0010800 | ParaView | Bug | public | 2010-06-07 15:55 | 2013-01-22 16:27 | ||||
Reporter | Ross McLendon | ||||||||
Status | closed | Resolution | duplicate | ||||||
Product Version | 3.8 | ||||||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0010800: Calculator parsing error on tensoral cell data... | ||||||||
Description | I load a .vtu file that has tensor-style cell data with the name "FailureModes". I use the calculator to attempt to extract scalars from this data so that I can apply threshold to various components. The equation field contains only a string of the form "FailureModes_XX" (no quotes, _XX corresponds to the component I want to convert to a scalar for use in Threshold down the road). When I hit apply, ParaView gives the the following output message: ERROR: In ..\..\..\src\VTK\Common\vtkFunctionParser.cxx, line 1632 vtkFunctionParser (00000000067DD400): Syntax error: operator expected; see position 14 ERROR: In ..\..\..\src\VTK\Common\vtkFunctionParser.cxx, line 1632 vtkFunctionParser (00000000067DD400): Syntax error: operator expected; see position 14 Warning: In ..\..\..\src\VTK\Graphics\vtkArrayCalculator.cxx, line 401 vtkPVArrayCalculator (000000000F885010): An error occured when parsing the calculator's function. See previous errors. Also, there is no Result array... This worked in 3.6.2. I'm guessing it's a parser issue. Hopefully not too bad to fix. | ||||||||
Additional Information | I've attached a version of my .vtu file that I'm trying to visualize... I am running ParaView 3.8 on Windows Server 2008 R2 64 bit. | ||||||||
Attached Files | paraview-3.8.1-fixed-vtkpvarraycalculator-tensor-data.patch [^] (2,224 bytes) 2011-03-29 05:12 [Show Content] | ||||||||
Relationships | ||||||
(0025948) He Yuqi (reporter) 2011-03-29 05:14 edited on: 2011-03-29 05:15 |
It seems that the function vtkPVArrayCalculator::UpdateArrayAndVariableNames does not support tensor-style cell data. Attached patch to fix this issue. |
(0029295) Utkarsh Ayachit (administrator) 2012-09-28 14:28 |
merged into master, if applicable. |
(0030220) Alan Scott (manager) 2013-01-22 16:27 |
Although I cannot find the attached file, I also believe this is the same as 13258. I used the dataset from that bug to test this one. Fixed. Tested remote server, Linux, master. |
2010-06-07 15:55 | Ross McLendon | New Issue | |
2011-03-29 05:12 | He Yuqi | File Added: paraview-3.8.1-fixed-vtkpvarraycalculator-tensor-data.patch | |
2011-03-29 05:14 | He Yuqi | Note Added: 0025948 | |
2011-03-29 05:15 | He Yuqi | Note Edited: 0025948 | |
2012-09-25 11:10 | Utkarsh Ayachit | Relationship added | duplicate of 0013258 |
2012-09-25 11:10 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2012-09-25 11:10 | Utkarsh Ayachit | Resolution | open => duplicate |
2012-09-25 11:10 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-09-28 14:28 | Utkarsh Ayachit | Fixed in Version | => git-master |
2012-09-28 14:28 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-09-28 14:28 | Utkarsh Ayachit | Note Added: 0029295 | |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2013-01-22 16:27 | Alan Scott | Note Added: 0030220 | |
2013-01-22 16:27 | Alan Scott | Status | customer review => closed |
