#include <libxml/xmlexports.h>
| #define | LIBXML_DOTTED_VERSION "2.13.5" |
| LIBXML_DOTTED_VERSION: More... | |
| #define | LIBXML_VERSION 21305 |
| LIBXML_VERSION: More... | |
| #define | LIBXML_VERSION_STRING "21305" |
| LIBXML_VERSION_STRING: More... | |
| #define | LIBXML_VERSION_EXTRA "" |
| LIBXML_VERSION_EXTRA: More... | |
| #define | LIBXML_TEST_VERSION xmlCheckVersion(21305); |
| LIBXML_TEST_VERSION: More... | |
| #define | LIBXML_THREAD_ENABLED |
| LIBXML_THREAD_ENABLED: More... | |
| #define | LIBXML_THREAD_ALLOC_ENABLED |
| LIBXML_THREAD_ALLOC_ENABLED: More... | |
| #define | LIBXML_TREE_ENABLED |
| LIBXML_TREE_ENABLED: More... | |
| #define | LIBXML_OUTPUT_ENABLED |
| LIBXML_OUTPUT_ENABLED: More... | |
| #define | LIBXML_PUSH_ENABLED |
| LIBXML_PUSH_ENABLED: More... | |
| #define | LIBXML_READER_ENABLED |
| LIBXML_READER_ENABLED: More... | |
| #define | LIBXML_PATTERN_ENABLED |
| LIBXML_PATTERN_ENABLED: More... | |
| #define | LIBXML_WRITER_ENABLED |
| LIBXML_WRITER_ENABLED: More... | |
| #define | LIBXML_SAX1_ENABLED |
| LIBXML_SAX1_ENABLED: More... | |
| #define | LIBXML_VALID_ENABLED |
| LIBXML_FTP_ENABLED: More... | |
| #define | LIBXML_HTML_ENABLED |
| LIBXML_HTML_ENABLED: More... | |
| #define | LIBXML_C14N_ENABLED |
| LIBXML_LEGACY_ENABLED: More... | |
| #define | LIBXML_CATALOG_ENABLED |
| LIBXML_CATALOG_ENABLED: More... | |
| #define | LIBXML_XPATH_ENABLED |
| LIBXML_XPATH_ENABLED: More... | |
| #define | LIBXML_XPTR_ENABLED |
| LIBXML_XPTR_ENABLED: More... | |
| #define | LIBXML_XINCLUDE_ENABLED |
| LIBXML_XPTR_LOCS_ENABLED: More... | |
| #define | LIBXML_ISO8859X_ENABLED |
| LIBXML_ICONV_ENABLED: More... | |
| #define | LIBXML_UNICODE_ENABLED |
| LIBXML_DEBUG_ENABLED: More... | |
| #define | LIBXML_REGEXP_ENABLED |
| LIBXML_REGEXP_ENABLED: More... | |
| #define | LIBXML_AUTOMATA_ENABLED |
| LIBXML_AUTOMATA_ENABLED: More... | |
| #define | LIBXML_SCHEMAS_ENABLED |
| LIBXML_SCHEMAS_ENABLED: More... | |
| #define | LIBXML_SCHEMATRON_ENABLED |
| LIBXML_SCHEMATRON_ENABLED: More... | |
| #define | LIBXML_MODULES_ENABLED |
| LIBXML_MODULES_ENABLED: More... | |
| #define | LIBXML_MODULE_EXTENSION ".so" |
| LIBXML_MODULE_EXTENSION: More... | |
| #define | LIBXML_ZLIB_ENABLED |
| LIBXML_ZLIB_ENABLED: More... | |
| #define LIBXML_DOTTED_VERSION "2.13.5" |
| #define LIBXML_VERSION 21305 |
LIBXML_VERSION:
the version number: 1.2.3 value is 10203
Definition at line 25 of file xmlversion.h.
| #define LIBXML_VERSION_STRING "21305" |
the version number string, 1.2.3 value is "10203"
Definition at line 32 of file xmlversion.h.
| #define LIBXML_VERSION_EXTRA "" |
extra version information, used to show a git commit description
Definition at line 39 of file xmlversion.h.
| #define LIBXML_TEST_VERSION xmlCheckVersion(21305); |
Macro to check that the libxml version in use is compatible with the version the software has been compiled against
Definition at line 47 of file xmlversion.h.
