void | Clear (const char *arrayname) |
| Remove the array identified by the arrayname, if any. More...
void | TransferSelectionToInternals (vtkSelection *selection) |
| Append as array the list of selected id and the field type of the current selection. More...
virtual void | SetPartitionType (int) |
| Choose the type for a partition in the output vtkMultiBlockDataSet. More...
virtual int | GetPartitionType () |
virtual void | SetFieldAssociation (int) |
| Indicate the field association to which the specified data arrays are added. More...
virtual int | GetFieldAssociation () |
void | SetSelectionConnection (int index, vtkAlgorithmOutput *algOutput) |
| Convenience method to specify the selection connection (2nd input port). More...
void | SetSelectionConnection (vtkAlgorithmOutput *algOutput) |
void | SetTuple1Double (const char *arrayname, vtkIdType index, double val) |
| Methods to add individual tuples to the data arrays. More...
void | SetTuple1Int (const char *arrayname, vtkIdType index, int val) |
void | SetTuple1IdType (const char *arrayname, vtkIdType index, vtkIdType val) |
void | SetTuple2Double (const char *arrayname, vtkIdType index, double val0, double val1) |
void | SetTuple2Int (const char *arrayname, vtkIdType index, int val0, int val1) |
void | SetTuple2IdType (const char *arrayname, vtkIdType index, vtkIdType val0, vtkIdType val1) |
void | SetTuple3Double (const char *arrayname, vtkIdType index, double val0, double val1, double val2) |
void | SetTuple3Int (const char *arrayname, vtkIdType index, int val0, int val1, int val2) |
void | SetTuple3IdType (const char *arrayname, vtkIdType index, vtkIdType val0, vtkIdType val1, vtkIdType val3) |
vtkDataObjectAlgorithm * | NewInstance () const |
virtual void | SetOutput (vtkDataObject *d) |
virtual int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
int | HasExecutive () |
void | RemoveAllInputs () |
virtual void | Update () |
void | ReleaseDataFlagOn () |
int * | GetUpdateExtent () |
int | GetUpdatePiece () |
virtual void | Modified () |
| vtkSteeringDataGenerator () |
| ~vtkSteeringDataGenerator () override |
int | FillInputPortInformation (int port, vtkInformation *info) override |
int | FillOutputPortInformation (int vtkNotUsed(port), vtkInformation *info) override |
int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
int | RequestData (vtkInformation *vtkNotUsed(request), vtkInformationVector **vtkNotUsed(inputVector), vtkInformationVector *outputVector) override |
virtual vtkObjectBase * | NewInstanceInternal () const |
| vtkDataObjectAlgorithm () |
| ~vtkDataObjectAlgorithm () |
virtual int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | FillOutputPortInformation (int port, vtkInformation *info) |
virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
virtual int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| vtkAlgorithm () |
| ~vtkAlgorithm () |
virtual void | SetNumberOfInputPorts (int n) |
virtual void | SetNumberOfOutputPorts (int n) |
int | InputPortIndexInRange (int index, const char *action) |
int | OutputPortIndexInRange (int index, const char *action) |
int | GetInputArrayAssociation (int idx, vtkInformationVector **inputVector) |
virtual vtkExecutive * | CreateDefaultExecutive () |
void | ReportReferences (vtkGarbageCollector *) VTK_OVERRIDE |
virtual void | SetNumberOfInputConnections (int port, int n) |
int | GetInputArrayAssociation (int idx, int connection, vtkInformationVector **inputVector) |
int | GetInputArrayAssociation (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkDataArray * | GetInputArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input) |
vtkDataArray * | GetInputArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, int connection, vtkInformationVector **inputVector, int &association) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input) |
vtkAbstractArray * | GetInputAbstractArrayToProcess (int idx, vtkDataObject *input, int &association) |
vtkInformation * | GetInputArrayFieldInformation (int idx, vtkInformationVector **inputVector) |
virtual void | SetNthInputConnection (int port, int index, vtkAlgorithmOutput *input) |
void | SetInputDataInternal (int port, vtkDataObject *input) |
void | AddInputDataInternal (int port, vtkDataObject *input) |
virtual void | SetErrorCode (unsigned long) |
| vtkObject () |
virtual | ~vtkObject () |
| vtkObjectBase () |
virtual | ~vtkObjectBase () |
| vtkObjectBase (const vtkObjectBase &) |
source to generate dataset given field arrays
vtkSteeringDataGenerator is simply a dataset generator that generates a single partition vtkMultiBlockDataSet with the 1st partition being non-empty dataset of the type specified using vtkSteeringDataGenerator::SetPartitionType
with arrays added to the field type chosen using vtkSteeringDataGenerator::SetFieldAssociation`.
If the PartitionType is a vtkPointSet subclass, then one can use coords as the field array name to add point coordinates when FieldAssociation is set to vtkDataObject::FIELD_ASSOCIATION_POINTS.
A sample proxy definition that uses this source is as follows:
<ServerManagerConfiguration>
<ProxyGroup name="sources">
<SourceProxy class="vtkSteeringDataGenerator" name="TestSteeringDataGeneratorSource">
<InputProperty command="SetSelectionConnection"
name="Selection"
panel_visibility="default"
port_index="0">
<DataTypeDomain name="input_type">
<DataType value="vtkSelection"/>
</DataTypeDomain>
<Documentation>
The input that provides the selection object.
</Documentation>
<Hints>
<Optional/>
<SelectionInput/>
</Hints>
</InputProperty>
<IntVectorProperty name="PartitionType"
command="SetPartitionType"
number_of_elements="1"
default_values="0"
panel_visibility="never">
</IntVectorProperty>
<IntVectorProperty name="FieldAssociation"
command="SetFieldAssociation"
default_values="0"
panel_visibility="never" />
<DoubleVectorProperty name="Center"
command="SetTuple3Double"
use_index="1"
clean_command="Clear"
initial_string="coords"
number_of_elements_per_command="3"
repeat_command="1" />
<IdTypeVectorProperty name="Id"
command="SetTuple2IdType"
use_index="1"
initial_string="Id"
number_of_elements_per_command="2"
<IntVectorProperty name="Type"
command="SetTuple1Int"
use_index="1"
initial_string="Type"
number_of_elements_per_command="1"
</SourceProxy>
</ProxyGroup>
</ServerManagerConfiguration>
Caveats
This filter should ideally generated vtkPartitionedDataSet
. However, until vtkPartitionedDataSet
is well supported, we are making it generate vtkMultiBlockDataSet.
Definition at line 101 of file vtkSteeringDataGenerator.h.
