0013891 | ParaView | (No Category) | public | 2013-02-18 18:06 | 2013-05-23 15:00 | ||||
Reporter | Warren Hunt | ||||||||
Product Version | 3.98.1 | ||||||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0013891: incorrect param to Threshold() method in paraview.simple | ||||||||
Description | The coprocessing plugin python generator adds UseContinuousCellRange to the Threshold constructor, but the presence of that parameter causes the instantiation to crash with error below: AttributeError: Attribute UseContinuousCellRange does not exist. This class does not allow addition of new attributes to avoid mistakes due to typos. Use add_attribute() if you really want to add this attribute. #this works: Threshold1 = Threshold( guiName="Threshold1", Scalars=['CELLS', 'KILLED'], ThresholdRange=[2.0, 2.0], AllScalars=1) #this is the auto-generated python but does not work: #Threshold1 = Threshold( guiName="Threshold1", Scalars=['CELLS', 'KILLED'], ThresholdRange=[2.0, 2.0], AllScalars=1, UseContinuousCellRange=0 ) Thanks! Warren Warren Hunt Sandia Labs | ||||||||
Project | Sandia-Catalyst | ||||||||
Type | crash | ||||||||
Relationships | ||||||
(0030442) Andy Bauer (developer) 2013-03-14 15:52 |
I think this is a version mismatch issue. the UseContinuousCellRange was added to the Threshold filter between 3.98.0 and 3.98.1. |
(0030443) Utkarsh Ayachit (administrator) 2013-03-14 16:01 |
The solution for this issue is the same as the one we had discussed for "missing arrays". For Catalyst/Batch scripts, missing arrays or missing attributes should not raise errors. Only for interactive Python shells should we throw exceptions in such cases. |
(0030444) Andy Bauer (developer) 2013-03-14 16:11 |
I'm not a Python expert but it seems that this would be problematic when the non-existing attribute is being specified in the constructor. Also, having process 0 give a warning would also be helpful to let the user know that something may be amiss. |
(0030447) Utkarsh Ayachit (administrator) 2013-03-18 15:08 |
After discussing with Berk, here's the conclusion: The error in this case is happening because Warren is using a newer ParaView version to generate the Python script that the version used to run it. Alas, not much can be done to support this case. He should simply edit/update the scripts in such cases. ParaView Python is not forward-compatible. BUG 0010965 will attempt to minimize the Python state itself to cull several properties so in this case, for example, the UseContinuousCellRange won't be saved in the state file at all and we will run into such issue at a fewer rate. |
(0030849) Alan Scott (manager) 2013-05-23 15:00 |
Version mismatch. Closing. |
2013-02-18 18:06 | Warren Hunt | New Issue | |
2013-03-14 13:30 | Andy Bauer | Assigned To | => Andy Bauer |
2013-03-14 14:22 | Andy Bauer | Status | backlog => todo |
2013-03-14 15:52 | Andy Bauer | Note Added: 0030442 | |
2013-03-14 15:53 | Andy Bauer | Assigned To | Andy Bauer => Utkarsh Ayachit |
2013-03-14 16:01 | Utkarsh Ayachit | Note Added: 0030443 | |
2013-03-14 16:11 | Andy Bauer | Note Added: 0030444 | |
2013-03-18 15:08 | Utkarsh Ayachit | Note Added: 0030447 | |
2013-03-18 15:09 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2013-03-18 15:09 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-03-18 15:09 | Utkarsh Ayachit | Resolution | open => won't fix |
2013-03-18 15:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-03-18 15:09 | Utkarsh Ayachit | Relationship added | related to 0010965 |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
2013-05-23 15:00 | Alan Scott | Note Added: 0030849 | |
2013-05-23 15:00 | Alan Scott | Status | customer review => closed |