| #define LIBXML_THREAD_ENABLED |
Whether the thread support is configured in
Definition at line 55 of file xmlversion.h.
| #define LIBXML_THREAD_ALLOC_ENABLED |
Whether the allocation hooks are per-thread
Definition at line 64 of file xmlversion.h.
| #define LIBXML_TREE_ENABLED |
Whether the DOM like tree manipulation API support is configured in
Definition at line 73 of file xmlversion.h.
| #define LIBXML_OUTPUT_ENABLED |
Whether the serialization/saving support is configured in
Definition at line 82 of file xmlversion.h.
| #define LIBXML_PUSH_ENABLED |
Whether the push parsing interfaces are configured in
Definition at line 91 of file xmlversion.h.
| #define LIBXML_READER_ENABLED |
Whether the xmlReader parsing interface is configured in
Definition at line 100 of file xmlversion.h.
| #define LIBXML_PATTERN_ENABLED |
Whether the xmlPattern node selection interface is configured in
Definition at line 109 of file xmlversion.h.
| #define LIBXML_WRITER_ENABLED |
Whether the xmlWriter saving interface is configured in
Definition at line 118 of file xmlversion.h.
| #define LIBXML_SAX1_ENABLED |
Whether the older SAX1 interface is configured in
Definition at line 127 of file xmlversion.h.
| #define LIBXML_VALID_ENABLED |
LIBXML_FTP_ENABLED:
Whether the FTP support is configured in LIBXML_HTTP_ENABLED:
Whether the HTTP support is configured in LIBXML_VALID_ENABLED:
Whether the DTD validation support is configured in
Definition at line 154 of file xmlversion.h.
| #define LIBXML_HTML_ENABLED |
Whether the HTML support is configured in
Definition at line 163 of file xmlversion.h.
| #define LIBXML_C14N_ENABLED |
Whether the deprecated APIs are compiled in for compatibility LIBXML_C14N_ENABLED:
Whether the Canonicalization support is configured in
Definition at line 181 of file xmlversion.h.
| #define LIBXML_CATALOG_ENABLED |
Whether the Catalog support is configured in
Definition at line 190 of file xmlversion.h.
| #define LIBXML_XPATH_ENABLED |
| #define LIBXML_XPTR_ENABLED |
| #define LIBXML_XINCLUDE_ENABLED |
Whether support for XPointer locations is configured in LIBXML_XINCLUDE_ENABLED:
Whether XInclude is configured in
Definition at line 226 of file xmlversion.h.
| #define LIBXML_ISO8859X_ENABLED |
Whether iconv support is available LIBXML_ICU_ENABLED:
Whether icu support is available LIBXML_ISO8859X_ENABLED:
Whether ISO-8859-* support is made available in case iconv is not
Definition at line 253 of file xmlversion.h.
| #define LIBXML_UNICODE_ENABLED |
Whether Debugging module is configured in LIBXML_UNICODE_ENABLED:
Whether the Unicode related interfaces are compiled in
Definition at line 271 of file xmlversion.h.
| #define LIBXML_REGEXP_ENABLED |
Whether the regular expressions interfaces are compiled in
Definition at line 280 of file xmlversion.h.
| #define LIBXML_AUTOMATA_ENABLED |
Whether the automata interfaces are compiled in
Definition at line 289 of file xmlversion.h.
| #define LIBXML_SCHEMAS_ENABLED |
Whether the Schemas validation interfaces are compiled in
Definition at line 298 of file xmlversion.h.
| #define LIBXML_SCHEMATRON_ENABLED |
Whether the Schematron validation interfaces are compiled in
Definition at line 307 of file xmlversion.h.
| #define LIBXML_MODULES_ENABLED |
Whether the module interfaces are compiled in
Definition at line 316 of file xmlversion.h.
| #define LIBXML_MODULE_EXTENSION ".so" |
the string suffix used by dynamic modules (usually shared libraries)
Definition at line 322 of file xmlversion.h.
| #define LIBXML_ZLIB_ENABLED |
Whether the Zlib support is compiled in
Definition at line 331 of file xmlversion.h.
1.8.13 on Sat Dec 13 2025
