| #define | VTK_MODULE_USE_EXTERNAL_VTK_fmt 0 |
| When using 'fmt' in VTK, this header enables use to use either the fmt version provided by VTK or an externally built version based on compile time flags. More... | |
| #define | VTK_FMT(header) <vtkfmt/vtk##header> |
| #define VTK_MODULE_USE_EXTERNAL_VTK_fmt 0 |
When using 'fmt' include this header and then include any fmt header you need as follows:
Note the clang-format sentinels are need avoid incorrect formatting the VTK_FMT macro call when using clang-format to format the code.
1.8.13 on Sun Dec 14 2025
