vtkRulerSourceRepresentation is a representation to show a ruler. More...
#include <vtkRulerSourceRepresentation.h>
| typedef vtkPVDataRepresentation | Superclass |
Public Types inherited from vtkPVDataRepresentation | |
| enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
| typedef vtkDataRepresentation | Superclass |
Public Types inherited from vtkDataRepresentation | |
| typedef vtkPassInputTypeAlgorithm | Superclass |
Public Types inherited from vtkPassInputTypeAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| void | SetTextProperty (vtkTextProperty *prop) |
| Set the text property for the printed distance. More... | |
| void | SetAxisLineWidth (float width) |
| Set the line width for the displayed axis in screen units. More... | |
| void | SetAxisColor (double red, double green, double blue) |
| Set the color for the displayed axis. More... | |
| void | SetVisibility (bool) override |
| Set the visibility. More... | |
| void | SetLabelFormat (char *labelFormat) |
| Specify the format to use for labeling the distance. More... | |
| void | SetNumberOfRulerTicks (int numberOfRulerTicks) |
| Specify the number of major ruler ticks. More... | |
| vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
| void | SetDistanceRepresentation (vtkDistanceRepresentation2D *) |
| Set the text widget. More... | |
| virtual vtkDistanceRepresentation2D * | GetDistanceRepresentation () |
| void | SetRulerMode (int choice) |
| Enable or disable ruler mode. More... | |
| int | GetRulerMode () |
| void | SetRulerDistance (double distance) |
| Specify the RulerDistance which indicates the spacing of the major ticks in the unit space obtained after the Scale is applied (see SetScale()). More... | |
| double | GetRulerDistance () |
| void | SetScale (double distance) |
| Set scale factor to apply to the ruler graduation scale and the displayed distance. More... | |
| double | GetScale () |
Public Member Functions inherited from vtkPVDataRepresentation | |
| virtual void | MarkModified () |
| This is one of the most important functions. More... | |
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| Initialize the representation with an identifier range so each internal representation can own a unique ID. More... | |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
| Returns the data object that is rendered from the given input port. More... | |
| Returns the cache-key the representation is currently using. More... | |
| Retrieves an output port for the input data object at the specified port and connection index. More... | |
| Provides access to the view. More... | |
Returns the timestamp when RequestData was executed on the representation. More... | |
| bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More... | |
| Specify the array names used for the selection. More... | |
| Set the update time. More... | |
| Get whether the UpdateTime is valid. More... | |
| void | ResetUpdateTime () |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
| Making these methods public. More... | |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| This flag indicates if the representation is for a temporal pipeline. More... | |
Overridden to ensure that MarkModified is called. More... | |
Public Member Functions inherited from vtkDataRepresentation | |
Public Member Functions inherited from vtkPassInputTypeAlgorithm | |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
Protected Attributes | |
| vtkDistanceRepresentation2D * | DistanceRepresentation |
| vtkNew< vtkPolyData > | Clone |
Protected Attributes inherited from vtkPVDataRepresentation | |
| double | UpdateTime |
| bool | UpdateTimeValid |
| unsigned int | UniqueIdentifier |
Protected Attributes inherited from vtkDataRepresentation | |
| bool | Selectable |
| int | SelectionType |
| vtkStringArray * | SelectionArrayNames |
| Command * | Observer |
| vtkAnnotationLink * | AnnotationLinkInternal |
Protected Attributes inherited from vtkAlgorithm | |
| vtkInformation * | Information |
| double | Progress |
| char * | ProgressText |
| vtkProgressObserver * | ProgressObserver |
| unsigned long | ErrorCode |
Public Attributes inherited from vtkAlgorithm | |
| SINGLE_PRECISION | |
| DOUBLE_PRECISION | |
| DEFAULT_PRECISION | |
| int | AbortExecute |
Static Protected Member Functions inherited from vtkAlgorithm | |
| static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
Static Protected Attributes inherited from vtkAlgorithm | |
| static vtkExecutive * | DefaultExecutivePrototype |
The input is expected to be vtkPolyData with two points.
Definition at line 22 of file vtkRulerSourceRepresentation.h.
Definition at line 26 of file vtkRulerSourceRepresentation.h.
| void vtkRulerSourceRepresentation::SetDistanceRepresentation | ( | vtkDistanceRepresentation2D * | ) |
| void vtkRulerSourceRepresentation::SetTextProperty | ( | vtkTextProperty * | prop | ) |
| void vtkRulerSourceRepresentation::SetAxisLineWidth | ( | float | width | ) |
Set the visibility.
| void vtkRulerSourceRepresentation::SetLabelFormat | ( | char * | labelFormat | ) |
Note that an empty string results in no label, or a format string without a "%" character will not print the distance value.
| void vtkRulerSourceRepresentation::SetRulerMode | ( | int | choice | ) |
When enabled, the ticks on the distance widget are separated by the amount specified by vtkDistanceRepresentation::RulerDistance. Otherwise, the value vtkDistanceRepresentation::NumberOfRulerTicks is used to draw the tick marks.
| int vtkRulerSourceRepresentation::GetRulerMode | ( | ) |
| void vtkRulerSourceRepresentation::SetRulerDistance | ( | double | distance | ) |
This ivar only has effect when the RulerMode is on.
| double vtkRulerSourceRepresentation::GetRulerDistance | ( | ) |
| void vtkRulerSourceRepresentation::SetScale | ( | double | distance | ) |
Used to transform VTK world space units to a desired unit, e.g., inches to centimeters.
| double vtkRulerSourceRepresentation::GetScale | ( | ) |
| void vtkRulerSourceRepresentation::SetNumberOfRulerTicks | ( | int | numberOfRulerTicks | ) |
Note: the number of ticks is the number between the two handle endpoints. This ivar only has effect when the RulerMode is off.
overrideprotectedvirtual |
Overridden to invoke vtkCommand::UpdateDataEvent.
Fill input port information.
Definition at line 137 of file vtkRulerSourceRepresentation.h.
Definition at line 138 of file vtkRulerSourceRepresentation.h.
1.8.13 on Sun Dec 14 2025
