vtkSMInteractionUndoStackBuilder Class Reference
builder server manager undo sets for render view interactions and pushes them on the undo stack. More...
#include <vtkSMInteractionUndoStackBuilder.h>
Inheritance diagram for vtkSMInteractionUndoStackBuilder:
Collaboration diagram for vtkSMInteractionUndoStackBuilder:
void Clear ()
 Clear the undo set currently being recorded. More...
void StartInteraction ()
 Called to record the state at the beginning of an interaction. More...
void EndInteraction ()
 Called to record the state at the end of an interaction and push it on the stack. More...
void SetRenderView (vtkSMRenderViewProxy *)
 Get/Set the render view proxy for which we are monitoring the interactions. More...
virtual vtkSMRenderViewProxyGetRenderView ()
virtual vtkSMUndoStackGetUndoStack ()
 Get/Set the undo stack that this builder will build. More...
virtual void SetUndoStack (vtkSMUndoStack *)
- Public Member Functions inherited from vtkSMObject
static vtkSMInteractionUndoStackBuilderNew ()
static vtkSMInteractionUndoStackBuilderSafeDownCast (vtkObject *o)
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMInteractionUndoStackBuilder ()
 ~vtkSMInteractionUndoStackBuilder () override
void ExecuteEvent (vtkObject *caller, unsigned long event, void *data)
 Event handler. More...
void PropertyModified (const char *pname)
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMRenderViewProxyRenderView
vtkSMUndoStackUndoStack
vtkUndoSetUndoSet
Friends
class vtkSMInteractionUndoStackBuilderObserver
vtkSMInteractionUndoStackBuilder specializes in interaction. This class can create undo elements for only one render view at a time.
Definition at line 24 of file vtkSMInteractionUndoStackBuilder.h.
Definition at line 28 of file vtkSMInteractionUndoStackBuilder.h.
◆ vtkSMInteractionUndoStackBuilder()
vtkSMInteractionUndoStackBuilder::vtkSMInteractionUndoStackBuilder ( )
◆ ~vtkSMInteractionUndoStackBuilder()
vtkSMInteractionUndoStackBuilder::~vtkSMInteractionUndoStackBuilder ( )
static vtkSMInteractionUndoStackBuilder* vtkSMInteractionUndoStackBuilder::New ( )
virtual const char* vtkSMInteractionUndoStackBuilder::GetClassName ( )
static int vtkSMInteractionUndoStackBuilder::IsTypeOf ( const char *  type)
virtual int vtkSMInteractionUndoStackBuilder::IsA ( const char *  type)
static vtkSMInteractionUndoStackBuilder* vtkSMInteractionUndoStackBuilder::SafeDownCast ( vtkObject o)
void vtkSMInteractionUndoStackBuilder::PrintSelf ( ostream &  os,
◆ SetRenderView()
void vtkSMInteractionUndoStackBuilder::SetRenderView ( vtkSMRenderViewProxy )
◆ GetRenderView()
virtual vtkSMRenderViewProxy* vtkSMInteractionUndoStackBuilder::GetRenderView ( )
◆ GetUndoStack()
virtual vtkSMUndoStack* vtkSMInteractionUndoStackBuilder::GetUndoStack ( )
◆ SetUndoStack()
virtual void vtkSMInteractionUndoStackBuilder::SetUndoStack ( vtkSMUndoStack )
◆ Clear()
void vtkSMInteractionUndoStackBuilder::Clear ( )
◆ StartInteraction()
void vtkSMInteractionUndoStackBuilder::StartInteraction ( )
Usually, this method isn't called directly, since the builder listens to interaction events on the interactor and calls it automatically. May be used when changing the camera programmatically.
◆ EndInteraction()
void vtkSMInteractionUndoStackBuilder::EndInteraction ( )
◆ ExecuteEvent()
void vtkSMInteractionUndoStackBuilder::ExecuteEvent ( vtkObject caller,
void *  data
Event handler.
◆ PropertyModified()
void vtkSMInteractionUndoStackBuilder::PropertyModified ( const char *  pname)
◆ vtkSMInteractionUndoStackBuilderObserver
friend class vtkSMInteractionUndoStackBuilderObserver
friend
Definition at line 87 of file vtkSMInteractionUndoStackBuilder.h.
◆ RenderView
vtkSMRenderViewProxy* vtkSMInteractionUndoStackBuilder::RenderView
Definition at line 76 of file vtkSMInteractionUndoStackBuilder.h.
◆ UndoStack
vtkSMUndoStack* vtkSMInteractionUndoStackBuilder::UndoStack
Definition at line 77 of file vtkSMInteractionUndoStackBuilder.h.
◆ UndoSet
vtkUndoSet* vtkSMInteractionUndoStackBuilder::UndoSet
Definition at line 78 of file vtkSMInteractionUndoStackBuilder.h.
