void | SetOutput (vtkDataObject *output) override |
| Set the data object that is "produced" by this producer. More...
virtual void | SetOutput (vtkDataObject *output, double time) |
| Set the output data object as well as time information for the requests. More...
int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| Process upstream/downstream requests trivially. More...
vtkTrivialProducer * | NewInstance () const |
virtual void | SetWholeExtent (int, int, int, int, int, int) |
virtual void | SetWholeExtent (int[6]) |
virtual int * | GetWholeExtent () |
virtual void | GetWholeExtent (int &, int &, int &, int &, int &, int &) |
virtual void | GetWholeExtent (int[6]) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkPVTrivialProducer () |
| ~vtkPVTrivialProducer () override |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkTrivialProducer () |
| ~vtkTrivialProducer () |
virtual int | FillInputPortInformation (int, vtkInformation *) |
virtual int | FillOutputPortInformation (int, vtkInformation *) |
virtual vtkExecutive * | CreateDefaultExecutive () |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
specialized subclass of vtkTrivialProducer that preserves the information about the whole extent of the data object.
vtkPVTrivialProducer is specialized subclass of vtkTrivialProducer that can manage time requests.
Definition at line 20 of file vtkPVTrivialProducer.h.
