int | CanReadFile (const char *) override |
| Return whether we can read the file given. More...
void | SetCaseFileName (const char *fileName) |
| Set the name of the file to be read. More...
virtual vtkMultiProcessController * | GetController () |
| This class uses MPI communication mechanisms to verify the integrity of all case files in the master file. More...
virtual void | SetController (vtkMultiProcessController *controller) |
virtual int | GetNumberOfPieces () |
| Get the number of pieces in the file. More...
int | GetNumberOfPointArrays () |
| Get the number of point or cell arrays available in the input. More...
int | GetNumberOfCellArrays () |
const char * | GetPointArrayName (int index) |
| Get the name of the point or cell array with the given index in the input. More...
const char * | GetCellArrayName (int index) |
int | GetPointArrayStatus (const char *name) |
| Get/Set whether the point or cell array with the given name is to be read. More...
int | GetCellArrayStatus (const char *name) |
void | SetPointArrayStatus (const char *name, int status) |
void | SetCellArrayStatus (const char *name, int status) |
void | SetByteOrderToBigEndian () |
| Set the byte order of the file (remember, more Unix workstations write big endian whereas PCs write little endian). More...
void | SetByteOrderToLittleEndian () |
void | SetByteOrder (int byteOrder) override |
int | GetByteOrder () override |
const char * | GetByteOrderAsString () |
vtkGenericEnSightReader * | NewInstance () const |
const char * | GetDescription (int n) |
const char * | GetComplexDescription (int n) |
const char * | GetDescription (int n, int type) |
int | DetermineEnSightVersion (int quiet=0) |
vtkGenericEnSightReader * | GetReader () |
virtual char * | GetCaseFileName () |
virtual void | SetFilePath (const char *) |
virtual char * | GetFilePath () |
virtual int | GetEnSightVersion () |
virtual int | GetNumberOfVariables () |
virtual int | GetNumberOfComplexVariables () |
int | GetNumberOfVariables (int type) |
virtual int | GetNumberOfScalarsPerNode () |
virtual int | GetNumberOfVectorsPerNode () |
virtual int | GetNumberOfTensorsSymmPerNode () |
virtual int | GetNumberOfScalarsPerElement () |
virtual int | GetNumberOfVectorsPerElement () |
virtual int | GetNumberOfTensorsSymmPerElement () |
virtual int | GetNumberOfScalarsPerMeasuredNode () |
virtual int | GetNumberOfVectorsPerMeasuredNode () |
virtual int | GetNumberOfComplexScalarsPerNode () |
virtual int | GetNumberOfComplexVectorsPerNode () |
virtual int | GetNumberOfComplexScalarsPerElement () |
virtual int | GetNumberOfComplexVectorsPerElement () |
int | GetVariableType (int n) |
int | GetComplexVariableType (int n) |
virtual void | SetTimeValue (float value) |
virtual float | GetTimeValue () |
virtual float | GetMinimumTimeValue () |
virtual float | GetMaximumTimeValue () |
virtual vtkDataArrayCollection * | GetTimeSets () |
virtual void | ReadAllVariablesOn () |
virtual void | ReadAllVariablesOff () |
virtual void | SetReadAllVariables (int) |
virtual int | GetReadAllVariables () |
virtual vtkDataArraySelection * | GetPointDataArraySelection () |
virtual vtkDataArraySelection * | GetCellDataArraySelection () |
virtual char * | GetGeometryFileName () |
virtual void | SetParticleCoordinatesByIndex (int) |
virtual int | GetParticleCoordinatesByIndex () |
virtual void | ParticleCoordinatesByIndexOn () |
virtual void | ParticleCoordinatesByIndexOff () |
vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
vtkMultiBlockDataSet * | GetOutput () |
vtkMultiBlockDataSet * | GetOutput (int) |
virtual int | ProcessRequest (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkPVEnSightMasterServerReader2 () |
| ~vtkPVEnSightMasterServerReader2 () override |
int | RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
int | ParseMasterServerFile () |
| vtkPGenericEnSightReader () |
| ~vtkPGenericEnSightReader () override |
int | GetMultiProcessLocalProcessId () |
| Multi Process cache. More...
int | GetMultiProcessNumberOfProcesses () |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkGenericEnSightReader () |
| ~vtkGenericEnSightReader () |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual void | ClearForNewCaseFileName () |
int | ReadLine (char result[256]) |
int | ReadBinaryLine (char result[80]) |
int | ReadNextDataLine (char result[256]) |
void | SelectionModified () |
char ** | CreateStringArray (int numStrings) |
void | DestroyStringArray (int numStrings, char **strings) |
void | SetDataArraySelectionSetsFromVariables () |
void | SetDataArraySelectionSetsFromReader () |
void | SetReaderDataArraySelectionSetsFromSelf () |
virtual void | SetTimeSets (vtkDataArrayCollection *) |
int | InsertNewPartId (int partId) |
virtual void | SetGeometryFileName (const char *) |
void | AddVariableDescription (const char *description) |
void | AddComplexVariableDescription (const char *description) |
void | AddVariableType (int variableType) |
void | AddComplexVariableType (int variableType) |
int | ReplaceWildcards (char *fileName, int timeSet, int fileSet) |
void | ReplaceWildcardsHelper (char *fileName, int num) |
| vtkMultiBlockDataSetAlgorithm () |
| ~vtkMultiBlockDataSetAlgorithm () |
virtual vtkExecutive * | CreateDefaultExecutive () |
virtual int | FillInputPortInformation (int port, vtkInformation *info) |
virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
