0009604 | ParaView | Bug | public | 2009-09-27 04:56 | 2010-03-09 21:50 | ||||
Reporter | Sven Buijssen | ||||||||
Assigned To | Zhanping Liu | ||||||||
Product Version | 3.6 | ||||||||
Target Version | 3.8 | Fixed in Version | |||||||
Summary | 0009604: Changing Result Array Name in Calculator raises error in depending Calculator | ||||||||
Description | Sources - Box Filters - Calculator1 Arbitrary operation to create a point data named e.g. "foo" Filters - Calculator2 Arbitrary operation to create another point data named e.g. "bar" Select Calculator1, change name to e.g. "foobar". => On Apply the output messages window will pop up and display ERROR: In ..\..\..\src\VTK\Graphics\vtkArrayCalculator.cxx, line 305 vtkArrayCalculator (0952DDF0): Invalid array name: foobar Checking the Scalars or Vectors (depending on operation in Calculator1) dropdown box in Calculator2 confirms that this list has not been updated automatically. Verified with ParaView 3.6.1 (local server, XP) and ParaView CVS as of today (local server, Linux 32 bit). | ||||||||
Relationships | ||||||
(0019709) Zhanping Liu (developer) 2010-03-04 13:02 |
This problem was fixed through the addition of new class vtkPVArrayCalculator.h/cxx and changes to some related files (see below). Now the user is able to change the name of an upstream calculator. === VTK/Graphics/vtkArrayCalculator.h/cxx ParaView/Qt/Components/pqCalculatorPanel.h/cxx ParaView/Servers/Fitlers/CMakeLists.txt ParaView/Servers/Fitlers/vtkPVArrayCalculator.h/cxx (addition) ParaView/Servers/ServerManager/Resources/filters.xml |
(0019788) Alan Scott (manager) 2010-03-09 21:50 |
Tested local server, XP, trunk. Not sure what "change name to foobar" means, so I changed the name of the filter AND the result array name. Both work. |
2009-09-27 04:56 | Sven Buijssen | New Issue | |
2009-10-02 09:26 | Utkarsh Ayachit | Status | backlog => tabled |
2009-10-02 09:26 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-10-02 09:26 | Utkarsh Ayachit | Target Version | => 3.8 |
2009-12-08 10:06 | Utkarsh Ayachit | Relationship added | has duplicate 0010012 |
2009-12-08 10:07 | Utkarsh Ayachit | Relationship deleted | has duplicate 0010012 |
2009-12-08 10:07 | Utkarsh Ayachit | Relationship added | related to 0010012 |
2010-01-11 10:42 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Zhanping Liu |
2010-03-04 13:02 | Zhanping Liu | Note Added: 0019709 | |
2010-03-04 13:03 | Zhanping Liu | Status | tabled => @80@ |
2010-03-09 21:50 | Alan Scott | Note Added: 0019788 | |
2010-03-09 21:50 | Alan Scott | Status | @80@ => closed |
2010-03-09 21:50 | Alan Scott | Resolution | open => fixed |
