21 #ifndef vtkPEnSightReader_h 22 #define vtkPEnSightReader_h 41 class vtkPEnSightReaderCellIdsType;
43 #define NEXTMODULO3(x) (x == 0) ? 1 : ((x == 1) ? 2 : 0) 66 , cellLocalNumberOfIds(-1)
68 , ImplicitDimensions(nullptr)
69 , ImplicitLocalDimensions(nullptr)
70 , ImplicitSplitDimension(-1)
71 , ImplicitSplitDimensionBeginIndex(-1)
72 , ImplicitSplitDimensionEndIndex(-1)
80 , cellLocalNumberOfIds(-1)
82 , ImplicitDimensions(nullptr)
83 , ImplicitLocalDimensions(nullptr)
84 , ImplicitSplitDimension(-1)
85 , ImplicitSplitDimensionBeginIndex(-1)
86 , ImplicitSplitDimensionEndIndex(-1)
91 this->cellMap =
new IntIntMap;
92 this->cellNumberOfIds = 0;
93 this->cellVector =
nullptr;
97 this->ImplicitDimensions =
new int[3];
98 this->ImplicitSplitDimension = -1;
99 this->ImplicitSplitDimensionBeginIndex = -1;
100 this->ImplicitSplitDimensionEndIndex = -1;
104 this->cellMap =
nullptr;
105 this->cellVector =
new IntVector;
106 this->cellNumberOfIds = -1;
107 this->cellLocalNumberOfIds = -1;
113 delete this->cellMap;
114 delete this->cellVector;
115 delete[] this->ImplicitDimensions;
123 this->cellMap =
new IntIntMap;
124 this->cellNumberOfIds = 0;
125 this->cellVector =
nullptr;
129 this->ImplicitDimensions =
new int[3];
130 this->ImplicitSplitDimension = -1;
131 this->ImplicitSplitDimensionBeginIndex = -1;
132 this->ImplicitSplitDimensionEndIndex = -1;
136 this->cellMap =
nullptr;
137 this->cellVector =
new IntVector;
138 this->cellNumberOfIds = -1;
139 this->cellLocalNumberOfIds = -1;
145 this->ImplicitDimensions[0] = dim1;
146 this->ImplicitDimensions[1] = dim2;
147 this->ImplicitDimensions[2] = dim3;
154 this->ImplicitSplitDimensionBeginIndex = begin;
172 if (this->ImplicitSplitDimension == -1)
178 index[2] =
id / (this->ImplicitDimensions[0] * this->ImplicitDimensions[1]);
179 index[1] = (
id - (index[2] * this->ImplicitDimensions[0] * this->ImplicitDimensions[1])) /
180 this->ImplicitDimensions[0];
181 index[0] =
id - index[1] * this->ImplicitDimensions[0] -
182 index[2] * this->ImplicitDimensions[1] * this->ImplicitDimensions[0];
183 if ((index[this->ImplicitSplitDimension] < this->ImplicitSplitDimensionBeginIndex) ||
184 (index[this->ImplicitSplitDimension] >= this->ImplicitSplitDimensionEndIndex))
194 int dim = this->ImplicitSplitDimension;
195 localIndex[dim] = index[dim] - this->ImplicitSplitDimensionBeginIndex;
197 this->ImplicitSplitDimensionEndIndex - this->ImplicitSplitDimensionBeginIndex;
199 localIndex[dim] = index[dim];
200 localDim[dim] = this->ImplicitDimensions[dim];
202 localDim[dim] = this->ImplicitDimensions[dim];
203 localIndex[dim] = index[dim];
204 return localIndex[0] + localDim[0] * localIndex[1] +
205 localDim[0] * localDim[1] * localIndex[2];
210 std::map<int, int>::iterator it = this->cellMap->find(
id);
211 if (it == this->cellMap->end())
214 return (*this->cellMap)[id];
219 if (this->cellVector->size() > (
unsigned int)(
id))
220 return (*this->cellVector)[id];
240 std::map<int, int>::iterator it = this->cellMap->find(
id);
241 if (it == this->cellMap->end())
242 this->cellNumberOfIds++;
244 (*this->cellMap)[
id] = value;
249 if (this->cellVector->size() < (
unsigned int)(
id + 1))
252 int currentSize =
static_cast<int>(this->cellVector->size());
253 this->cellVector->resize(
id + 1);
254 for (k = currentSize; k < id; k++)
256 (*this->cellVector)[k] = -1;
258 (*this->cellVector)[
id] = value;
262 (*this->cellVector)[
id] = value;
285 (*this->cellMap)[this->cellNumberOfIds] =
id;
288 this->cellNumberOfIds++;
289 return this->cellNumberOfIds - 1;
294 this->cellVector->push_back(
id);
295 return static_cast<int>(this->cellVector->size() - 1);
299 return static_cast<int>(this->cellVector->size() - 1);
309 return this->cellNumberOfIds;
314 return this->cellNumberOfIds;
318 return this->cellNumberOfIds;
332 if (this->cellNumberOfIds >= 0)
334 return this->cellNumberOfIds;
337 return static_cast<int>(this->cellVector->size());
350 this->cellNumberOfIds = n;
364 this->cellLocalNumberOfIds = n;
372 this->cellMap->clear();
373 this->cellNumberOfIds = 0;
378 this->cellVector->clear();
379 if (this->cellNumberOfIds >= 0)
380 this->cellNumberOfIds = -1;
