manages transfer functions i.e. More...
#include <vtkSMTransferFunctionManager.h>
enum | UpdateScalarBarsMode { HIDE_UNUSED_SCALAR_BARS = 0x01, SHOW_USED_SCALAR_BARS = 0x02 } |
enum | TransferFunctionResetMode { NEVER = -1, GROW_ON_APPLY = 0, GROW_ON_APPLY_AND_TIMESTEP = 1, RESET_ON_APPLY = 2, RESET_ON_APPLY_AND_TIMESTEP = 3, RESET_VISIBLE_ON_APPLY = 4, RESET_VISIBLE_ON_APPLY_AND_TIMESTEP = 5 } |
Enum for TransferFunctionResetMode GROW means the data range can only expand to new data RESET means the data range corresponds exactly to the data RESET_VISIBLE means the data range corresponds exactly to the visible data. More... | |
virtual vtkSMProxy * | GetColorTransferFunction (const char *arrayName, vtkSMSessionProxyManager *pxm) |
Returns a color transfer function proxy instance for mapping a data array with the given name. More... | |
virtual vtkSMProxy * | GetOpacityTransferFunction (const char *arrayName, vtkSMSessionProxyManager *pxm) |
Returns a opacity transfer function proxy (aka Piecewise Function) instance for mapping a data array with the given name. More... | |
virtual vtkSMProxy * | GetTransferFunction2D (const char *arrayName, vtkSMSessionProxyManager *pxm) |
Returns a 2D transfer function proxy (aka Image Data) instance. More... | |
virtual vtkSMProxy * | GetTransferFunction2D (const char *arrayName, const char *array2Name, vtkSMSessionProxyManager *pxm) |
virtual vtkSMProxy * | GetScalarBarRepresentation (vtkSMProxy *colorTransferFunctionProxy, vtkSMProxy *view) |
Returns the scalar-bar (color-legend) representation corresponding to the transfer function for the view (currently only render-views are supported). More... | |
void | ResetAllTransferFunctionRangesUsingCurrentData (vtkSMSessionProxyManager *pxm, bool animating=false) |
Iterates over all "known" transfer function proxies and request each one of them to update its range using data information currently available. More... | |
virtual bool | UpdateScalarBars (vtkSMProxy *viewProxy, unsigned int mode) |
Updates the scalar bar visibility in the view. More... | |
virtual bool | UpdateScalarBarsComponentTitle (vtkSMProxy *lutProxy, vtkSMProxy *representation) |
Updates all scalar bars using provided lutProxy, the representation is used to recover the component title. More... | |
virtual bool | HideScalarBarIfNotNeeded (vtkSMProxy *lutProxy, vtkSMProxy *view) |
Hides the scalar bar, if any, for the lutProxy in the view if it's not being used. More... | |
virtual void | Modified () |
static vtkSMTransferFunctionManager * | New () |
static vtkSMTransferFunctionManager * | SafeDownCast (vtkObject *o) |
static vtkObject * | New () |
vtkSMTransferFunctionManager () | |
~vtkSMTransferFunctionManager () override | |
vtkSMObject () | |
~vtkSMObject () override | |
vtkObject () | |
virtual | ~vtkObject () |
vtkObjectBase () | |
virtual | ~vtkObjectBase () |
bool | Debug |
vtkTimeStamp | MTime |
color lookuptables and opacity piecewise functions for ParaView applications.
vtkSMTransferFunctionManager manages transfer functions i.e. color lookuptables and opacity piecewise functions for ParaView applications. vtkSMTransferFunctionManager implements the ParaView specific mechanism for managing such transfer function proxies where there's one transfer function created and maintained per data array name.
vtkSMTransferFunctionManager has no state. You can create as many instances as per your choosing to call the methods. It uses the session proxy manager to locate proxies registered using specific names under specific groups. Thus, the state is maintained by the proxy manager itself.
Definition at line 29 of file vtkSMTransferFunctionManager.h.
Definition at line 33 of file vtkSMTransferFunctionManager.h.
Enumerator | |
HIDE_UNUSED_SCALAR_BARS | |
SHOW_USED_SCALAR_BARS |
Definition at line 78 of file vtkSMTransferFunctionManager.h.
Enumerator | |
NEVER | |
GROW_ON_APPLY | |
GROW_ON_APPLY_AND_TIMESTEP | |
RESET_ON_APPLY | |
RESET_ON_APPLY_AND_TIMESTEP | |
RESET_VISIBLE_ON_APPLY | |
RESET_VISIBLE_ON_APPLY_AND_TIMESTEP |
Definition at line 90 of file vtkSMTransferFunctionManager.h.
If none exists in the given session, a new instance will be created and returned.
Thus returns an existing proxy, if present, otherwise a new one is created, if possible.
void vtkSMTransferFunctionManager::ResetAllTransferFunctionRangesUsingCurrentData | ( | vtkSMSessionProxyManager * | pxm, |
bool | animating = false |
Set animating
to true if this is called in the context of an animation, false otherwise. It relies on the mode defined by the TransferFunctionResetMode enum
Based on the specified mode, scalars bars representing non-represented arrays can be automatically hidden; and those corresponding to arrays used for coloring can be automatically shown.
Returns true if the scalar bar visibility was changed.
