This is the concrete implementation for the Undo element for a property modification event.
int | Undo () override |
| Undo the operation encapsulated by this element. More...
int | Redo () override |
| Redo the operation encaspsulated by this element. More...
void | ModifiedProperty (vtkSMProxy *proxy, const char *propertyname) |
| Set the property/proxy that was modified. More...
bool | Merge (vtkUndoElement *vtkNotUsed(new_element)) override |
| Called on the older element in the UndoSet to merge with the element being added if both the elements are mergeable . More...
virtual void | SetUndoSetWorkingContext (vtkCollection *workCTX) |
virtual bool | GetMergeable () |
| Returns if this undo element can be merged with other undo elements. More...
virtual void | Modified () |
The undo action sets the property to the value that was pushed on to the server previous to the modification. The redo action sets the property to the modified value.
Definition at line 21 of file vtkSMPropertyModificationUndoElement.h.
