singleton used to filter out undesired data attribute from the representation. More...
#include <vtkPVRepresentedArrayListSettings.h>
| virtual bool | ShouldUseMagnitudeMode (int ncomp) const |
| Check if the array mode for this number of components should be the magnitude mode or not. More... | |
| virtual void | SetNumberOfFilterExpressions (int n) |
| Set/get the number of filter expressions. More... | |
| virtual int | GetNumberOfFilterExpressions () |
| virtual void | SetFilterExpression (int i, const char *expression) |
| Set/get the filter expression at index i. More... | |
| virtual const char * | GetFilterExpression (int i) |
| virtual void | SetComputeArrayMagnitude (bool) |
| Setters to control whether ParaView should allow the user to display the gradient of a given multi-component field. More... | |
| virtual void | SetArrayMagnitudeException (int idx, int ncomp) |
| virtual void | SetNumberOfArrayMagnitudeExceptions (int nexceptions) |
| virtual void | SetNumberOfChartsDefaultXAxis (int n) |
| ChartsDefaultXAxis is the list of array names that will be selected by default as the X axis when displaying some data in charts. More... | |
| virtual int | GetNumberOfChartsDefaultXAxis () const |
| virtual void | SetChartsDefaultXAxis (int i, const char *expression) |
| virtual const char * | GetChartsDefaultXAxis (int i) const |
| virtual const std::vector< std::string > & | GetAllChartsDefaultXAxis () const |
| virtual void | SetNumberOfChartsHiddenAttributes (int n) |
| ChartsHiddenAttributes is a list of regex that controls whether or not array should be visible by defaults in a chart. More... | |
| virtual int | GetNumberOfChartsHiddenAttributes () const |
| virtual void | SetChartsHiddenAttributes (int i, const char *expression) |
| virtual const std::vector< vtksys::RegularExpression > & | GetAllChartsHiddenAttributes () const |
| virtual bool | GetSeriesVisibilityDefault (const char *name) const |
| static vtkPVRepresentedArrayListSettings * | New () |
| static vtkPVRepresentedArrayListSettings * | SafeDownCast (vtkObject *o) |
| static vtkPVRepresentedArrayListSettings * | GetInstance () |
| Access the singleton. More... | |
| vtkPVRepresentedArrayListSettings () | |
| ~vtkPVRepresentedArrayListSettings () override | |
Currently represent the "Represented Attributes" section of ParaView settings.
vtkPVRepresentedArrayListSettings is a singleton used to keep track of a list of regular expressions that filter out arrays in a RepresentedArrayList domain, and contains other settings controlling which array should be visible in which situation.
All calls to vtkPVRepresentedArrayListSettings::New() returns a reference to the singleton instance.
Definition at line 36 of file vtkPVRepresentedArrayListSettings.h.
Definition at line 40 of file vtkPVRepresentedArrayListSettings.h.
If the index is outside the valid range, this call is a noop.
If ComputeArrayMagnitude is true then ParaView will always compute the magnitude. Otherwise it will not.
ArrayMagnitudeExceptions is the list of exceptions and will behave differently depending on the value of ComputeArrayMagnitude. If ComputeArrayMagnitude is false then the list describes the number of components for which ParaView will still compute the magnitude. Else the list describe the number of components for which ParaView will not compute the magnitude.
This will internally use the informations given by ComputeArrayMagnitude and ArrayMagnitudeExceptions.
If the name of the array matches one of the regex then it will be hidden by defaults, otherwise it will be visible.
See GetSeriesVisibilityDefault to evaluate the default visibility of a given array name.
1.8.13 on Sun Dec 14 2025
