void | ReadRelativeFile (const char *FileName) |
| Unlike vtkOSPRayMaterial::ReadFile, this searches in a number of relative and environmental paths specified by the SearchPaths member variable. More...
virtual char * | GetSearchPaths () |
| Get a string of standard search paths (path1;path2;path3) search paths are based on PV_PLUGIN_PATH, plugin dir relative to executable. More...
vtkObject * | GetMaterialLibrary () |
| Returns the underlying material library. More...
bool | ReadFile (const char *FileName) |
| Defer to contained MaterialLibrary. More...
const char * | WriteBuffer () |
void | WriteFile (const std::string &filename) |
bool | ReadBuffer (const char *) |
virtual void | Modified () |
manages visual material definitions
vtkPVMaterialLibrary helps ParaView to load visual material definition files from known, generally process relative, locations on the sever.
This class does nothing without raytracing (module VTK_MODULE_ENABLE_VTK_RenderingRayTracing disabled)
Definition at line 22 of file vtkPVMaterialLibrary.h.
