0011065 | ParaView | Feature | public | 2010-07-29 20:06 | 2015-01-11 08:37 | ||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0011065: Enhanced background | ||||||||
Description | I have a user that would like to add a background 3d grid around objects. This particular person wants this functionality around CTH data. I have added a screenshot that shows one example of this functionality. I did it as follows: Load Dave's small CTH dataset. Wireframe, then cull front faces. Load Dave's small CTH dataset. Cell to Point data. isoVolume the upper sphere. isovolume the lower block. isovolume the pressure as 1e9. Notice how 3d the object looks! | ||||||||
Project | Sandia | ||||||||
Topic Name | 11065_enhanced_amr_outline | ||||||||
Attached Files | ![]() ![]() ![]() ![]() ![]() ![]() | ||||||||
Relationships | ||||||
(0022062) Utkarsh Ayachit (administrator) 2010-09-01 11:23 |
Well this is very dicey. Note that in the attached image, you are only seeing the refinement at the outer most parts of the CTH data. Now if we project the highest refinement available in the interior to the background, then that can be misleading too, since it may lead the user to believe that that entire extruded volume has that high resolution. It may be easier to provide a python macro, in this case. |
(0022229) Utkarsh Ayachit (administrator) 2010-09-15 14:01 |
Merge topic 'bug_11065' 770af22 Added a new demo script for showing grid background. --------------- A new demo script show_grid_as_background has been added. One can go to the Python shell and make this script a Macro. After that, once you've loaded your AMR dataset done IsoVolume (or whatever), simply click on the reader (make it active) and then choose "show_grid_as_background" from the "Macro" menu or toolbar. We need to make it simpler to distribute macros with ParaView, but that's another bug. |
(0022247) Alan Scott (manager) 2010-09-15 21:59 |
Let me bounce this by the user, and I will reopen if necessary. At this time, lets assume the feature is resolved. |
(0025223) Alan Scott (manager) 2011-02-01 20:20 |
I have talked to my user, and also tried the suggested macro. I have been unclear as to what I want/need. If I have an object, such as a car or a sphere, I want to place this object into a space with a grid pattern on the furthest three planes, formed by planes perpendicular to the X axis, Y axis and Z axis. This would be like drawing a grid on the wall of the garage. I am sending a set of screenshots to Utkarsh, showing what I want. These screenshots also show bug number 11067. Screenshot 000000 - This shows the desired background functionality - a regular grid pattern. Notice that the foreground pattern shows the AMR block pattern. Screenshot 000713 - shows the desired background functionality, on background and foreground. Screenshot 000450 - shows the desired background only. Note how clear the numbers and labels are. Note that the labels are not on top of the numbers. |
(0029097) Utkarsh Ayachit (administrator) 2012-09-01 20:47 |
A partial fix is on its way to "git-mater". The missing part is the ability to hide the front or back faces on outlines. |
(0029098) Utkarsh Ayachit (administrator) 2012-09-01 20:47 |
commit 0c1121d78bf9136f3686f91d5d7f93b68660324e Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sat Sep 1 20:40:07 2012 -0400 BUG 0011065. Added support for "enhanced outline" for AMR. For AMR, instead of showing merely the outer outline, we now show the outer outline etched with the dataset outlines. Unlike in past, the internal block outlines are not shown, merely those on the outer surface. Also for overlapping AMR, outline doesnt' need any heavy data. It merely uses the AMR box information. |
(0029171) Utkarsh Ayachit (administrator) 2012-09-11 16:55 |
