vtkPVGenerateProcessIds Class Reference
Generate process IDs of input vtkDataSet or vtkHyperTreeGrid. More...
#include <vtkPVGenerateProcessIds.h>
Inheritance diagram for vtkPVGenerateProcessIds:
Collaboration diagram for vtkPVGenerateProcessIds:
enum  DesiredOutputPrecision
virtual void SetGeneratePointData (bool)
 Set/Get whether to generate process ids for PointData. More...
virtual bool GetGeneratePointData ()
virtual void GeneratePointDataOn ()
virtual void GeneratePointDataOff ()
virtual void SetGenerateCellData (bool)
 Set/Get whether to generate process ids for CellData. More...
virtual bool GetGenerateCellData ()
virtual void GenerateCellDataOn ()
virtual void GenerateCellDataOff ()
vtkPassInputTypeAlgorithmNewInstance () const
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkTableGetTableOutput ()
vtkGraphGetGraphOutput ()
vtkDataObjectGetInput ()
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVGenerateProcessIdsNew ()
static vtkPVGenerateProcessIdsSafeDownCast (vtkObject *o)
static vtkPassInputTypeAlgorithmNew ()
static vtkPassInputTypeAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVGenerateProcessIds ()=default
 ~vtkPVGenerateProcessIds () override=default
int FillInputPortInformation (int, vtkInformation *) override
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
virtual int RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
double Progress
char * ProgressText
unsigned long ErrorCode
This meta-filter add support of vtkHyperTreeGrid by forwarding process IDs generation to the appropriate VTK filter.
See also
vtkGenerateProcessIds vtkHyperTreeGridGenerateProcessIds
Definition at line 19 of file vtkPVGenerateProcessIds.h.
Definition at line 24 of file vtkPVGenerateProcessIds.h.
◆ vtkPVGenerateProcessIds()
vtkPVGenerateProcessIds::vtkPVGenerateProcessIds ( )
protecteddefault
◆ ~vtkPVGenerateProcessIds()
vtkPVGenerateProcessIds::~vtkPVGenerateProcessIds ( )
overrideprotecteddefault
static vtkPVGenerateProcessIds* vtkPVGenerateProcessIds::New ( )
virtual const char* vtkPVGenerateProcessIds::GetClassName ( )
static int vtkPVGenerateProcessIds::IsTypeOf ( const char *  type)
virtual int vtkPVGenerateProcessIds::IsA ( const char *  type)
static vtkPVGenerateProcessIds* vtkPVGenerateProcessIds::SafeDownCast ( vtkObject o)
void vtkPVGenerateProcessIds::PrintSelf ( ostream &  os,
◆ SetGeneratePointData()
virtual void vtkPVGenerateProcessIds::SetGeneratePointData ( bool  )
Default is true.
Note
: Unused if input is a vtkHyperTreeGrid instance. In that case, point data is never generated.
◆ GetGeneratePointData()
virtual bool vtkPVGenerateProcessIds::GetGeneratePointData ( )
Default is true.
Note
◆ GeneratePointDataOn()
virtual void vtkPVGenerateProcessIds::GeneratePointDataOn ( )
Default is true.
Note
◆ GeneratePointDataOff()
virtual void vtkPVGenerateProcessIds::GeneratePointDataOff ( )
Default is true.
Note
◆ SetGenerateCellData()
virtual void vtkPVGenerateProcessIds::SetGenerateCellData ( bool  )
Default is false.
Note
: Unused if input is a vtkHyperTreeGrid instance. In that case, cell data is always generated.
◆ GetGenerateCellData()
virtual bool vtkPVGenerateProcessIds::GetGenerateCellData ( )
Default is false.
Note
◆ GenerateCellDataOn()
virtual void vtkPVGenerateProcessIds::GenerateCellDataOn ( )
Default is false.
Note
◆ GenerateCellDataOff()
virtual void vtkPVGenerateProcessIds::GenerateCellDataOff ( )
Default is false.
Note
◆ RequestData()
int vtkPVGenerateProcessIds::RequestData ( vtkInformation ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ FillInputPortInformation()
int vtkPVGenerateProcessIds::FillInputPortInformation ( int  ,
vtkInformation
