vtkPVEnSightMasterServerReader Class Reference
#include <vtkPVEnSightMasterServerReader.h>
Inheritance diagram for vtkPVEnSightMasterServerReader:
Collaboration diagram for vtkPVEnSightMasterServerReader:
typedef vtkGenericEnSightReader Superclass
- Public Types inherited from vtkGenericEnSightReader
enum  FileTypes
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
int CanReadFile (const char *) override
 Return whether we can read the file given. More...
virtual vtkMultiProcessControllerGetController ()
 This class uses MPI communication mechanisms to verify the integrity of all case files in the master file. More...
virtual void SetController (vtkMultiProcessController *controller)
virtual int GetNumberOfPieces ()
 Get the number of pieces in the file. More...
- Public Member Functions inherited from vtkGenericEnSightReader
vtkGenericEnSightReaderNewInstance () const
const char * GetDescription (int n)
const char * GetComplexDescription (int n)
const char * GetDescription (int n, int type)
int DetermineEnSightVersion (int quiet=0)
vtkGenericEnSightReaderGetReader ()
void SetCaseFileName (const char *fileName)
virtual char * GetCaseFileName ()
virtual void SetFilePath (const char *)
virtual char * GetFilePath ()
virtual int GetEnSightVersion ()
virtual int GetNumberOfVariables ()
virtual int GetNumberOfComplexVariables ()
int GetNumberOfVariables (int type)
virtual int GetNumberOfScalarsPerNode ()
virtual int GetNumberOfVectorsPerNode ()
virtual int GetNumberOfTensorsSymmPerNode ()
virtual int GetNumberOfScalarsPerElement ()
virtual int GetNumberOfVectorsPerElement ()
virtual int GetNumberOfTensorsSymmPerElement ()
virtual int GetNumberOfScalarsPerMeasuredNode ()
virtual int GetNumberOfVectorsPerMeasuredNode ()
virtual int GetNumberOfComplexScalarsPerNode ()
virtual int GetNumberOfComplexVectorsPerNode ()
virtual int GetNumberOfComplexScalarsPerElement ()
virtual int GetNumberOfComplexVectorsPerElement ()
int GetVariableType (int n)
int GetComplexVariableType (int n)
virtual void SetTimeValue (float value)
virtual float GetTimeValue ()
virtual float GetMinimumTimeValue ()
virtual float GetMaximumTimeValue ()
virtual vtkDataArrayCollectionGetTimeSets ()
virtual void ReadAllVariablesOn ()
virtual void ReadAllVariablesOff ()
virtual void SetReadAllVariables (int)
virtual int GetReadAllVariables ()
virtual vtkDataArraySelectionGetPointDataArraySelection ()
virtual vtkDataArraySelectionGetCellDataArraySelection ()
int GetNumberOfPointArrays ()
int GetNumberOfCellArrays ()
const char * GetPointArrayName (int index)
const char * GetCellArrayName (int index)
int GetPointArrayStatus (const char *name)
int GetCellArrayStatus (const char *name)
void SetPointArrayStatus (const char *name, int status)
void SetCellArrayStatus (const char *name, int status)
void SetByteOrderToBigEndian ()
void SetByteOrderToLittleEndian ()
virtual void SetByteOrder (int)
virtual int GetByteOrder ()
const char * GetByteOrderAsString ()
virtual char * GetGeometryFileName ()
virtual void SetParticleCoordinatesByIndex (int)
virtual int GetParticleCoordinatesByIndex ()
virtual void ParticleCoordinatesByIndexOn ()
virtual void ParticleCoordinatesByIndexOff ()
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithmNewInstance () const
vtkMultiBlockDataSetGetOutput ()
vtkMultiBlockDataSetGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVEnSightMasterServerReaderNew ()
static vtkPVEnSightMasterServerReaderSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkGenericEnSightReader
static vtkGenericEnSightReaderNew ()
static vtkGenericEnSightReaderSafeDownCast (vtkObjectBase *o)
static int CanReadFile (const char *casefilename)
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithmNew ()
static vtkMultiBlockDataSetAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVEnSightMasterServerReader ()
 ~vtkPVEnSightMasterServerReader () override
int RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
int ParseMasterServerFile ()
void SuperclassExecuteInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
void SuperclassExecuteData (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
- Protected Member Functions inherited from vtkGenericEnSightReader
 vtkGenericEnSightReader ()
 ~vtkGenericEnSightReader ()
virtual void ClearForNewCaseFileName ()
int ReadLine (char result[256])
int ReadBinaryLine (char result[80])
int ReadNextDataLine (char result[256])
void SelectionModified ()
char ** CreateStringArray (int numStrings)
void DestroyStringArray (int numStrings, char **strings)
void SetDataArraySelectionSetsFromVariables ()
void SetDataArraySelectionSetsFromReader ()
void SetReaderDataArraySelectionSetsFromSelf ()
virtual void SetTimeSets (vtkDataArrayCollection *)
int InsertNewPartId (int partId)
virtual void SetGeometryFileName (const char *)
void AddVariableDescription (const char *description)
void AddComplexVariableDescription (const char *description)
void AddVariableType (int variableType)