381 if (this->cellLocalNumberOfIds >= 0)
382 this->cellLocalNumberOfIds = -1;
393 return this->cellNumberOfIds;
398 return this->cellLocalNumberOfIds;
402 return static_cast<int>(this->cellMap->size());
412 if (this->cellLocalNumberOfIds >= 0)
414 return this->cellLocalNumberOfIds;
419 for (
unsigned int i = 0; i < this->cellVector->size(); i++)
421 if ((*this->cellVector)[i] != -1)
465 NUMBER_OF_ELEMENT_TYPES = 17
472 TENSOR_SYMM_PER_NODE = 2,
473 SCALAR_PER_ELEMENT = 3,
474 VECTOR_PER_ELEMENT = 4,
475 TENSOR_SYMM_PER_ELEMENT = 5,
476 SCALAR_PER_MEASURED_NODE = 6,
477 VECTOR_PER_MEASURED_NODE = 7,
478 COMPLEX_SCALAR_PER_NODE = 8,
479 COMPLEX_VECTOR_PER_NODE = 9,
480 COMPLEX_SCALAR_PER_ELEMENT = 10,
481 COMPLEX_VECTOR_PER_ELEMENT = 11
496 vtkGetStringMacro(MeasuredFileName);
504 vtkGetStringMacro(MatchFileName);
524 vtkSetStringMacro(MeasuredFileName);
531 vtkSetStringMacro(MatchFileName);
539 int ReadCaseFileGeometry(
char* line);
540 int ReadCaseFileVariable(
char* line);
541 int ReadCaseFileTime(
char* line);
542 int ReadCaseFileFile(
char* line);
551 virtual int ReadGeometryFile(
558 virtual int ReadMeasuredGeometryFile(
570 virtual int ReadScalarsPerNode(
const char* fileName,
const char* description,
int timeStep,
572 int component = 0) = 0;
578 virtual int ReadVectorsPerNode(
int timeStep,
585 virtual int ReadTensorsPerNode(
592 virtual int ReadScalarsPerElement(
int timeStep,
599 virtual int ReadVectorsPerElement(
606 virtual int ReadTensorsPerElement(
613 virtual int CreateUnstructuredGridOutput(
620 virtual int CreateStructuredGridOutput(
626 void AddVariableFileName(
const char* fileName1,
const char* fileName2 =
nullptr);
631 void AddVariableDescription(
const char* description);
636 void AddVariableType();
642 int GetElementType(
const char* line);
648 int GetSectionType(
const char* line);
653 void ReplaceWildcards(
char* filename,
int num);
658 void RemoveLeadingBlanks(
char* line);
670 vtkIdType GetTotalNumberOfCellIds(
int index);
671 vtkIdType GetLocalTotalNumberOfCellIds(
int index);
705 const std::vector<vtkIdType>& faces = {});
706 void InsertVariableComponent(
vtkFloatArray* array,
int i,
int component,
float* content,
707 int partId,
int ensightCellType,
int insertionType);
722 void PrepareStructuredDimensionsForDistribution(
int partId,
int* oldDimensions,
723 int* newDimensions,
int* splitDimension,
int* splitDimensionBeginIndex,
int ghostLevel,
783 vtkSetMacro(UseTimeSets,
int);
784 vtkGetMacro(UseTimeSets,
int);
785 vtkBooleanMacro(UseTimeSets,
int);
788 vtkSetMacro(UseFileSets,
int);
789 vtkGetMacro(UseFileSets,
int);
790 vtkBooleanMacro(UseFileSets,
int);
800 int CheckOutputConsistency();
void SetMode(EnsightReaderCellIdMode amode)
std::vector< int > IntVector
vtkPEnSightReaderCellIds(EnsightReaderCellIdMode amode)
void SetImplicitSplitDimensionEndIndex(int end)
vtkIdList * VariableTimeSetIds
EnsightReaderCellIdMode mode
Superclass for EnSight file parallel readers.
vtkIdList * TimeSetsWithFilenameNumbers
vtkIdList * ComplexVariableFileSetIds
int NumberOfGeometryParts
std::map< int, int > IntIntMap
int ImplicitSplitDimensionBeginIndex
void SetImplicitSplitDimensionBeginIndex(int begin)
char ** ComplexVariableFileNames
vtkIdList * UnstructuredPartIds
class to read any type of EnSight files
vtkPEnSightReaderCellIdsType * CellIds
void SetImplicitSplitDimension(int dim)
void SetLocalNumberOfIds(int n)
vtkIdList * VariableFileSetIds
int GetLocalNumberOfIds()
int * ImplicitLocalDimensions
bool InjectGlobalElementIds
vtkPEnSightReaderCellIds()
vtkIdListCollection * FileSetFileNameNumbers
int ImplicitSplitDimensionEndIndex
void SetImplicitDimensions(int dim1, int dim2, int dim3)
~vtkPEnSightReaderCellIds()
char ** VariableFileNames
void SetId(int id, int value)
vtkIdListCollection * TimeSetFileNameNumbers
vtkIdList * ComplexVariableTimeSetIds
void SetNumberOfIds(int n)
vtkIdListCollection * FileSetNumberOfSteps
#define VTKPVVTKEXTENSIONSIOENSIGHT_EXPORT
vtkIdList * StructuredPartIds
std::map< std::string, std::map< int, long > > FileOffsets
int NumberOfMeasuredPoints
vtkPEnSightReaderCellIdsType * PointIds
vtkIdList * FileSetsWithFilenameNumbers
