selects proxies. More...
#include <vtkSMProxySelectionModel.h>
enum | ProxySelectionFlag { NO_UPDATE = 0, CLEAR = 1, SELECT = 2, DESELECT = 4, CLEAR_AND_SELECT = CLEAR | SELECT } |
typedef vtkSMRemoteObject | Superclass |
typedef std::list< vtkSmartPointer< vtkSMProxy > > | SelectionType |
Type for selection. More... | |
Override the set session, so we can attach an observer to the Collaboration manager in order to monitor master/slave changes. More... | |
vtkSMProxy * | GetCurrentProxy () |
Returns the proxy that is current, nullptr if there is no current. More... | |
void | SetCurrentProxy (vtkSMProxy *proxy, int command) |
Sets the current proxy. More... | |
bool | IsSelected (vtkSMProxy *proxy) |
Returns true if the proxy is selected. More... | |
unsigned int | GetNumberOfSelectedProxies () |
vtkSMProxy * | GetSelectedProxy (unsigned int index) |
Returns the selected proxy at the given index. More... | |
const SelectionType & | GetSelection () |
Returns the selection set. More... | |
void | Select (const SelectionType &proxies, int command) |
Update the selected set of proxies. More... | |
void | Select (vtkSMProxy *proxy, int command) |
void | Clear () |
Wrapper friendly methods to doing what Select() can do. More... | |
void | Select (vtkSMProxy *proxy) |
void | Deselect (vtkSMProxy *proxy) |
void | ClearAndSelect (vtkSMProxy *proxy) |
bool | GetSelectionDataBounds (double bounds[6]) |
Utility method to get the data bounds for the currently selected items. More... | |
This method return the full object state that can be used to create that object from scratch. More... | |
This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
void | SetFollowingMaster (bool following) |
Allow to synchronize the active object with master or just keep remote object out-of-synch. More... | |
bool | IsFollowingMaster () |
Override the SetSession so if the object already have an ID we automatically register it to the associated session. More... | |
bool | HasGlobalID () |
Allow the user to test if the RemoteObject has already a GlobalID without assigning a new one to it. More... | |
virtual void | EnableLocalPushOnly () |
Allow to switch off any push of state change to the server for that particular object. More... | |
virtual void | DisableLocalPushOnly () |
Enable the given remote object to communicate its state normally to the server location. More... | |
Let the session be aware that even if the Location is client only, the message should not be send to the server for a general broadcast. More... | |
virtual void | SetLocation (vtkTypeUInt32) |
Get/Set the location where the underlying VTK-objects are created. More... | |
Get the global unique id for this object. More... | |
virtual void | PrototypeOn () |
Allow user to set the remote object to be discard for Undo/Redo action. More... | |
virtual void | PrototypeOff () |
bool | IsPrototype () |
virtual void | SetPrototype (bool) |
virtual void | Modified () |
static vtkSMProxySelectionModel * | New () |
static vtkSMProxySelectionModel * | SafeDownCast (vtkObject *o) |
static vtkSMRemoteObject * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMProxySelectionModel () | |
~vtkSMProxySelectionModel () override | |
void | InvokeCurrentChanged (vtkSMProxy *proxy) |
void | InvokeSelectionChanged () |
void | PushStateToSession () |
When the state has changed we call that method so the state can be shared is any collaboration is involved. More... | |
vtkSMRemoteObject () | |
Default constructor. More... | |
~vtkSMRemoteObject () override | |
Destructor. More... | |
void | PushState (vtkSMMessage *msg) |
Subclasses can call this method to send a message to its state object on the server processes specified. More... | |
bool | PullState (vtkSMMessage *msg) |
Subclasses can call this method to pull the state from the state-object on the server processes specified. More... | |
void | SetGlobalID (vtkTypeUInt32 guid) |
Set the GlobalUniqueId. More... | |
vtkTypeUInt32 | GetFilteredLocation () |
vtkSMSessionObject () | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
Protected Attributes | |
vtkSmartPointer< vtkSMProxy > | Current |
SelectionType | Selection |
vtkSMMessage * | State |
vtkTypeUInt32 | GlobalID |
vtkTypeUInt32 | Location |
bool | Prototype |
bool | ClientOnlyLocationFlag |
vtkWeakPointer< vtkSMSession > | Session |
Identifies the session id to which this object is related. More... | |
bool | Debug |
vtkTimeStamp | MTime |
Friends | |
class | vtkInternal |
selects proxies.
vtkSMProxySelectionModel is used to select proxies. vtkSMProxyManager uses two instances of vtkSMProxySelectionModel for keeping track of the selected/active sources/filters and the active view.
Definition at line 28 of file vtkSMProxySelectionModel.h.
Definition at line 32 of file vtkSMProxySelectionModel.h.
typedef std::list<vtkSmartPointer<vtkSMProxy> > vtkSMProxySelectionModel::SelectionType |
Type for selection.
Definition at line 53 of file vtkSMProxySelectionModel.h.
Enumerator | |
NO_UPDATE | |
CLEAR | |
SELECT | |
DESELECT | |
CLEAR_AND_SELECT |
Definition at line 56 of file vtkSMProxySelectionModel.h.
Reimplemented from vtkSMRemoteObject.
Reimplemented from vtkSMSessionObject.
void vtkSMProxySelectionModel::SetFollowingMaster | ( | bool | following | ) |
Only the state from the master will be loaded.
bool vtkSMProxySelectionModel::IsFollowingMaster | ( | ) |
vtkSMProxy* vtkSMProxySelectionModel::GetCurrentProxy | ( | ) |
void vtkSMProxySelectionModel::SetCurrentProxy | ( | vtkSMProxy * | proxy, |
int | command | ||
command
is used to control how the current selection is affected.
bool vtkSMProxySelectionModel::IsSelected | ( | vtkSMProxy * | proxy | ) |
unsigned int vtkSMProxySelectionModel::GetNumberOfSelectedProxies | ( | ) |
vtkSMProxy* vtkSMProxySelectionModel::GetSelectedProxy | ( | unsigned int | index | ) |
Definition at line 97 of file vtkSMProxySelectionModel.h.
void vtkSMProxySelectionModel::Select | ( | const SelectionType & | proxies, |
int | command | ||
command
affects how the selection is updated.
void vtkSMProxySelectionModel::Select | ( | vtkSMProxy * | proxy, |
int | command | ||
Definition at line 117 of file vtkSMProxySelectionModel.h.
Definition at line 118 of file vtkSMProxySelectionModel.h.
Definition at line 119 of file vtkSMProxySelectionModel.h.
Definition at line 120 of file vtkSMProxySelectionModel.h.
bool vtkSMProxySelectionModel::GetSelectionDataBounds | ( | double | bounds[6] | ) |
This only makes sense for selections comprising of source-proxies or output-port proxies. Returns true is the bounds are valid.
This method will be used to fill the undo stack. If not overridden this will return nullptr.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
friend |
Definition at line 170 of file vtkSMProxySelectionModel.h.
Definition at line 154 of file vtkSMProxySelectionModel.h.
Definition at line 155 of file vtkSMProxySelectionModel.h.
Definition at line 164 of file vtkSMProxySelectionModel.h.