void AddComplexVariableType (int variableType)
int ReplaceWildcards (char *fileName, int timeSet, int fileSet)
void ReplaceWildcardsHelper (char *fileName, int num)
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkDataObjectGetInput (int port)
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkMultiProcessControllerController
int NumberOfPieces
vtkPVEnSightMasterServerReaderInternal * Internal
vtkPVEnSightMasterServerTranslatorExtentTranslator
int InformationError
- Protected Attributes inherited from vtkGenericEnSightReader
istream * IS
FILE * IFile
vtkGenericEnSightReaderReader
char * CaseFileName
char * GeometryFileName
char * FilePath
intVariableTypes
intComplexVariableTypes
char ** VariableDescriptions
char ** ComplexVariableDescriptions
int NumberOfVariables
int NumberOfComplexVariables
int NumberOfScalarsPerNode
int NumberOfVectorsPerNode
int NumberOfTensorsSymmPerNode
int NumberOfScalarsPerElement
int NumberOfVectorsPerElement
int NumberOfTensorsSymmPerElement
int NumberOfScalarsPerMeasuredNode
int NumberOfVectorsPerMeasuredNode
int NumberOfComplexScalarsPerNode
int NumberOfComplexVectorsPerNode
int NumberOfComplexScalarsPerElement
int NumberOfComplexVectorsPerElement
float TimeValue
float MinimumTimeValue
float MaximumTimeValue
int TimeValueInitialized
vtkDataArrayCollectionTimeSets
int ReadAllVariables
int ByteOrder
int ParticleCoordinatesByIndex
int EnSightVersion
vtkDataArraySelectionPointDataArraySelection
vtkDataArraySelectionCellDataArraySelection
vtkCallbackCommandSelectionObserver
int SelectionModifiedDoNotCallModified
TranslationTableType * TranslationTable
double Progress
char * ProgressText
unsigned long ErrorCode
- Public Attributes inherited from vtkGenericEnSightReader
 ENSIGHT_6
 ENSIGHT_6_BINARY
 ENSIGHT_GOLD
 ENSIGHT_GOLD_BINARY
 ENSIGHT_MASTER_SERVER
 FILE_BIG_ENDIAN
 FILE_LITTLE_ENDIAN
 FILE_UNKNOWN_ENDIAN
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Static Protected Member Functions inherited from vtkGenericEnSightReader
static void SelectionModifiedCallback (vtkObject *caller, unsigned long eid, void *clientdata, void *calldata)
Definition at line 18 of file vtkPVEnSightMasterServerReader.h.
Definition at line 23 of file vtkPVEnSightMasterServerReader.h.
◆ vtkPVEnSightMasterServerReader()
vtkPVEnSightMasterServerReader::vtkPVEnSightMasterServerReader ( )
◆ ~vtkPVEnSightMasterServerReader()
vtkPVEnSightMasterServerReader::~vtkPVEnSightMasterServerReader ( )
static vtkPVEnSightMasterServerReader* vtkPVEnSightMasterServerReader::New ( )
virtual const char* vtkPVEnSightMasterServerReader::GetClassName ( )
static int vtkPVEnSightMasterServerReader::IsTypeOf ( const char *  type)
virtual int vtkPVEnSightMasterServerReader::IsA ( const char *  type)
Reimplemented from vtkGenericEnSightReader.
static vtkPVEnSightMasterServerReader* vtkPVEnSightMasterServerReader::SafeDownCast ( vtkObject o)
void vtkPVEnSightMasterServerReader::PrintSelf ( ostream &  os,
◆ GetController()
virtual vtkMultiProcessController* vtkPVEnSightMasterServerReader::GetController ( )
The get method interface must use vtkMultiProcessController instead of vtkMPIController because Tcl wrapping requires the class's wrapper to be defined, but it is not defined if MPI is not on. In client-server mode, we may still need to create an instance of this class on the client process even if MPI is not compiled in.
◆ SetController()
virtual void vtkPVEnSightMasterServerReader::SetController ( vtkMultiProcessController controller)
◆ CanReadFile()
int vtkPVEnSightMasterServerReader::CanReadFile ( const char *  )
override
◆ GetNumberOfPieces()
virtual int vtkPVEnSightMasterServerReader::GetNumberOfPieces ( )
Valid after UpdateInformation.
◆ RequestInformation()
int vtkPVEnSightMasterServerReader::RequestInformation ( vtkInformation ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ RequestData()
int vtkPVEnSightMasterServerReader::RequestData ( vtkInformation ,
◆ ParseMasterServerFile()
int vtkPVEnSightMasterServerReader::ParseMasterServerFile ( )
◆ SuperclassExecuteInformation()
void vtkPVEnSightMasterServerReader::SuperclassExecuteInformation ( vtkInformation ,
◆ SuperclassExecuteData()
void vtkPVEnSightMasterServerReader::SuperclassExecuteData ( vtkInformation ,
◆ Controller
vtkMultiProcessController* vtkPVEnSightMasterServerReader::Controller
Definition at line 66 of file vtkPVEnSightMasterServerReader.h.
◆ NumberOfPieces
int vtkPVEnSightMasterServerReader::NumberOfPieces
Definition at line 69 of file vtkPVEnSightMasterServerReader.h.
◆ Internal
vtkPVEnSightMasterServerReaderInternal* vtkPVEnSightMasterServerReader::Internal
Definition at line 72 of file vtkPVEnSightMasterServerReader.h.
◆ ExtentTranslator
vtkPVEnSightMasterServerTranslator* vtkPVEnSightMasterServerReader::ExtentTranslator
Definition at line 76 of file vtkPVEnSightMasterServerReader.h.
◆ InformationError
int vtkPVEnSightMasterServerReader::InformationError
Definition at line 79 of file vtkPVEnSightMasterServerReader.h.
