Image compressor/decompressor using Zlib. More...
#include <vtkZlibImageCompressor.h>
| typedef vtkImageCompressor | Superclass |
Public Types inherited from vtkImageCompressor | |
| const char * | SaveConfiguration () override |
| Serialize compressor configuration (but not the data) into the stream. More... | |
| const char * | RestoreConfiguration (const char *stream) override |
| Restore state from the stream, The stream format for all image compressor is: [ClassName, LossLessMode, [Derived Class Stream]]. More... | |
| void | SetLossLessMode (int mode) override |
| When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More... | |
| int | Compress () override |
| Compress/Decompress data array on the objects input with results in the objects output. More... | |
| int | Decompress () override |
| void | SaveConfiguration (vtkMultiProcessStream *stream) override |
| Serialize/Restore compressor configuration (but not the data) into the stream. More... | |
| bool | RestoreConfiguration (vtkMultiProcessStream *stream) override |
| virtual void | SetCompressionLevel (int) |
| Set compression level. More... | |
| virtual int | GetCompressionLevel () |
| void | SetColorSpace (int csId) |
| Set to an integer between 0 and 5. More... | |
| int | GetColorSpace () |
| void | SetStripAlpha (int status) |
| Set to boolean value indicating whether alpha values should be stripped prior to compression. More... | |
| int | GetStripAlpha () |
Public Member Functions inherited from vtkImageCompressor | |
| virtual void | SetImageResolution (int width, int height) |
| Communicates the next expected image resolution. More... | |
| void | SetInput (vtkUnsignedCharArray *input) |
| Get/Set the input to this compressor. More... | |
| virtual vtkUnsignedCharArray * | GetInput () |
| virtual vtkUnsignedCharArray * | GetOutput () |
| Get/Set the output of the compressor. More... | |
| void | SetOutput (vtkUnsignedCharArray *) |
| virtual int | GetLossLessMode () |
| static vtkZlibImageCompressor * | New () |
| static vtkZlibImageCompressor * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkImageCompressor | |
| static vtkImageCompressor * | SafeDownCast (vtkObject *o) |
| vtkZlibImageCompressor () | |
| ~vtkZlibImageCompressor () override | |
Protected Member Functions inherited from vtkImageCompressor | |
| virtual void | SetConfiguration (const char *) |
| vtkImageCompressor () | |
| Construct with nullptr input array and empty but allocated output array. More... | |
| ~vtkImageCompressor () override | |
Protected Attributes inherited from vtkImageCompressor | |
| vtkUnsignedCharArray * | Output |
| vtkUnsignedCharArray * | Input |
| int | LossLessMode |
| char * | Configuration |
This class compresses Image data using Zlib. The compression level varies between 1 and 9, 1 being the fastest at the cost of the compression ratio, 9 producing the highest compression ratio at the cost of speed. Optionally color depth may be reduced and alpha stripped/restored.
Definition at line 27 of file vtkZlibImageCompressor.h.
Definition at line 31 of file vtkZlibImageCompressor.h.
Reimplemented from vtkImageCompressor.
See also Set/GetInput/Output.
Implements vtkImageCompressor.
A pointer to the internally managed stream is returned (ie do not free it!).
Upon success the stream is returned otherwise 0 is returned indicating an error.
A setting of 1 is the fastest producing the smallest compression ratio while a setting of 9 is the slowest producing the highest compression ratio. Zlib is loss-less regardless of level however, setting SetColorSpaceReduction factor to a non zero value will cause internal pre-processor to reduce the color space prior to compression which can improve compression ratio realized.
| void vtkZlibImageCompressor::SetColorSpace | ( | int | csId | ) |
This uses the same color space reduction as the squirt compressor. If set to 0 no colorspace reduction is performed.
| int vtkZlibImageCompressor::GetColorSpace | ( | ) |
| void vtkZlibImageCompressor::SetStripAlpha | ( | int | status | ) |
Stripping alpha values will reduce input to compressor by 1/4 and results in speed up in compressor run time and of course reduced image size. Stripped alpha value are reinstated to 0xff during decompress.
| int vtkZlibImageCompressor::GetStripAlpha | ( | ) |
1.8.13 on Sat Dec 13 2025
