Defines a 2D transfer function for mapping to RGBA values for volume rendering. More...
#include <vtkPVTransferFunction2D.h>
| virtual void | Build () |
| Generate the transfer function image data. More... | |
| std::vector< vtkSmartPointer< vtkPVTransferFunction2DBox > > | GetBoxes () |
| Get the control boxes defined on the function. More... | |
| void | RemoveAllBoxes () |
| Remove all control boxes from the transfer function. More... | |
| vtkImageData * | GetFunction () |
| Get the 2D transfer function. More... | |
| virtual void | SetOutputDimensions (int, int) |
| Set/Get the output dimensions of the image data that is the transfer function. More... | |
| void | SetOutputDimensions (int [2]) |
| virtual int * | GetOutputDimensions () |
| virtual void | GetOutputDimensions (int &, int &) |
| virtual void | GetOutputDimensions (int [2]) |
| int | AddControlBox (double x, double y, double width, double height, double r, double g, double b, double a) |
| Add/Remove a control box to/from the 2D transfer function. More... | |
| int | AddControlBox (double x, double y, double width, double height, double *color) |
| int | AddControlBox (vtkRectd &box, double *color) |
| int | AddControlBox (vtkSmartPointer< vtkPVTransferFunction2DBox > box) |
| int | SetControlBox (int id, vtkSmartPointer< vtkPVTransferFunction2DBox > box) |
| int | RemoveControlBox (int id) |
| int | RemoveControlBox (vtkSmartPointer< vtkPVTransferFunction2DBox > box) |
| virtual void | SetRange (double, double, double, double) |
| Set/Get the range of the function. More... | |
| virtual void | SetRange (double [4]) |
| virtual double * | GetRange () |
| virtual void | GetRange (double &, double &, double &, double &) |
| virtual void | GetRange (double [4]) |
| static vtkPVTransferFunction2D * | New () |
| Instantiate the class. More... | |
| vtkPVTransferFunction2D () | |
| ~vtkPVTransferFunction2D () override | |
| bool | UpdateRange () |
| Update the range of the function. More... | |
Protected Attributes | |
| double | Range [4] = { 0, 0, 0, 0 } |
| The range for the X and Y axes of the function. More... | |
| int | OutputDimensions [2] = { 10, 10 } |
| The output dimensions for the transfer function. More... | |
| Standard methods for the VTK class. More... | |
| static vtkPVTransferFunction2D * | SafeDownCast (vtkObject *o) |
vtkPVTransferFunction2D is a color mapping in RGBA space that uses 2D functions to allow interpolation along both the X and Y axes of the function.
Definition at line 27 of file vtkPVTransferFunction2D.h.
Definition at line 39 of file vtkPVTransferFunction2D.h.
By default, this is (10, 10).
| void vtkPVTransferFunction2D::SetOutputDimensions | ( | int | [2] | ) |
| int vtkPVTransferFunction2D::AddControlBox | ( | double | x, |
| double | y, | ||
| double | width, | ||
| double | height, | ||
| double | r, | ||
| double | g, | ||
| double | b, | ||
| double | a | ||
Returns the index of the added box or -1 on error.
| double | y, | ||
| double * | color | ||
| int vtkPVTransferFunction2D::AddControlBox | ( | vtkSmartPointer< vtkPVTransferFunction2DBox > | box | ) |
| int vtkPVTransferFunction2D::SetControlBox | ( | int | id, |
| vtkSmartPointer< vtkPVTransferFunction2DBox > | box | ||
| int vtkPVTransferFunction2D::RemoveControlBox | ( | vtkSmartPointer< vtkPVTransferFunction2DBox > | box | ) |
| std::vector<vtkSmartPointer<vtkPVTransferFunction2DBox> > vtkPVTransferFunction2D::GetBoxes | ( | ) |
| void vtkPVTransferFunction2D::RemoveAllBoxes | ( | ) |
Set/Get the (minX, maxX, minY, maxY) for the 2D transfer function.
| vtkImageData* vtkPVTransferFunction2D::GetFunction | ( | ) |
Returns true if the range changes. If the range has changed, calls Modified(). If UseCustomRange is set, this is a no-op.
This will determine the bounds of the transfer function.
Definition at line 108 of file vtkPVTransferFunction2D.h.
Definition at line 113 of file vtkPVTransferFunction2D.h.
1.8.13 on Sat Dec 13 2025
