iterates over the properties of a proxy More...
#include <vtkSMOrderedPropertyIterator.h>
void | SetProxy (vtkSMProxy *proxy) |
Set the proxy to be used. More... | |
void | Begin () |
Go to the first property. More... | |
int | IsAtEnd () |
Returns true if iterator points past the end of the collection. More... | |
void | Next () |
Move to the next property. More... | |
const char * | GetKey () |
Returns the key (name) at the current iterator position. More... | |
Returns the property at the current iterator position. More... | |
const char * | GetPropertyLabel () |
Returns the XMLLabel for self properties and the exposed name for sub-proxy properties. More... | |
virtual vtkSMProxy * | GetProxy () |
Return the proxy. More... | |
virtual void | Modified () |
static vtkSMOrderedPropertyIterator * | New () |
static vtkSMOrderedPropertyIterator * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMOrderedPropertyIterator () | |
~vtkSMOrderedPropertyIterator () override | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkSMProxy * | Proxy |
unsigned int | Index |
bool | Debug |
vtkTimeStamp | MTime |
vtkSMOrderedPropertyIterator is used to iterate over the properties of a proxy. The properties of the root proxies as well as sub-proxies are included in the iteration. For sub-proxies, only exposed properties are iterated over. vtkSMOrderedPropertyIterator iterates over properties in the order they appear in the xml or in the order they were added. This is possible because vtkSMProxy keeps track of the order in which properties were added or exposed in a PropertyNamesInOrder vector.
Definition at line 25 of file vtkSMOrderedPropertyIterator.h.
Definition at line 29 of file vtkSMOrderedPropertyIterator.h.
void vtkSMOrderedPropertyIterator::SetProxy | ( | vtkSMProxy * | proxy | ) |
Return the proxy.
void vtkSMOrderedPropertyIterator::Begin | ( | ) |
int vtkSMOrderedPropertyIterator::IsAtEnd | ( | ) |
void vtkSMOrderedPropertyIterator::Next | ( | ) |
const char* vtkSMOrderedPropertyIterator::GetKey | ( | ) |
vtkSMProperty* vtkSMOrderedPropertyIterator::GetProperty | ( | ) |
const char* vtkSMOrderedPropertyIterator::GetPropertyLabel | ( | ) |
Definition at line 79 of file vtkSMOrderedPropertyIterator.h.
Definition at line 80 of file vtkSMOrderedPropertyIterator.h.
