vtkAnimationPlayer subclass that plays through a discrete set of time values. More...
#include <vtkTimestepsAnimationPlayer.h>
| typedef vtkAnimationPlayer | Superclass |
Public Types inherited from vtkAnimationPlayer | |
| void | RemoveAllTimeSteps () |
| Remove all timesteps. More... | |
| unsigned int | GetNumberOfTimeSteps () |
| Get number of timesteps. More... | |
| double | GetNextTimeStep (double time) |
| Returns the timestep value after the given timestep. More... | |
| void | AddTimeStep (double time) |
| Add/Remove timesteps. More... | |
| void | RemoveTimeStep (double time) |
| virtual void | SetFramesPerTimestep (unsigned long) |
| Get/Set the number of frames per timstep. More... | |
| virtual unsigned long | GetFramesPerTimestep () |
Public Member Functions inherited from vtkAnimationPlayer | |
| void | Play (int dir=1) |
| Start playing the animation. More... | |
| void | Stop () |
| Stop playing the animation. More... | |
| int | IsInPlay () |
| Returns if the animation is currently playing. More... | |
| virtual bool | GetInPlay () |
| void | GoToNext () |
| Take the animation scene to next frame. More... | |
| void | GoToPrevious () |
| Take animation scene to previous frame. More... | |
| void | GoToFirst () |
| Take animation scene to first frame. More... | |
| void | GoToLast () |
| Take animation scene to last frame. More... | |
| virtual void | SetAnimationScene (vtkSMAnimationScene *) |
| Set the animation scene that is to be played by this player. More... | |
| vtkSMAnimationScene * | GetAnimationScene () |
| virtual void | SetLoop (bool) |
| Set to true to play the animation in a loop. More... | |
| virtual bool | GetLoop () |
| virtual int | GetStride () |
| Get/Set the stride value fot the animation player. More... | |
| virtual void | SetStride (int) |
| static vtkTimestepsAnimationPlayer * | New () |
| static vtkTimestepsAnimationPlayer * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkAnimationPlayer | |
| static vtkAnimationPlayer * | SafeDownCast (vtkObject *o) |
| double | GoToNext (double, double, double currenttime) override |
| Return next/previous time knowing start, end and current. More... | |
| double | GoToPrevious (double, double, double currenttime) override |
| void | StartLoop (double, double, double, double *playbackWindow) override |
| Manage loop inside playbackwindow. More... | |
| void | EndLoop () override |
| double | GetNextTime (double currentime) override |
| double | GetPreviousTime (double currenttime) override |
Protected Member Functions inherited from vtkAnimationPlayer | |
| vtkAnimationPlayer () | |
| ~vtkAnimationPlayer () override | |
Protected Attributes | |
| double | PlaybackWindow [2] |
| unsigned long | FramesPerTimestep |
| unsigned long | Count |
| double | GetPreviousTimeStep (double time) |
| Returns the timestep value before the given timestep. More... | |
| vtkTimestepsAnimationPlayer () | |
| ~vtkTimestepsAnimationPlayer () override | |
Player to play an animation scene through a discrete set of time values. FramesPerTimestep controls how many frames are generated for each time value.
Definition at line 20 of file vtkTimestepsAnimationPlayer.h.
Definition at line 24 of file vtkTimestepsAnimationPlayer.h.
If no value exists, returns the argument time itself.
Reimplemented from vtkAnimationPlayer.
| void vtkTimestepsAnimationPlayer::AddTimeStep | ( | double | time | ) |
| void vtkTimestepsAnimationPlayer::RemoveTimeStep | ( | double | time | ) |
| void vtkTimestepsAnimationPlayer::RemoveAllTimeSteps | ( | ) |
| unsigned int vtkTimestepsAnimationPlayer::GetNumberOfTimeSteps | ( | ) |
overrideprotectedvirtual |
Implements vtkAnimationPlayer.
inlineoverrideprotectedvirtual |
Definition at line 77 of file vtkTimestepsAnimationPlayer.h.
Definition at line 84 of file vtkTimestepsAnimationPlayer.h.
Definition at line 89 of file vtkTimestepsAnimationPlayer.h.
Definition at line 94 of file vtkTimestepsAnimationPlayer.h.
Definition at line 95 of file vtkTimestepsAnimationPlayer.h.
Definition at line 96 of file vtkTimestepsAnimationPlayer.h.
1.8.13 on Sun Dec 14 2025
