Behaviors are classes that manage certain behaviors in the application. More...
class | pqAlwaysConnectedBehavior |
pqAlwaysConnectedBehavior ensures that the client always remains connected to a server. More... | |
class | pqApplyBehavior |
pqApplyBehavior collects the logic that needs to happen after the user hits "Apply" on the pqPropertiesPanel. More... | |
class | pqAutoLoadPluginXMLBehavior |
ParaView plugins can load gui configuration xmls eg. More... | |
class | pqAutoSaveBehavior |
: pqAutoSaveBehavior save states automatically in the background. More... | |
class | pqCategoryToolbarsBehavior |
pqCategoryToolbarsBehavior is used when the application wants to enable categories from a pqProxyGroupMenuManager to show up in a toolbar. More... | |
class | pqCollaborationBehavior |
pqCollaborationBehavior ensures that a pqCollaborationManager get set when a new pqServer that support collaboration has been created. More... | |
class | pqCommandLineOptionsBehavior |
pqCommandLineOptionsBehavior processes command-line options on startup and performs relevant actions such as loading data files, connecting to server etc. More... | |
class | pqCrashRecoveryBehavior |
pqCrashRecoveryBehavior manages saving/loading of crash recovery state. More... | |
class | pqCustomShortcutBehavior |
pqCustomShortcutBehavior TODO More... | |
class | pqDataTimeStepBehavior |
pqDataTimeStepBehavior ensures that whenever a file is opened with more than 1 timestep, the application time >= the time for the last timestep. More... | |
class | pqDefaultViewBehavior |
pqDefaultViewBehavior ensures that when a new server connection is made, the default view of the user-specified type is automatically created. More... | |
class | pqLockPanelsBehavior |
Central location for controlling whether dock widgets are locked down or movable. More... | |
class | pqModelTransformSupportBehavior |
pqModelTransformSupportBehavior is designed for supporting ChangeOfBasis matrix for MantId. More... | |
class | pqObjectPickingBehavior |
pqObjectPickingBehavior is used to add support for picking "source" by clicking on it in a view. More... | |
class | pqPersistentMainWindowStateBehavior |
pqPersistentMainWindowStateBehavior saves and restores the MainWindow state on shutdown and restart. More... | |
class | pqPipelineContextMenuBehavior |
This behavior manages showing up of a context menu with sensible pipeline related actions for changing color/visibility etc. More... | |
class | pqPluginActionGroupBehavior |
pqPluginActionGroupBehavior adds support for loading menus/toolbars from plugins. More... | |
class | pqPluginDockWidgetsBehavior |
pqPluginDockWidgetsBehavior adds support for loading dock widgets from plugins. More... | |
class | pqPluginDocumentationBehavior |
pqPluginDocumentationBehavior is a helper class that ensures that documentation from plugins is registered with the QHelpEngine. More... | |
class | pqPluginPathBehavior |
Applications may want to support auto-loading of plugins from certain locations when a client-server connection is made. More... | |
class | pqPluginSettingsBehavior |
pqPluginSettingsBehavior adds support for adding application settings from plugins More... | |
class | pqSpreadSheetVisibilityBehavior |
Whenever spreadsheet view is created, ParaView wants to ensure that the active source is automatically displayed in that view. More... | |
class | pqUndoRedoBehavior |
pqUndoRedoBehavior enables application wide undo-redo. More... | |
class | pqVerifyRequiredPluginBehavior |
ParaView plugins can be loaded on the client or server before a connection is made. More... | |
class | pqViewStreamingBehavior |
pqViewStreamingBehavior is used to manage rendering of render-view when streaming is enabled. More... | |
class | pqLiveSourceBehavior |
pqLiveSourceBehavior adds support for generated "live" sources algorithms. More... | |
class | pqParaViewBehaviors |
creates all standard ParaView behaviourspqParaViewBehaviors creates all the behaviors used by ParaView. More... | |
class | pqPluginToolBarBehavior |
Behavior that monitors loaded plugins to handle any implementations of pqToolBarInterface. More... | |
class | pqUsageLoggingBehavior |
behavior to log usage on application startup. More... | |
Developers should simply instantiate behaviors if the expect that behavior in their client.
