vtkPVCenterAxesActor Class Reference
vtkPVCenterAxesActor is an actor for the center-axes used in ParaView. More...
#include <vtkPVCenterAxesActor.h>
Inheritance diagram for vtkPVCenterAxesActor:
Collaboration diagram for vtkPVCenterAxesActor:
typedef vtkOpenGLActor Superclass
- Public Types inherited from vtkOpenGLActor
typedef vtkActor Superclass
- Public Types inherited from vtkActor
typedef vtkProp3D Superclass
- Public Types inherited from vtkProp3D
typedef vtkProp Superclass
void SetSymmetric (int)
 If Symmetric is on, the the axis continue to negative values. More...
void SetComputeNormals (int)
 Option for computing normals. More...
- Public Member Functions inherited from vtkOpenGLActor
vtkOpenGLActorNewInstance () const
void Render (vtkRenderer *ren, vtkMapper *mapper)
void GetKeyMatrices (vtkMatrix4x4 *&WCVCMatrix, vtkMatrix3x3 *&normalMatrix)
- Public Member Functions inherited from vtkActor
vtkActorNewInstance () const
virtual void GetActors (vtkPropCollection *)
virtual int HasTranslucentPolygonalGeometry ()
void ShallowCopy (vtkProp *prop)
void ReleaseGraphicsResources (vtkWindow *)
virtual vtkPropertyMakeProperty ()
virtual void SetMapper (vtkMapper *)
virtual void ApplyProperties ()
vtkMTimeType GetMTime ()
virtual vtkMTimeType GetRedrawMTime ()
virtual bool GetSupportsSelection ()
virtual int RenderOpaqueGeometry (vtkViewport *viewport)
virtual int RenderTranslucentPolygonalGeometry (vtkViewport *viewport)
void SetProperty (vtkProperty *lut)
vtkPropertyGetProperty ()
void SetBackfaceProperty (vtkProperty *lut)
virtual vtkPropertyGetBackfaceProperty ()
virtual void SetTexture (vtkTexture *)
virtual vtkTextureGetTexture ()
virtual vtkMapperGetMapper ()
void GetBounds (double bounds[6])
doubleGetBounds ()
virtual bool GetForceOpaque ()
virtual void SetForceOpaque (bool)
virtual void ForceOpaqueOn ()
virtual void ForceOpaqueOff ()
virtual bool GetForceTranslucent ()
virtual void SetForceTranslucent (bool)
virtual void ForceTranslucentOn ()
virtual void ForceTranslucentOff ()
doubleGetBounds ()
- Public Member Functions inherited from vtkProp3D
vtkProp3DNewInstance () const
virtual void SetPosition (double pos[3])
virtual doubleGetPosition ()
virtual void GetPosition (double data[3])
void AddPosition (double deltaPosition[3])
void AddPosition (double deltaX, double deltaY, double deltaZ)
doubleGetCenter ()
doubleGetXRange ()
doubleGetYRange ()
doubleGetZRange ()
double GetLength ()
void RotateX (double)
void RotateY (double)
void RotateZ (double)
void RotateWXYZ (double w, double x, double y, double z)
void SetOrientation (double x, double y, double z)
void SetOrientation (double orientation[3])
doubleGetOrientationWXYZ ()
void AddOrientation (double x, double y, double z)
void AddOrientation (double orentation[3])
void PokeMatrix (vtkMatrix4x4 *matrix)
void InitPathTraversal ()
vtkMTimeType GetUserTransformMatrixMTime ()
virtual void ComputeMatrix ()
virtual void SetPosition (double x, double y, double z)
virtual void SetOrigin (double x, double y, double z)
virtual void SetOrigin (const double pos[3])
virtual doubleGetOrigin ()
virtual void GetOrigin (double data[3])
virtual void SetScale (double x, double y, double z)
virtual void SetScale (double scale[3])
virtual doubleGetScale ()
virtual void GetScale (double data[3])
void SetScale (double s)
void SetUserTransform (vtkLinearTransform *transform)
virtual vtkLinearTransformGetUserTransform ()
void SetUserMatrix (vtkMatrix4x4 *matrix)
vtkMatrix4x4GetUserMatrix ()
virtual void GetMatrix (vtkMatrix4x4 *m)
virtual void GetMatrix (double m[16])
doubleGetOrientation ()
void GetOrientation (double orentation[3])
vtkMatrix4x4GetMatrix ()
virtual int GetIsIdentity ()
vtkPropNewInstance () const
virtual void Pick ()
virtual bool HasKeys (vtkInformation *requiredKeys)
virtual void BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path)
virtual void GetActors2D (vtkPropCollection *)
virtual void GetVolumes (vtkPropCollection *)
virtual void SetVisibility (int)
virtual int GetVisibility ()
virtual void VisibilityOn ()
virtual void VisibilityOff ()
virtual void SetPickable (int)
virtual int GetPickable ()
virtual void PickableOn ()
virtual void PickableOff ()
virtual void SetDragable (int)
virtual int GetDragable ()
virtual void DragableOn ()
virtual void DragableOff ()
