#include <pqPythonEditorActions.h>
| enum | GeneralActionType : std::uint8_t { GeneralActionType::NewFile, GeneralActionType::OpenFile, GeneralActionType::SaveFile, GeneralActionType::SaveFileAs, GeneralActionType::SaveFileAsMacro, GeneralActionType::SaveFileAsScript, GeneralActionType::DeleteAll, GeneralActionType::Undo, GeneralActionType::Redo, GeneralActionType::Copy, GeneralActionType::Cut, GeneralActionType::Paste, GeneralActionType::CloseCurrentTab, GeneralActionType::Exit, GeneralActionType::Run, GeneralActionType::END } |
| General editor actions. More... | |
| enum | ScriptActionType : std::uint8_t { ScriptActionType::Open, ScriptActionType::Load, ScriptActionType::Delete, ScriptActionType::Run, ScriptActionType::END } |
| Specialized actions for the scripting part of the editor. More... | |
| using | TGeneralAction = EditorActionGroup< GeneralActionType > |
| using | ScriptAction = EditorActionGroup< ScriptActionType > |
| pqPythonEditorActions () | |
| Default constructor initialize the tooltip and text of the various actions. More... | |
| const QAction & | operator[] (const GeneralActionType action) const |
| const accessor to an action More... | |
| QAction & | operator[] (const GeneralActionType action) |
| void | updateScriptsList (pqPythonManager *python_mgr) |
| Updates the list of actions by listing the files contained into the default Script dir. More... | |
| void | FillQMenu (EnumArray< ScriptAction::Type, QMenu *> menus) |
| Fill the input menus with the current actions listed by this object. More... | |
| template<class T > | |
| static void | connect (pqPythonEditorActions &, T *) |
| Connects the pqPythonEditorActions to the type T. More... | |
| static void | disconnect (pqPythonEditorActions &, T *) |
| Disconnects the pqPythonEditorActions to the type T. More... | |
Public Attributes | |
| TGeneralAction | GeneralActions |
| The list of general actions. More... | |
| std::vector< ScriptAction > | ScriptActions |
| The variable sized array of script actions. More... | |
Definition at line 73 of file pqPythonEditorActions.h.
Definition at line 127 of file pqPythonEditorActions.h.
Definition at line 134 of file pqPythonEditorActions.h.
strong |
| Enumerator | |
| NewFile | |
| OpenFile | |
| SaveFile | |
| SaveFileAs | |
| SaveFileAsMacro | |
| SaveFileAsScript | |
| DeleteAll | |
| Undo | |
| Redo | |
| Copy | |
| Cut | |
| Paste | |
| CloseCurrentTab | |
| Exit | |
| Run | |
| END | |
Definition at line 85 of file pqPythonEditorActions.h.
strong |
| Enumerator | |
| Open | |
| Load | |
| Delete | |
| Run | |
| END | |
Definition at line 117 of file pqPythonEditorActions.h.
| pqPythonEditorActions::pqPythonEditorActions | ( | ) |
Definition at line 144 of file pqPythonEditorActions.h.
Definition at line 152 of file pqPythonEditorActions.h.
| void pqPythonEditorActions::updateScriptsList | ( | pqPythonManager * | python_mgr | ) |
| python_mgr | instance of the python manager |
| void pqPythonEditorActions::FillQMenu | ( | EnumArray< ScriptAction::Type, QMenu *> | menus | ) |
| TGeneralAction pqPythonEditorActions::GeneralActions |
Definition at line 132 of file pqPythonEditorActions.h.
| std::vector<ScriptAction> pqPythonEditorActions::ScriptActions |
Definition at line 139 of file pqPythonEditorActions.h.
1.8.13 on Sat Dec 13 2025
