#include <vtkParticlePipeline.h>
| typedef vtkCPPipeline | Superclass |
Public Types inherited from vtkCPPipeline | |
| int | RequestDataDescription (vtkCPDataDescription *desc) override |
| Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More... | |
| int | CoProcess (vtkCPDataDescription *desc) override |
| Execute the pipeline. Returns 1 for success and 0 for failure. More... | |
| virtual void | SetFilename (const char *filename) |
| virtual char * | GetFilename () |
| virtual void | SetParticleRadius (double) |
| virtual double | GetParticleRadius () |
| virtual void | SetCameraThetaAngle (double) |
| virtual double | GetCameraThetaAngle () |
| virtual void | SetCameraPhiAngle (double) |
| virtual double | GetCameraPhiAngle () |
| virtual void | SetCameraDistance (double) |
| virtual double | GetCameraDistance () |
| virtual void | SetBounds (double, double, double, double, double, double) |
| virtual void | SetBounds (double [6]) |
| virtual double * | GetBounds () |
| virtual void | GetBounds (double data[6]) |
| virtual void | SetAttributeMaximum (double) |
| virtual double | GetAttributeMaximum () |
| virtual void | SetAttributeMinimum (double) |
| virtual double | GetAttributeMinimum () |
Public Member Functions inherited from vtkCPPipeline | |
| virtual int | Finalize () |
| Finalize the pipeline before deleting it. More... | |
| static vtkParticlePipeline * | New () |
| static vtkParticlePipeline * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkCPPipeline | |
| static vtkCPPipeline * | SafeDownCast (vtkObject *o) |
| vtkParticlePipeline () | |
| ~vtkParticlePipeline () override | |
| void | SetupPipeline () |
Protected Member Functions inherited from vtkCPPipeline | |
| vtkCPPipeline () | |
| ~vtkCPPipeline () override | |
Protected Attributes | |
| char * | Filename |
| double | ParticleRadius |
| double | CameraThetaAngle |
| double | CameraPhiAngle |
| double | CameraDistance |
| double | Bounds [6] |
| double | AttributeMaximum |
| double | AttributeMinimum |
| vtkTrivialProducer * | input |
| vtkColorTransferFunction * | lut |
| vtkSphereSource * | sphere |
| vtkOutlineSource * | outline |
| vtkGlyph3DMapper * | particleMapper |
| vtkPolyDataMapper * | outlineMapper |
| vtkActor * | particleActor |
| vtkActor * | outlineActor |
| vtkLightKit * | lightKit |
| vtkIceTSynchronizedRenderers * | syncRen |
| vtkSynchronizedRenderWindows * | syncWin |
| vtkRenderWindow * | window |
| vtkRenderer * | renderer |
| vtkWindowToImageFilter * | w2i |
| vtkPNGWriter * | writer |
Definition at line 25 of file vtkParticlePipeline.h.
Definition at line 29 of file vtkParticlePipeline.h.
Reimplemented from vtkCPPipeline.
If coprocessing does need to be performed this time step it fills in the FieldNames array that the coprocessor requires in order to fulfill all the coprocessing requests for this TimeStep/Time combination.
Implements vtkCPPipeline.
Definition at line 81 of file vtkParticlePipeline.h.
Definition at line 83 of file vtkParticlePipeline.h.
Definition at line 85 of file vtkParticlePipeline.h.
Definition at line 86 of file vtkParticlePipeline.h.
Definition at line 87 of file vtkParticlePipeline.h.
Definition at line 89 of file vtkParticlePipeline.h.
Definition at line 91 of file vtkParticlePipeline.h.
Definition at line 92 of file vtkParticlePipeline.h.
Definition at line 94 of file vtkParticlePipeline.h.
Definition at line 95 of file vtkParticlePipeline.h.
Definition at line 96 of file vtkParticlePipeline.h.
Definition at line 97 of file vtkParticlePipeline.h.
Definition at line 98 of file vtkParticlePipeline.h.
Definition at line 99 of file vtkParticlePipeline.h.
Definition at line 100 of file vtkParticlePipeline.h.
Definition at line 101 of file vtkParticlePipeline.h.
Definition at line 102 of file vtkParticlePipeline.h.
Definition at line 103 of file vtkParticlePipeline.h.
Definition at line 104 of file vtkParticlePipeline.h.
Definition at line 105 of file vtkParticlePipeline.h.
Definition at line 106 of file vtkParticlePipeline.h.
Definition at line 107 of file vtkParticlePipeline.h.
Definition at line 108 of file vtkParticlePipeline.h.
1.8.13 on Sun Dec 14 2025
