vtkPVPostFilter Class Reference
Post Filter for on demand conversion. More...
#include <vtkPVPostFilter.h>
Inheritance diagram for vtkPVPostFilter:
Collaboration diagram for vtkPVPostFilter:
enum  DesiredOutputPrecision
vtkExecutiveCreateDefaultExecutive () override
 We need to override this method because the composite data pipeline is not what we want. More...
vtkDataObjectAlgorithmNewInstance () const
vtkDataObjectGetInput ()
vtkDataObjectGetInput (int port)
vtkDataObjectGetOutput ()
vtkDataObjectGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVPostFilterNew ()
static vtkPVPostFilterSafeDownCast (vtkObject *o)
static std::string DefaultComponentName (int componentNumber, int componentCount)
static vtkDataObjectAlgorithmNew ()
static vtkDataObjectAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVPostFilter ()
 ~vtkPVPostFilter () override
int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
int DoAnyNeededConversions (vtkDataObject *output)
int DoAnyNeededConversions (vtkDataSet *dataset)
int DoAnyNeededConversions (vtkDataSet *output, const char *requested_name, int fieldAssociation, const char *demangled_name, const char *demagled_component_name)
void CellDataToPointData (vtkDataSet *output, const char *name)
void PointDataToCellData (vtkDataSet *output, const char *name)
int ExtractComponent (vtkDataSetAttributes *dsa, const char *requested_name, const char *demangled_name, const char *demagled_component_name)
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
double Progress
char * ProgressText
unsigned long ErrorCode
vtkPVPostFilter is a filter used for on demand conversion of properties Provide the ability to automatically use a vector component as a scalar input property.
Interpolate cell centered data to point data, and the inverse if needed by the filter.
Definition at line 25 of file vtkPVPostFilter.h.
Definition at line 29 of file vtkPVPostFilter.h.
◆ vtkPVPostFilter()
vtkPVPostFilter::vtkPVPostFilter ( )
◆ ~vtkPVPostFilter()
vtkPVPostFilter::~vtkPVPostFilter ( )
static vtkPVPostFilter* vtkPVPostFilter::New ( )
virtual const char* vtkPVPostFilter::GetClassName ( )
static int vtkPVPostFilter::IsTypeOf ( const char *  type)
virtual int vtkPVPostFilter::IsA ( const char *  type)
static vtkPVPostFilter* vtkPVPostFilter::SafeDownCast ( vtkObject o)
void vtkPVPostFilter::PrintSelf ( ostream &  os,
◆ CreateDefaultExecutive()
vtkExecutive* vtkPVPostFilter::CreateDefaultExecutive ( )
Instead we need the PVCompositeDataPipeline so that we can figure out what we conversion(s) we need to do
◆ DefaultComponentName()
static std::string vtkPVPostFilter::DefaultComponentName ( int  componentNumber,
int  componentCount
◆ FillInputPortInformation()
int vtkPVPostFilter::FillInputPortInformation ( int  port,
vtkInformation info
overrideprotectedvirtual
◆ RequestDataObject()
int vtkPVPostFilter::RequestDataObject ( vtkInformation ,
vtkInformationVector **  ,
◆ RequestData()
int vtkPVPostFilter::RequestData ( vtkInformation ,
◆ DoAnyNeededConversions() [1/3]
int vtkPVPostFilter::DoAnyNeededConversions ( vtkDataObject output)
◆ DoAnyNeededConversions() [2/3]
int vtkPVPostFilter::DoAnyNeededConversions ( vtkDataSet dataset)
◆ DoAnyNeededConversions() [3/3]
int vtkPVPostFilter::DoAnyNeededConversions ( vtkDataSet output,
const char *  requested_name,
const char *  demangled_name,
const char *  demagled_component_name
◆ CellDataToPointData()
void vtkPVPostFilter::CellDataToPointData ( vtkDataSet output,
const char *  name
◆ PointDataToCellData()
void vtkPVPostFilter::PointDataToCellData ( vtkDataSet output,
const char *  name
◆ ExtractComponent()
int vtkPVPostFilter::ExtractComponent ( vtkDataSetAttributes dsa,
