runtime configuration for vtkProcessModule More...
#include <vtkProcessModuleConfiguration.h>
| virtual bool | GetForceMPIInit () |
Get whether to call MPI_Init() on this process irrespective of whether MPI is needed on this process. More... | |
| virtual bool | GetForceNoMPIInit () |
Get whether to not call MPI_Init() on this process irrespective of whether MPI is needed on this process. More... | |
| virtual bool | GetUseMPISSend () |
| Flag indicating whether to use synchronous send (SSend) for MPI communication. More... | |
| virtual bool | GetSymmetricMPIMode () |
| Get whether to use symmetric MPI mode. More... | |
| virtual void | SetSymmetricMPIMode (bool) |
| Ideally, this method should not be public. More... | |
| virtual std::string | GetVirtualEnvironmentPath () |
| Get the virtual environment path to set up for Python. More... | |
| virtual vtkLogger::Verbosity | GetLogStdErrVerbosity () |
Get the verbosity level to use for reporting log messages on stderr. More... | |
| std::string | GetCSLogFileName () const |
| Get the filename to use to generate client-server-stream logs, if any. More... | |
| virtual bool | GetEnableStackTrace () |
| Get whether to generate a stack trace after a crash. More... | |
| const std::vector< std::pair< std::string, vtkLogger::Verbosity > > & | GetLogFiles () const |
| Returns a vector of pairs for log files requested. More... | |
| bool | PopulateOptions (vtkCLIOptions *options, vtkProcessModule::ProcessTypes processType) |
| Populate command line options. More... | |
| static vtkProcessModuleConfiguration * | SafeDownCast (vtkObject *o) |
| static vtkProcessModuleConfiguration * | GetInstance () |
| Provides access to the singleton. More... | |
| static std::string | GetRankAnnotatedFileName (const std::string &fname) |
| A helper function to add a rank number to the filename, if needed. More... | |
| vtkProcessModuleConfiguration () | |
| ~vtkProcessModuleConfiguration () override | |
vtkProcessModuleConfiguration is a singleton that maintains runtime configuration options that affect how vtkProcessModule is initialized.
Definition at line 24 of file vtkProcessModuleConfiguration.h.
Definition at line 27 of file vtkProcessModuleConfiguration.h.
In this mode is only supported in "batch". In that case, all processes, including the satellites, execute the Python script locally.
However, we are keeping it public to avoid changing to much code at this time.
In other words, all messages at the chosen level and higher are posted to stderr. Default is vtkLogger::VERBOSITY_INVALID.
| std::string vtkProcessModuleConfiguration::GetCSLogFileName | ( | ) | const |
If running in a distributed mode, the filename is automatically changed to include current rank index.
This is currently only supported on POSIX systems.
Definition at line 94 of file vtkProcessModuleConfiguration.h.
| bool vtkProcessModuleConfiguration::PopulateOptions | ( | vtkCLIOptions * | options, |
| vtkProcessModule::ProcessTypes | processType | ||
processType indicates which type of ParaView process the options are being setup for. That may affect available options.
This is useful to create a separate log file per rank, for example, when executing in parallel. If number of ranks is 1, the filename is unchanged.
1.8.13 on Tue Dec 16 2025
