vtkSelectionRepresentation is a representation to show the extracted cells. More...
#include <vtkSelectionRepresentation.h>
| typedef vtkPVDataRepresentation | Superclass |
Public Types inherited from vtkPVDataRepresentation | |
| enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
| typedef vtkDataRepresentation | Superclass |
Public Types inherited from vtkDataRepresentation | |
| typedef vtkPassInputTypeAlgorithm | Superclass |
Public Types inherited from vtkPassInputTypeAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
| void | SetLabelRepresentation (vtkDataLabelRepresentation *) |
| One must change the internal representations only before the representation is added to a view, after that it should not be touched. More... | |
| This needs to be called on all instances of vtkSelectionRepresentation when the input is modified. More... | |
| void | SetVisibility (bool val) override |
| Get/Set the visibility for this representation. More... | |
| unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override |
| Override because of internal composite representations that need to be initialized as well. More... | |
| void | SetLogName (const std::string &) override |
| Overridden to pass logname to internal GeometryRepresentation. More... | |
| Overridden to simply pass the input to the internal representations. More... | |
| void | SetInputConnection (vtkAlgorithmOutput *input) override |
| void | AddInputConnection (vtkAlgorithmOutput *input) override |
| void | RemoveInputConnection (int port, vtkAlgorithmOutput *input) override |
| void | RemoveInputConnection (int port, int idx) override |
| void | SetUpdateTime (double time) override |
| Passed on to internal representations as well. More... | |
| void | SetForceUseCache (bool val) override |
| void | SetForcedCacheKey (double val) override |
| void | SetColor (double r, double g, double b) |
| Forwarded to GeometryRepresentation. More... | |
| void | SetLineWidth (double val) |
| void | SetOpacity (double val) |
| void | SetPointSize (double val) |
| void | SetRepresentation (int val) |
| void | SetUseOutline (int) |
| void | SetRenderPointsAsSpheres (bool) |
| void | SetRenderLinesAsTubes (bool) |
| void | SetOrientation (double, double, double) |
| Forwarded to GeometryRepresentation and LabelRepresentation. More... | |
| void | SetOrigin (double, double, double) |
| void | SetPosition (double, double, double) |
| void | SetScale (double, double, double) |
| void | SetUserTransform (const double[16]) |
| virtual void | SetPointFieldDataArrayName (const char *val) |
| Forwarded to vtkDataLabelRepresentation. More... | |
| virtual void | SetCellFieldDataArrayName (const char *val) |
Public Member Functions inherited from vtkPVDataRepresentation | |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
| Returns the data object that is rendered from the given input port. More... | |
| Returns the cache-key the representation is currently using. More... | |
| Retrieves an output port for the input data object at the specified port and connection index. More... | |
| Provides access to the view. More... | |
Returns the timestamp when RequestData was executed on the representation. More... | |
| bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More... | |
| Specify the array names used for the selection. More... | |
| Set the update time. More... | |
| Get whether the UpdateTime is valid. More... | |
| void | ResetUpdateTime () |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
| Making these methods public. More... | |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| This flag indicates if the representation is for a temporal pipeline. More... | |
Public Member Functions inherited from vtkDataRepresentation | |
Public Member Functions inherited from vtkPassInputTypeAlgorithm | |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
Protected Attributes | |
| vtkGeometryRepresentation * | GeometryRepresentation |
| vtkDataLabelRepresentation * | LabelRepresentation |
Protected Attributes inherited from vtkPVDataRepresentation | |
| double | UpdateTime |
| bool | UpdateTimeValid |
| unsigned int | UniqueIdentifier |
Protected Attributes inherited from vtkDataRepresentation | |
| bool | Selectable |
| int | SelectionType |
| vtkStringArray * | SelectionArrayNames |
| Command * | Observer |
| vtkAnnotationLink * | AnnotationLinkInternal |
Protected Attributes inherited from vtkAlgorithm | |
| vtkInformation * | Information |
| double | Progress |
| char * | ProgressText |
| vtkProgressObserver * | ProgressObserver |
| unsigned long | ErrorCode |
Public Attributes inherited from vtkAlgorithm | |
| SINGLE_PRECISION | |
| DOUBLE_PRECISION | |
| DEFAULT_PRECISION | |
| int | AbortExecute |
Static Protected Member Functions inherited from vtkAlgorithm | |
| static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
Static Protected Attributes inherited from vtkAlgorithm | |
| static vtkExecutive * | DefaultExecutivePrototype |
It uses vtkGeometryRepresentation and vtkPVDataRepresentation internally.
Definition at line 23 of file vtkSelectionRepresentation.h.
Definition at line 27 of file vtkSelectionRepresentation.h.
vtkDataRepresentation::GetVisibility() returns false. Reimplemented from vtkPVDataRepresentation.
| void vtkSelectionRepresentation::SetLabelRepresentation | ( | vtkDataLabelRepresentation * | ) |
We won't need this if vtkPVDataRepresentation correctly respected in the arguments passed to it during ProcessRequest() etc.
This is essential since the geometry filter does not have any real-input on the client side which messes with the Update requests.
When the visibility of representation of false, all view passes are ignored. Overridden to propagate to the active representation.
| void vtkSelectionRepresentation::SetLineWidth | ( | double | val | ) |
| void vtkSelectionRepresentation::SetOpacity | ( | double | val | ) |
| void vtkSelectionRepresentation::SetPointSize | ( | double | val | ) |
| void vtkSelectionRepresentation::SetRepresentation | ( | int | val | ) |
| void vtkSelectionRepresentation::SetUseOutline | ( | int | ) |
| void vtkSelectionRepresentation::SetRenderPointsAsSpheres | ( | bool | ) |
| void vtkSelectionRepresentation::SetRenderLinesAsTubes | ( | bool | ) |
overrideprotectedvirtual |
protectedvirtual |
Fires UpdateDataEvent.
Definition at line 146 of file vtkSelectionRepresentation.h.
Definition at line 147 of file vtkSelectionRepresentation.h.
1.8.13 on Sun Dec 14 2025
