progress handler. More...
#include <vtkPVProgressHandler.h>
void | RegisterProgressEvent (vtkObject *object, int id) |
Listen to progress events from the object. More... | |
void | PrepareProgress () |
This method resets all the progress counters and prepares progress reporting. More... | |
void | AddHandlers () |
This method add wrong tag event handlers and rmi call back for progress related mathods. More... | |
bool | GetEnableProgress () |
Get whether or not progress is currently enable and if this progress handler is ready to receive progress events. More... | |
void | CleanupPendingProgress () |
This method collects all outstanding progress messages. More... | |
void | LocalCleanupPendingProgress () |
Local cleanup of progress flags. More... | |
void | SetSession (vtkPVSession *conn) |
Get/Set the session. More... | |
virtual vtkPVSession * | GetSession () |
virtual void | SetProgressInterval (double) |
Get/Set the progress interval in seconds. More... | |
virtual double | GetProgressInterval () |
virtual char * | GetLastProgressText () |
These are only valid in handler for the vtkCommand::ProgressEvent. More... | |
virtual int | GetLastProgress () |
virtual void | Modified () |
static vtkPVProgressHandler * | New () |
static vtkPVProgressHandler * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
Protected Types | |
enum | TAGS { CLEANUP_TAG = 188969, PROGRESS_EVENT_TAG = 188970, MESSAGE_EVENT_TAG = 188971 } |
enum | RMI_TAGS { CLEANUP_TAG_RMI = 188972, MESSAGE_EVENT_TAG_RMI = 188973 } |
vtkPVProgressHandler () | |
~vtkPVProgressHandler () override | |
void | RefreshProgress (const char *progress_text, double progress) |
Update the last progress and progress text and invokes a progress event. More... | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkPVSession * | Session |
double | ProgressInterval |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | RMICallback |
progress handler.
vtkPVProgressHandler handles the progress messages. It handles progress in all configurations single process, client-server. It must be noted that when running in parallel, progress updates are fetched from the root node. Due to performance reasons, we no longer collect progress events (or messages) from satellites, only root-node events are reported back to the client. While this may not faithfully report the progress, this avoid nasty MPI issues that can be painful to debug and diagnose.
Progress events are currently not supported in multi-clients mode.
calldata:
vtkPVProgressHandler* vtkCommand::ProgressEvent calldata:
vtkPVProgressHandler* vtkCommand::EndEvent calldata:
vtkPVProgressHandler*Definition at line 40 of file vtkPVProgressHandler.h.
Definition at line 44 of file vtkPVProgressHandler.h.
Enumerator | |
CLEANUP_TAG | |
PROGRESS_EVENT_TAG | |
MESSAGE_EVENT_TAG |
Definition at line 111 of file vtkPVProgressHandler.h.
Enumerator | |
CLEANUP_TAG_RMI | |
MESSAGE_EVENT_TAG_RMI |
Definition at line 118 of file vtkPVProgressHandler.h.
void vtkPVProgressHandler::SetSession | ( | vtkPVSession * | conn | ) |
This is not reference-counted to avoid cycles.
void vtkPVProgressHandler::PrepareProgress | ( | ) |
All progress events before this call are ignored.
void vtkPVProgressHandler::AddHandlers | ( | ) |
bool vtkPVProgressHandler::GetEnableProgress | ( | ) |
void vtkPVProgressHandler::CleanupPendingProgress | ( | ) |
All progress events after this call are ignored.
void vtkPVProgressHandler::LocalCleanupPendingProgress | ( | ) |
Progress events occurring more frequently than this interval are skipped. Default is 0.1 seconds on client and 1 second on server and batch processes.
friend |
Definition at line 166 of file vtkPVProgressHandler.h.
Definition at line 129 of file vtkPVProgressHandler.h.
Definition at line 130 of file vtkPVProgressHandler.h.