virtual void SetUseBounds (bool)
virtual bool GetUseBounds ()
virtual void UseBoundsOn ()
virtual void UseBoundsOff ()
virtual vtkAssemblyPathGetNextPath ()
virtual int GetNumberOfPaths ()
virtual void PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix))
virtual vtkInformationGetPropertyKeys ()
virtual void SetPropertyKeys (vtkInformation *keys)
virtual int RenderVolumetricGeometry (vtkViewport *)
virtual int RenderOverlay (vtkViewport *)
virtual bool RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys)
virtual double GetEstimatedRenderTime (vtkViewport *)
virtual double GetEstimatedRenderTime ()
virtual void SetEstimatedRenderTime (double t)
virtual void RestoreEstimatedRenderTime ()
virtual void AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp))
virtual void SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v))
virtual double GetAllocatedRenderTime ()
void SetRenderTimeMultiplier (double t)
virtual double GetRenderTimeMultiplier ()
virtual int GetNumberOfConsumers ()
void AddConsumer (vtkObject *c)
void RemoveConsumer (vtkObject *c)
vtkObjectGetConsumer (int i)
int IsConsumer (vtkObject *c)
static vtkPVCenterAxesActorNew ()
static vtkPVCenterAxesActorSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkOpenGLActor
static vtkOpenGLActorNew ()
static vtkOpenGLActorSafeDownCast (vtkObjectBase *o)
static vtkInformationIntegerKeyGLDepthMaskOverride ()
- Static Public Member Functions inherited from vtkActor
static vtkActorSafeDownCast (vtkObjectBase *o)
static vtkActorNew ()
- Static Public Member Functions inherited from vtkProp3D
static vtkProp3DSafeDownCast (vtkObjectBase *o)
static vtkPropSafeDownCast (vtkObjectBase *o)
static vtkInformationIntegerKeyGeneralTextureUnit ()
static vtkInformationDoubleVectorKeyGeneralTextureTransform ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVCenterAxesActor ()
 ~vtkPVCenterAxesActor () override
- Protected Member Functions inherited from vtkOpenGLActor
 vtkOpenGLActor ()
 ~vtkOpenGLActor ()
 vtkOpenGLActor ()
 ~vtkOpenGLActor ()
- Protected Member Functions inherited from vtkActor
 vtkActor ()
 ~vtkActor ()
int GetIsOpaque ()
- Protected Member Functions inherited from vtkProp3D
 vtkProp3D ()
 ~vtkProp3D ()
 vtkProp ()
 ~vtkProp ()
vtkAxesAxes
vtkPolyDataMapperMapper
- Protected Attributes inherited from vtkOpenGLActor
vtkMatrix4x4MCWCMatrix
vtkMatrix3x3NormalMatrix
vtkTransformNormalTransform
vtkTimeStamp KeyMatrixTime
- Protected Attributes inherited from vtkActor
bool ForceOpaque
bool ForceTranslucent
vtkPropertyProperty
vtkPropertyBackfaceProperty
vtkTextureTexture
vtkMapperMapper
double MapperBounds [6]
vtkTimeStamp BoundsMTime
- Protected Attributes inherited from vtkProp3D
vtkLinearTransformUserTransform
vtkMatrix4x4UserMatrix
vtkMatrix4x4Matrix
vtkTimeStamp MatrixMTime
double Origin [3]
double Position [3]
double Orientation [3]
double Scale [3]
double Center [3]
vtkTransformTransform
double Bounds [6]
vtkProp3DCachedProp3D
int IsIdentity
int Visibility
int Pickable
int Dragable
bool UseBounds
double AllocatedRenderTime
double EstimatedRenderTime
double SavedEstimatedRenderTime
double RenderTimeMultiplier
int NumberOfConsumers
vtkObject ** Consumers
vtkAssemblyPathsPaths
vtkInformationPropertyKeys
It merely uses vtkAxes as the poly data source.
Definition at line 19 of file vtkPVCenterAxesActor.h.
Definition at line 23 of file vtkPVCenterAxesActor.h.
◆ vtkPVCenterAxesActor()
vtkPVCenterAxesActor::vtkPVCenterAxesActor ( )
◆ ~vtkPVCenterAxesActor()
vtkPVCenterAxesActor::~vtkPVCenterAxesActor ( )
static vtkPVCenterAxesActor* vtkPVCenterAxesActor::New ( )
virtual const char* vtkPVCenterAxesActor::GetClassName ( )
static int vtkPVCenterAxesActor::IsTypeOf ( const char *  type)
virtual int vtkPVCenterAxesActor::IsA ( const char *  type)
Reimplemented from vtkOpenGLActor.
static vtkPVCenterAxesActor* vtkPVCenterAxesActor::SafeDownCast ( vtkObject o)
void vtkPVCenterAxesActor::PrintSelf ( ostream &  os,
◆ SetSymmetric()
void vtkPVCenterAxesActor::SetSymmetric ( int  )
◆ SetComputeNormals()
void vtkPVCenterAxesActor::SetComputeNormals ( int  )
By default they are computed.
◆ Axes
vtkAxes* vtkPVCenterAxesActor::Axes
Definition at line 40 of file vtkPVCenterAxesActor.h.
◆ Mapper
vtkPolyDataMapper* vtkPVCenterAxesActor::Mapper
Definition at line 41 of file vtkPVCenterAxesActor.h.
