *table, vtkFieldData *dataAttrIn) |
virtual int | PrepareTrainingTable (vtkTable *trainingTable, vtkTable *fullDataTable, vtkIdType numObservations) |
virtual vtkIdType | GetNumberOfObservationsForTraining (vtkIdType N) |
| Subclasses may (but need not) override this function to guarantee that some minimum number of observations are included in the training data. More...
void | ShallowCopy (vtkDataObject *out, vtkDataObject *in) |
| A variant of shallow copy that calls vtkDataObject::ShallowCopy() and then for composite datasets, creates clones for each leaf node that then shallow copies the fields and geometry. More...
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkTableAlgorithm () |
| ~vtkTableAlgorithm () |
virtual int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
virtual int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
virtual vtkExecutive * | CreateDefaultExecutive () |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
Provide access to VTK descriptive statistics.
This filter provides access to the features of vtkDescriptiveStatistics. See VTK documentation for details
- Thanks to David Thompson and Philippe Pebay from Sandia National Laboratories for implementing this class.
Definition at line 22 of file vtkPSciVizDescriptiveStats.h.
