| 0010012 | ParaView | Bug | public | 2009-12-08 09:44 | 2010-03-09 21:54 | ||||
| Assigned To | Zhanping Liu | ||||||||
| Status | closed | Resolution | duplicate | ||||||
| Product Version | |||||||||
| Target Version | 3.8 | Fixed in Version | |||||||
| Summary | 0010012: Calculator remembering past arrays | ||||||||
| Description | From Paul Edwards: > create a box > apply calculator filter: array name "a", value "1" > apply calculator again: array name "b", value "2" > > now change the input for the second calculator to the box and you get > the following error: > > vtkArrayCalculator (0x28b3d40): Invalid array name: a > > Even though it doesn't use that array... | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0018724) Utkarsh Ayachit (administrator) 2009-12-08 11:20 |
From Dominik Szczerba: > Create a custom filter using calculator and the data (u,v,w,p) > sqrt(u^2+v^2+w^2). Save a custom filter. Now re-open the data but now do not > read 'p' array this time (XDMF). Apply custom filter. Calculator will complain > p is absent. |
(0019710) Zhanping Liu (developer) 2010-03-04 13:05 |
This problem was fixed through the addition of new class vtkPVArrayCalculator.h/cxx and changes to some related files (see below). Now the user is able to change the input of a calculator. === VTK/Graphics/vtkArrayCalculator.h/cxx ParaView/Qt/Components/pqCalculatorPanel.h/cxx ParaView/Servers/Fitlers/CMakeLists.txt ParaView/Servers/Fitlers/vtkPVArrayCalculator.h/cxx (addition) ParaView/Servers/ServerManager/Resources/filters.xml |
(0019789) Alan Scott (manager) 2010-03-09 21:54 |
Tested local server, XP, trunk. |
| Notes |
| Issue History | |||
| 2009-12-08 09:44 | Utkarsh Ayachit | New Issue | |
| 2009-12-08 10:06 | Utkarsh Ayachit | Relationship added | duplicate of 0009604 |
| 2009-12-08 10:06 | Utkarsh Ayachit | Duplicate ID | 0 => 9604 |
| 2009-12-08 10:06 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2009-12-08 10:06 | Utkarsh Ayachit | Resolution | open => duplicate |
| 2009-12-08 10:06 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2009-12-08 10:07 | Utkarsh Ayachit | Status | @80@ => tabled |
| 2009-12-08 10:07 | Utkarsh Ayachit | Relationship deleted | 0009604 |
| 2009-12-08 10:07 | Utkarsh Ayachit | Relationship added | related to 0009604 |
| 2009-12-08 11:20 | Utkarsh Ayachit | Note Added: 0018724 | |
| 2010-01-11 10:41 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Zhanping Liu |
| 2010-03-04 13:05 | Zhanping Liu | Note Added: 0019710 | |
| 2010-03-04 13:05 | Zhanping Liu | Status | tabled => @80@ |
| 2010-03-09 21:54 | Alan Scott | Note Added: 0019789 | |
| 2010-03-09 21:54 | Alan Scott | Status | @80@ => closed |
| Issue History |
