4 #ifndef pqPropertyLinks_h 5 #define pqPropertyLinks_h 41 typedef QObject Superclass;
64 bool addPropertyLink(QObject* qobject,
const char* qproperty,
const char* qsignal,
70 bool addTraceablePropertyLink(QObject* qobject,
76 template <
class ConnectionType>
77 bool addPropertyLink(QObject* qobject,
79 ConnectionType* notused =
nullptr);
86 template <
87 bool addTraceablePropertyLink(QObject* qobject,
89 ConnectionType* notused =
nullptr);
94 bool removePropertyLink(QObject* qobject,
103 int getNumberOfPropertyLinks()
const;
135 void setUseUncheckedProperties(
bool val);
143 void qtWidgetChanged();
144 void smPropertyChanged();
151 void onQtPropertyModified();
152 void onSMPropertyModified();
157 template <
158 ConnectionType* addPropertyLinkInternal(QObject* qobject,
164 pqInternals* Internals;
165 bool UseUncheckedProperties;
166 bool AutoUpdateVTKObjects;
170 template <
171 ConnectionType* pqPropertyLinks::addPropertyLinkInternal(QObject* qobject,
174 if (!qobject || !qproperty || !qsignal || !smproxy || !smproperty)
176 qCritical() <<
"Invalid parameters to pqPropertyLinks::addPropertyLinkInternal";
177 qDebug() <<
"(" << qobject <<
", " << qproperty <<
", " << qsignal <<
") <==> (" 178 << (smproxy ? smproxy->
GetXMLName() :
"(none)") <<
"," 179 << (smproperty ? smproperty->
GetXMLLabel() :
"(none)") << smindex <<
183 ConnectionType* connection =
new ConnectionType(qobject, qproperty, qsignal, smproxy, smproperty,
184 smindex, this->useUncheckedProperties(),
this);
185 this->addNewConnection(connection);
191 template <
195 auto connection = this->addPropertyLinkInternal<ConnectionType>(
196 qobject, qproperty, qsignal, smproxy, smproperty, smindex);
197 return connection !=
nullptr;
201 template <
205 auto connection = this->addPropertyLinkInternal<ConnectionType>(
206 qobject, qproperty, qsignal, smproxy, smproperty, smindex);
209 connection->setTraceChanges(
true);
bool useUncheckedProperties() const
bool addTraceablePropertyLink(QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1)
Like addPropertyLink, but also sets up properties to be Python traceable.
virtual char * GetXMLLabel()
The label assigned by the xml parser.
pqPropertyLinks is used to connect vtkSMProperty and subclasses to properties on QObject instances...
bool autoUpdateVTKObjects() const
void setAutoUpdateVTKObjects(bool val)
set whether UpdateVTKObjects is called automatically when needed
void removeAllPropertyLinks()
Remove all links.
pqPropertyLinksConnection is used by pqPropertyLinks to keep a QObject and vtkSMProperty linked toget...
bool addPropertyLink(QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1)
Setup a link between a Qt property and vtkSMProperty on a vtkSMProxy instance.
virtual char * GetXMLName()
Assigned by the XML parser.
