0010965 | ParaView | Feature | public | 2010-07-08 16:11 | 2014-01-11 08:39 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0010965: Trace State does not cull default values | ||||||||
Description | When you use the Start Trace/Stop Trace buttons to trace actions within the GUI, the resulting script is greatly shortened by removing entries that match the defaults for the objects (that's good). However, when you use the 'Save State as Python' feature, it seems to dump everything regardless of the defaults. The resulting script would be much more readable if it also culled any values that match the default. | ||||||||
Project | Sandia-Catalyst | ||||||||
Topic Name | 10965_cull_default_values | ||||||||
Relationships | ||||||
(0024346) Robert Maynard (developer) 2010-12-31 11:54 |
ParaView Commit SHA: c96853dcbcc After talking with Utkarsh we decided that with how rarely we change default values it seemed reasonable that the python state would not include them. |
(0024361) Pat Marion (reporter) 2011-01-03 11:34 |
Commit c96853dcbcc needs to be reverted. For saving python state, the CaptureAllProperties flag must be True. I think that solving this bug requires writing a routine that checks if a property's current value matches the default_value defined in xml. |
(0024368) Robert Maynard (developer) 2011-01-03 16:29 |
I have reverted commit c96853dcbcc. |
(0031138) Andy Bauer (developer) 2013-07-12 17:22 |
Note that Kyle fixed this already for saving state. The option is available under Save Full State in the Settings menu. I'm working on enabling this feature for the generated co-processing scripts. |
(0031142) Andy Bauer (developer) 2013-07-16 23:00 |
To control whether or not default values are included in the catalyst and spatio-temporal generated scripts, set the option in the settings menu. The default value in the settings menu is to cull the default values from the generated script. |
(0031336) Utkarsh Ayachit (administrator) 2013-07-26 10:00 |
SUMMARY --------------------------------------------- Topics merged into master: 10965_cull_default_values 14179-add-PythonQt-plugin cth_markers_on_by_default (VTK) fix-catalyst (VTK) update_vtk_master |
(0032021) Andy Bauer (developer) 2013-12-18 11:20 |
Steps to reproduce the current incorrect behaviour: 1) start trace 2) create wavelet, apply 3) create cut filter, apply 4) stop trace 5) save file now repeat all steps with save full state in python switched from the previous setting. |
(0032032) Utkarsh Ayachit (administrator) 2013-12-19 16:56 |
I think there's lot of confusion with this bug. Andy/Alan, "Trace" is never supposed to change based on whether "Save Full State in Python" setting is checked or not. "Trace" is always a log of the the changed properties, so it's only going to record the values that changed. The only thing this setting (the "Save Full State in Python" setting from the Settings dialog) affects is when one tries to "Save State" as Python (accessible from File->Save State menu; don't forget to choose the "*.py" file extension). With that you'll indeed get the "full" or "trimmed" states files as expected. |
(0032035) Utkarsh Ayachit (administrator) 2013-12-20 08:26 |
Topics merged into master: 14286_fix_orientation_widget (VTK) 14426-huge-png 14464_fix_specular_highlights 14466_fix_calculator_panel disable-unified-bindings-by-default fix-collaboration fix_parallel_amrconnectivity gio-cleanup-and-warning-fixes pvweb-enhancements-events-protocols-docs |
(0032056) Alan Scott (manager) 2013-12-24 17:45 |
Fascinating bug. As per Utkarsh's last note, this isn't a bug at all, since Kens' writeup is confusing. So, I am not sure what to test. With regards to Trace State not culling default values (summary of this bug), Utkarsh's latest work has greatly reduced the amount of default state placed in the trace. Very nice. There are issues with the new trace. (Basically, can_ex2 = FindSource( "can.ex2" )is being incorrectly shoved into the trace.) I am dealing with it in bug number 14214. This is basically fixed. With regards to Save Full State as Python doesn't effect trace, this is correct. This is not a bug. With regards to saving state as python (description of this bug), and playing with the Save Full State as Python setting, this now works correctly. The non Save Full State is greatly reduced. Tested master, local server or pvbatch, Linux. |
2010-07-08 16:11 | Ken Moreland | New Issue | |
2010-09-01 11:34 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
2010-12-31 10:11 | Robert Maynard | Assigned To | => Robert Maynard |
2010-12-31 10:11 | Robert Maynard | Status | backlog => tabled |
2010-12-31 11:54 | Robert Maynard | Note Added: 0024346 | |
2010-12-31 11:54 | Robert Maynard | Status | tabled => @80@ |
2010-12-31 11:54 | Robert Maynard | Fixed in Version | => 3.10.shortlist |
2010-12-31 11:54 | Robert Maynard | Resolution | open => fixed |
2011-01-03 11:34 | Pat Marion | Note Added: 0024361 | |
2011-01-03 11:34 | Pat Marion | Status | @80@ => @20@ |
2011-01-03 11:34 | Pat Marion | Resolution | fixed => reopened |
2011-01-03 14:20 | Pat Marion | Status | @20@ => tabled |
2011-01-03 16:29 | Robert Maynard | Note Added: 0024368 | |
2013-01-08 21:33 | Alan Scott | Project | => Sandia |
2013-01-08 21:33 | Alan Scott | Type | => incorrect functionality |
2013-03-18 15:09 | Utkarsh Ayachit | Relationship added | related to 0013891 |
2013-03-18 15:09 | Utkarsh Ayachit | Project | Sandia => Sandia-Catalyst |
2013-03-18 15:09 | Utkarsh Ayachit | Assigned To | Robert Maynard => |
2013-07-12 17:20 | Andy Bauer | Assigned To | => Andy Bauer |
2013-07-12 17:21 | Andy Bauer | Status | backlog => todo |
2013-07-12 17:22 | Andy Bauer | Note Added: 0031138 | |
2013-07-12 17:22 | Andy Bauer | Status | todo => active development |
2013-07-16 23:00 | Andy Bauer | Topic Name | => 10965_cull_default_values |
2013-07-16 23:00 | Andy Bauer | Note Added: 0031142 | |
2013-07-16 23:00 | Andy Bauer | Status | active development => gatekeeper review |
2013-07-16 23:00 | Andy Bauer | Fixed in Version | => git-next |
2013-07-16 23:00 | Andy Bauer | Resolution | reopened => fixed |
2013-07-26 10:00 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-07-26 10:00 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-07-26 10:00 | Utkarsh Ayachit | Note Added: 0031336 | |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2013-12-18 11:17 | Andy Bauer | Assigned To | Andy Bauer => Utkarsh Ayachit |
2013-12-18 11:17 | Andy Bauer | Status | customer review => todo |
2013-12-18 11:20 | Andy Bauer | Note Added: 0032021 | |
2013-12-19 16:51 | Utkarsh Ayachit | Description Updated | |
2013-12-19 16:56 | Utkarsh Ayachit | Note Added: 0032032 | |
2013-12-19 16:56 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2013-12-20 08:26 | Utkarsh Ayachit | Fixed in Version | 4.1 => git-master |
2013-12-20 08:26 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-12-20 08:26 | Utkarsh Ayachit | Note Added: 0032035 | |
2013-12-24 17:45 | Alan Scott | Note Added: 0032056 | |
2013-12-24 17:45 | Alan Scott | Status | customer review => closed |
2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
