abstract proxy for manipulators used in animation. More...
#include <vtkPVCueManipulator.h>
| enum | { StateModifiedEvent = 2000 } |
| StateModifiedEvent - This event is fired when the manipulator modifies the animated proxy. More... | |
| static vtkPVCueManipulator * | SafeDownCast (vtkObject *o) |
| virtual void | Initialize (vtkPVAnimationCue *) |
| This method is called when the AnimationCue's StartAnimationCueEvent is triggered, to let the animation manipulator know that the cue has been restarted. More... | |
| virtual void | Finalize (vtkPVAnimationCue *) |
| This method is called when the AnimationCue's EndAnimationCueEvent is triggered. More... | |
| virtual void | UpdateValue (double currenttime, vtkPVAnimationCue *cueproxy)=0 |
| This updates the values based on currenttime. More... | |
| vtkPVCueManipulator () | |
| ~vtkPVCueManipulator () override | |
Friends | |
| class | vtkPVAnimationCue |
An animation cue proxy delegates the operation of modifying the property on the proxy being animated to a Manipulator. An example of a manipulator is a vtkPVKeyFrameCueManipulator. Subclasses must override UpdateValue to perform the actual property manipulation. Just like all proxies involved in Animation, this is a client side proxy, with no VTK objects created on the server. A manipulator fires two kinds of events:
Definition at line 33 of file vtkPVCueManipulator.h.
Definition at line 36 of file vtkPVCueManipulator.h.
| anonymous enum |
vtkCommand::Modified - is fired when the keyframes are changed i.e. added/removed/modified.
| Enumerator | |
| StateModifiedEvent | |
Definition at line 43 of file vtkPVCueManipulator.h.
Reimplemented in vtkPVKeyFrameCueManipulator, and vtkPVCameraCueManipulator.
Reimplemented in vtkPVKeyFrameCueManipulator.
inlineprotectedvirtual |
This is here for one major reason: after the last key frame, the state of the scene must be as it was left a the the last key frame. This does not happened automatically, since if while animating the currentime never coincides with the last key frame's key time, then it never gets a chance to update the properties value. Hence, we note when the cue begins. Then, if the currentime is beyond that of the last key frame we pretend that the current time coincides with that of the last key frame and let it update the properties. This is done only once per Animation cycle. The Initialize method is used to indicate that a new animation cycle has begun.
Definition at line 61 of file vtkPVCueManipulator.h.
Typically, the Manipulator will set the state of the Cue to that at the end of the cue.
Definition at line 68 of file vtkPVCueManipulator.h.
protectedpure virtual |
currenttime is normalized to the time range of the Cue.
Implemented in vtkPVKeyFrameCueManipulator, and vtkPVCameraCueManipulator.
friend |
Definition at line 78 of file vtkPVCueManipulator.h.
1.8.13 on Sun Dec 14 2025
