#include "vtkPVAdaptorsCamModule.h"
| void VTKPVADAPTORSCAM_EXPORT | fv_coprocessorinitializewithpython_ (const char *pythonScriptName) |
| Initializes the Catalyst Coprocessor. More... | |
| void VTKPVADAPTORSCAM_EXPORT | fv_create_grid_ (int *dim, double *lonCoord, double *latCoord, double *levCoord, int *nCells2d, int *maxNcols, int *myRank) |
| Creates the Grids for 2D, 3D rectilinear and 2D, 3D spherical. More... | |
| void VTKPVADAPTORSCAM_EXPORT | fv_add_chunk_ (int *nstep, int *chunkSize, double *lonRad, double *latRad, double *psScalar, double *tScalar, double *uScalar, double *vScalar) |
| for timestep 0: creates the points and cells for the grids. More... | |
| void VTKPVADAPTORSCAM_EXPORT | fv_catalyst_finalize_ () |
| int VTKPVADAPTORSCAM_EXPORT | fv_requestdatadescription_ (int *timeStep, double *time) |
| Checks if Catalyst needs to coprocess data. More... | |
| int VTKPVADAPTORSCAM_EXPORT | fv_needtocreategrid_ () |
| Checks if the grids need to be created. More... | |
| void VTKPVADAPTORSCAM_EXPORT | fv_coprocess_ () |
| Calls the coprocessor. More... | |
| void VTKPVADAPTORSCAM_EXPORT fv_coprocessorinitializewithpython_ | ( | const char * | pythonScriptName | ) |
| void VTKPVADAPTORSCAM_EXPORT fv_create_grid_ | ( | int * | dim, |
| double * | lonCoord, | ||
| double * | latCoord, | ||
| double * | levCoord, | ||
| int * | nCells2d, | ||
| int * | maxNcols, | ||
| int * | myRank | ||
| void VTKPVADAPTORSCAM_EXPORT fv_add_chunk_ | ( | int * | nstep, |
| int * | chunkSize, | ||
| double * | lonRad, | ||
| double * | latRad, | ||
| double * | psScalar, | ||
| double * | tScalar, | ||
| double * | uScalar, | ||
| double * | vScalar | ||
for all timesteps: copies data from the simulation to Catalyst.
| void VTKPVADAPTORSCAM_EXPORT fv_catalyst_finalize_ | ( | ) |
| int VTKPVADAPTORSCAM_EXPORT fv_requestdatadescription_ | ( | int * | timeStep, |
| double * | time | ||
| int VTKPVADAPTORSCAM_EXPORT fv_needtocreategrid_ | ( | ) |
| void VTKPVADAPTORSCAM_EXPORT fv_coprocess_ | ( | ) |
1.8.13 on Sun Dec 14 2025
