Represents a SpyPlot Block Grid. More...
#include <vtkSpyPlotBlock.h>
| struct | BlockStatusType |
| vtkSpyPlotBlock () | |
| ~vtkSpyPlotBlock () | |
| int | SetGeometry (int dir, const unsigned char *encodedInfo, int infoSize) |
| int | GetTotalSize () const |
| int | FixInformation (const vtkBoundingBox &globalBounds, int extents[6], int realExtents[6], int realDims[3], vtkDataArray *ca[3]) |
| void | SetDebug (unsigned char i) |
| unsigned char | GetDebug () const |
| void | SetCoordinateSystem (const int &coordinateSystem) |
| void | ComputeDerivedVariables (vtkCellData *data, const int &numberOfMaterials, vtkDataArray **materialMasses, vtkDataArray **materialVolumeFractions, const int &downConvertVolumeFraction) const |
| double | GetCellVolume (int i, int j, int k) const |
| void | ComputeMaterialDensity (vtkIdType position, vtkDataArray *materialMasses, vtkUnsignedCharArray *materialFraction, vtkDoubleArray *volumes, vtkDoubleArray *materialdensity, double *material_mass, double *material_volume) const |
| void | ComputeMaterialDensity (vtkIdType position, vtkDataArray *materialMasses, vtkFloatArray *materialFraction, vtkDoubleArray *volumes, vtkDoubleArray *materialdensity, double *material_mass, double *material_volume) const |
vtkSpyPlotBlock is a regular hexahedral grid stored in a SpyPlot file. The grid can be part of an Adaptive Mesh Refinement (AMR) dataset or part The class was extracted from vtkSpyPlotUniReader and expanded upon by transisitioning functionality from vtkSpyPlotUniReader and adding it to this class. Note that this helper class is not derived from vtkObject and can be allocated on the static
Definition at line 31 of file vtkSpyPlotBlock.h.
| vtkSpyPlotBlock::vtkSpyPlotBlock | ( | ) |
| vtkSpyPlotBlock::~vtkSpyPlotBlock | ( | ) |
Definition at line 124 of file vtkSpyPlotBlock.h.
Definition at line 129 of file vtkSpyPlotBlock.h.
Definition at line 161 of file vtkSpyPlotBlock.h.
| void vtkSpyPlotBlock::GetBounds | ( | double | bounds[6] | ) | const |
| void vtkSpyPlotBlock::GetSpacing | ( | double | spacing[3] | ) | const |
| void vtkSpyPlotBlock::GetVectors | ( | vtkDataArray * | coordinates[3] | ) | const |
Definition at line 166 of file vtkSpyPlotBlock.h.
Definition at line 173 of file vtkSpyPlotBlock.h.
Definition at line 178 of file vtkSpyPlotBlock.h.
Definition at line 141 of file vtkSpyPlotBlock.h.
Definition at line 151 of file vtkSpyPlotBlock.h.
Definition at line 136 of file vtkSpyPlotBlock.h.
Definition at line 146 of file vtkSpyPlotBlock.h.
Definition at line 156 of file vtkSpyPlotBlock.h.
| void vtkSpyPlotBlock::GetRealBounds | ( | double | realBounds[6] | ) | const |
| int vtkSpyPlotBlock::GetAMRInformation | ( | const vtkBoundingBox & | globalBounds, |
| int * | level, | ||
| double | spacing[3], | ||
| double | origin[3], | ||
| int | extents[6], | ||
| int | realExtents[6], | ||
| int | realDimensions[3] | ||
| ) | const |
| int vtkSpyPlotBlock::Read | ( | int | isAMR, |
| int | fileVersion, | ||
| vtkSpyPlotIStream * | stream | ||
Definition at line 186 of file vtkSpyPlotBlock.h.
| int vtkSpyPlotBlock::FixInformation | ( | const vtkBoundingBox & | globalBounds, |
| int | realDims[3], | ||
| vtkDataArray * | ca[3] | ||
| void vtkSpyPlotBlock::SetDebug | ( | unsigned char | i | ) |
| unsigned char vtkSpyPlotBlock::GetDebug | ( | ) | const |
| void vtkSpyPlotBlock::ComputeDerivedVariables | ( | vtkCellData * | data, |
| const int & | numberOfMaterials, | ||
| vtkDataArray ** | materialMasses, | ||
| vtkDataArray ** | materialVolumeFractions, | ||
| const int & | downConvertVolumeFraction | ||
| ) | const |
Definition at line 92 of file vtkSpyPlotBlock.h.
Definition at line 103 of file vtkSpyPlotBlock.h.
Definition at line 104 of file vtkSpyPlotBlock.h.
Definition at line 105 of file vtkSpyPlotBlock.h.
Definition at line 108 of file vtkSpyPlotBlock.h.
Definition at line 109 of file vtkSpyPlotBlock.h.
Definition at line 110 of file vtkSpyPlotBlock.h.
1.8.13 on Sat Dec 13 2025
