: pqAutoSaveBehavior save states automatically in the background. More...
#include <pqAutoSaveBehavior.h>
Inherits QObject.
Public Slots | |
| static void | saveState () |
| Saves the state. More... | |
| static QDir | getStateDirectory () |
| Return the directory where to write the state. More... | |
| static bool | autoSaveSettingEnabled () |
| Return true if the AutoSave settings is enabled. More... | |
| static void | setAutoSaveSetting (bool enable) |
| Set the AutoSave Setting to "enable". More... | |
| static pqApplicationCore::StateFileFormat | getStateFormat () |
| Return the file format for the statefile, as defined in the settings. More... | |
| pqAutoSaveBehavior (QObject *parent=nullptr) | |
| ~pqAutoSaveBehavior () override | |
On every significant change, as a pipeline update or a rendering, it writes a new statefile and backup the previous one. The target directory can be defined in the settings. By default, the standard platform-dependent AppData directory is used. See pqCoreUtilities::getParaViewApplicationDataDirectory().
The file format can be chosen with the AutoSaveStateFormat setting.
The features can be (de)activated through the AutoSave setting.
Definition at line 29 of file pqAutoSaveBehavior.h.
| pqAutoSaveBehavior::pqAutoSaveBehavior | ( | QObject * | parent = nullptr | ) |
staticslot |
Saves the state.
First make a copy of the previous state as a .bak file.
Uses format and directory from settings. Default to pvsm and pqCoreUtilities::getParaViewApplicationDataDirectory()
staticslot |
Uses user-defined directory (from settings) or standard one if empty. See pqCoreUtilities::getParaViewApplicationDataDirectory()
staticslot |
staticslot |
staticslot |
Default to StateFormat::PVSM.
1.8.13 on Sun Dec 14 2025
