0011251 | ParaView | Feature | public | 2010-09-20 14:08 | 2010-10-27 21:01 | ||||
Assigned To | Sebastien Jourdain | ||||||||
Target Version | Fixed in Version | 3.10 | |||||||
Summary | 0011251: Mechanisms to distribute macros with Paraview | ||||||||
Description | Mechanisms to distribute macros with Paraview. | ||||||||
Relationships | ||||||
(0022368) Sebastien Jourdain (manager) 2010-09-27 10:43 |
Fixed provided inside the commit 8d67360bcc130352b75f5ff8c334ca09b729cf74 - Now the storage of macros is on the filesystem directly - When a macro is added, the script file is copied into a ParaView user specific configuration directory. - When a macro is deleted, the script file is kept inside the same ParaView Macros directory but it is renamed with a dot at the head of the filename - The macro list is retreived by listing the content of application and user "Macros" directory. - If two created/deleted macro have the same name the newest is renamed with the following pattern fileName-X.py where X is an integer that start at one and is incremented till the file do not exist. |
(0022723) Alan Scott (manager) 2010-10-27 21:01 |
Tested local server, Windows, trunk. |
2010-09-20 14:08 | Utkarsh Ayachit | New Issue | |
2010-09-20 14:08 | Utkarsh Ayachit | Status | backlog => tabled |
2010-09-20 14:08 | Utkarsh Ayachit | Assigned To | => Sebastiennn Jourdain |
2010-09-20 14:08 | Utkarsh Ayachit | Relationship added | related to 0009672 |
2010-09-27 10:43 | Sebastien Jourdain | Note Added: 0022368 | |
2010-09-27 10:43 | Sebastien Jourdain | Status | tabled => @80@ |
2010-09-27 10:43 | Sebastien Jourdain | Fixed in Version | => 3.10 |
2010-09-27 10:43 | Sebastien Jourdain | Resolution | open => fixed |
2010-10-27 21:01 | Alan Scott | Note Added: 0022723 | |
2010-10-27 21:01 | Alan Scott | Status | @80@ => closed |