commit 76e49705184ee7a1c50c7b56c6b808be017e3ed8 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Sep 11 16:17:03 2012 -0400 Updating test to include amr outline with front face culling. commit 6b47a997212fc6f809ac563e378f577758d6a1b9 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Sep 11 15:41:58 2012 -0400 BUG 0011065. Adding face culling support for outline for AMR. To add support for face culling for outlines, we make vtkOutlineRepresentation a vtkGeometryRepresentationWithFaces subclass. vtkOutlineRepresentation now overrides certain methods in vtkGeometryRepresentation to ensure that the representation always generates outlines. Cleaning up the xml for "OutlineRepresentation" by being the same as the "SurfaceRepresentation". It will have a few extra properties like "Representation", "SuppressLOD", etc. that have no effect, but the XML ends up being much cleaner. commit 150d8db57821799ef62d9ca236135c98664fe0f8 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Sep 11 15:37:51 2012 -0400 Generate faces for outlines of AMR dataset. For BUG 0011065, we need to enable culling of front faces. For that its essential that the outlines have front/back faces to begin with. Hence, making vtkPVGeometryFilter generate faces for outlines for AMR datasets. Since vtkOutlineRepresentation is anyways set to show "wireframe", the resulting visualization remains unchanged. This can be theoretically done for all data types, but leaving that for a later date. |
(0029172) Utkarsh Ayachit (administrator) 2012-09-11 16:57 |
To test, simply show the outline of the CTH dataset and then in the "advanced view", select "Backface Representation" type to be "Cull Frontface". Attached is an image with cube-axes (with "Fly Mode" set to "Outer Edges"). |
(0029205) Utkarsh Ayachit (administrator) 2012-09-14 11:09 |
merged in master, if applicable. |
(0029220) Alan Scott (manager) 2012-09-18 22:26 |
Lets call this "close enough" until I get very specific feedback from the users. This closes this feature request for 4.0. Tested remote server, Linux, master. |
2010-07-29 20:06 | Alan Scott | New Issue | |
2010-07-29 20:06 | Alan Scott | File Added: cthGrid.png | |
2010-09-01 11:23 | Utkarsh Ayachit | Note Added: 0022062 | |
2010-09-01 11:23 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
2010-09-15 14:01 | Utkarsh Ayachit | Note Added: 0022229 | |
2010-09-15 14:01 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-09-15 14:01 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2010-09-15 14:01 | Utkarsh Ayachit | Resolution | open => fixed |
2010-09-15 14:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-09-15 21:59 | Alan Scott | Note Added: 0022247 | |
2010-09-15 21:59 | Alan Scott | Status | @80@ => closed |
2011-02-01 20:20 | Alan Scott | Note Added: 0025223 | |
2011-02-01 20:20 | Alan Scott | Status | closed => backlog |
2011-02-01 22:18 | Alan Scott | Priority | normal => high |
2011-02-01 22:18 | Alan Scott | Status | backlog => tabled |
2011-06-24 14:21 | Alan Scott | Status | backlog => todo |
2011-06-27 08:32 | Utkarsh Ayachit | Project | => Sandia |
2012-05-31 10:23 | Utkarsh Ayachit | Status | todo => backlog |
2012-05-31 10:26 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => |
2012-05-31 10:26 | Utkarsh Ayachit | Status | backlog => todo |
2012-09-01 20:47 | Utkarsh Ayachit | Note Added: 0029097 | |
2012-09-01 20:47 | Utkarsh Ayachit | Note Added: 0029098 | |
2012-09-01 20:48 | Utkarsh Ayachit | File Added: bug11065.png | |
2012-09-01 20:50 | Utkarsh Ayachit | Relationship added | related to 0011067 |
2012-09-11 16:55 | Utkarsh Ayachit | File Added: Screenshot-ParaView 3.14.1-1757-g76e4970 64-bit.png | |
2012-09-11 16:55 | Utkarsh Ayachit | Topic Name | => 11065_enhanced_amr_outline |
2012-09-11 16:55 | Utkarsh Ayachit | Note Added: 0029171 | |
2012-09-11 16:55 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-09-11 16:55 | Utkarsh Ayachit | Fixed in Version | 3.10 => git-next |
2012-09-11 16:55 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-09-11 16:57 | Utkarsh Ayachit | Note Added: 0029172 | |
2012-09-14 11:09 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-09-14 11:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-09-14 11:09 | Utkarsh Ayachit | Note Added: 0029205 | |
2012-09-18 22:26 | Alan Scott | Note Added: 0029220 | |
2012-09-18 22:26 | Alan Scott | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
2015-01-11 08:34 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 697b9e2f |
2015-01-11 08:36 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b3c8ba78 |
2015-01-11 08:36 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master ad2f27ea |
2015-01-11 08:36 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 0c1121d7 |
2015-01-11 08:37 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 6b47a997 |
