vtkPVGridAxes3DRepresentation Class Reference
Representation for vtkPVGridAxis3DActor. More...
#include <vtkPVGridAxes3DRepresentation.h>
Inheritance diagram for vtkPVGridAxes3DRepresentation:
Collaboration diagram for vtkPVGridAxes3DRepresentation:
enum  DesiredOutputPrecision
void SetGridAxes (vtkPVGridAxes3DActor *gridAxes)
virtual vtkPVGridAxes3DActorGetGridAxes ()
void SetVisibility (bool) override
void SetGridAxesVisibility (bool)
void SetPosition (double pos[3])
void SetPosition (double x, double y, double z)
void SetScale (double scale[3])
void SetScale (double x, double y, double z)
virtual void MarkModified ()
virtual bool GetVisibility ()
virtual vtkDataObjectGetRenderedDataObject (int vtkNotUsed(port))
double GetCacheKey () const
vtkAlgorithmOutputGetInternalOutputPort () override
vtkAlgorithmOutputGetInternalOutputPort (int port) override
vtkAlgorithmOutputGetInternalOutputPort (int port, int conn) override
vtkViewGetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
const std::stringGetLogName () const
vtkDataRepresentationNewInstance () const
virtual vtkSelectionConvertSelection (vtkView *view, vtkSelection *selection)
vtkAlgorithmOutputGetInputConnection (int port=0, int index=0)
vtkAnnotationLinkGetAnnotationLink ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort ()
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalAnnotationOutputPort (int port, int conn)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort ()
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port)
virtual vtkAlgorithmOutputGetInternalSelectionOutputPort (int port, int conn)
virtual vtkStringArrayGetSelectionArrayNames ()
vtkPassInputTypeAlgorithmNewInstance () const
vtkPolyDataGetPolyDataOutput ()
vtkStructuredPointsGetStructuredPointsOutput ()
vtkImageDataGetImageDataOutput ()
vtkStructuredGridGetStructuredGridOutput ()
vtkUnstructuredGridGetUnstructuredGridOutput ()
vtkRectilinearGridGetRectilinearGridOutput ()
vtkTableGetTableOutput ()
vtkGraphGetGraphOutput ()
vtkDataObjectGetInput ()
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVGridAxes3DRepresentationNew ()
static vtkPVGridAxes3DRepresentationSafeDownCast (vtkObject *o)
static vtkPVDataRepresentationSafeDownCast (vtkObject *o)
static vtkDataRepresentationNew ()
static vtkDataRepresentationSafeDownCast (vtkObjectBase *o)
static vtkPassInputTypeAlgorithmNew ()
static vtkPassInputTypeAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVGridAxes3DRepresentation ()
 ~vtkPVGridAxes3DRepresentation () override
int RequestData (vtkInformation *req, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) override
void UpdateVisibility ()
 vtkPVDataRepresentation ()
vtkExecutiveCreateDefaultExecutive () override
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
virtual vtkAnnotationLayersConvertAnnotations (vtkView *view, vtkAnnotationLayers *annotations)
vtkTrivialProducerGetInternalInput (int port, int conn)
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
vtkDataObjectGetInput (int port)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
bool GridAxesVisibility
double Position [3]
double Scale [3]
vtkNew< vtkPolyDataDummyPolyData
vtkPVGridAxes3DActorGridAxes
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
vtkStringArraySelectionArrayNames
CommandObserver
vtkAnnotationLinkAnnotationLinkInternal
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Definition at line 20 of file vtkPVGridAxes3DRepresentation.h.
Definition at line 24 of file vtkPVGridAxes3DRepresentation.h.
◆ vtkPVGridAxes3DRepresentation()
vtkPVGridAxes3DRepresentation::vtkPVGridAxes3DRepresentation ( )
◆ ~vtkPVGridAxes3DRepresentation()
vtkPVGridAxes3DRepresentation::~vtkPVGridAxes3DRepresentation ( )
static vtkPVGridAxes3DRepresentation* vtkPVGridAxes3DRepresentation::New ( )
virtual const char* vtkPVGridAxes3DRepresentation::GetClassName ( )
static int vtkPVGridAxes3DRepresentation::IsTypeOf ( const char *  type)
virtual int vtkPVGridAxes3DRepresentation::IsA ( const char *  type)
static vtkPVGridAxes3DRepresentation* vtkPVGridAxes3DRepresentation::SafeDownCast ( vtkObject o)
void vtkPVGridAxes3DRepresentation::PrintSelf ( ostream &  os,
◆ SetGridAxes()
void vtkPVGridAxes3DRepresentation::SetGridAxes ( vtkPVGridAxes3DActor gridAxes)
◆ GetGridAxes()
virtual vtkPVGridAxes3DActor* vtkPVGridAxes3DRepresentation::GetGridAxes ( )
◆ SetVisibility()
void vtkPVGridAxes3DRepresentation::SetVisibility ( bool  val)
When the visibility of representation of false, all view passes are ignored.
◆ SetGridAxesVisibility()
void vtkPVGridAxes3DRepresentation::SetGridAxesVisibility ( bool  )
◆ SetPosition() [1/2]
void vtkPVGridAxes3DRepresentation::SetPosition ( double  pos[3])
◆ SetPosition() [2/2]
void vtkPVGridAxes3DRepresentation::SetPosition ( double  x,
double  y,
double  z
◆ SetScale() [1/2]
void vtkPVGridAxes3DRepresentation::SetScale ( double  scale[3])
◆ SetScale() [2/2]
void vtkPVGridAxes3DRepresentation::SetScale ( double  x,
double  y,
double  z
◆ ProcessViewRequest()
int vtkPVGridAxes3DRepresentation::ProcessViewRequest ( vtkInformationRequestKey request_type,
vtkInformation inInfo,
vtkInformation outInfo
Note
Starting with ParaView 5.8, this method is no longer called for hidden representation i.e. representations for which vtkDataRepresentation::GetVisibility() returns false.
◆ FillInputPortInformation()
int vtkPVGridAxes3DRepresentation::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ RequestData()
int vtkPVGridAxes3DRepresentation::RequestData ( vtkInformation ,
vtkInformationVector **  ,
Overridden to invoke vtkCommand::UpdateDataEvent.
◆ AddToView()
bool vtkPVGridAxes3DRepresentation::AddToView ( vtkView view)
◆ RemoveFromView()
bool vtkPVGridAxes3DRepresentation::RemoveFromView ( vtkView view)
◆ UpdateVisibility()
void vtkPVGridAxes3DRepresentation::UpdateVisibility ( )
◆ GridAxesVisibility
bool vtkPVGridAxes3DRepresentation::GridAxesVisibility
Definition at line 51 of file vtkPVGridAxes3DRepresentation.h.
◆ Position
double vtkPVGridAxes3DRepresentation::Position[3]
Definition at line 54 of file vtkPVGridAxes3DRepresentation.h.
◆ Scale
double vtkPVGridAxes3DRepresentation::Scale[3]
Definition at line 55 of file vtkPVGridAxes3DRepresentation.h.
◆ DummyPolyData
vtkNew<vtkPolyData> vtkPVGridAxes3DRepresentation::DummyPolyData
Definition at line 57 of file vtkPVGridAxes3DRepresentation.h.
◆ GridAxes
vtkPVGridAxes3DActor* vtkPVGridAxes3DRepresentation::GridAxes
Definition at line 58 of file vtkPVGridAxes3DRepresentation.h.
