0012315 | ParaView | (No Category) | public | 2011-06-24 19:46 | 2011-08-17 18:59 | ||||
Reporter | Burlen | ||||||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0012315: Display->Style->Subdivision doesn't work on quadratic cells | ||||||||
Description | The subdivision spin box doesn't affect quadratic cells. The attached file can be used to reproduce the issue. Open the file, click the display tab, under the style group, change the subdivisions to 4, there is no change. Compare this result to the tessellate filter. | ||||||||
Project | Sandia | ||||||||
Topic Name | 12315-display-subdivision-broken | ||||||||
Attached Files | ![]() ![]() | ||||||||
(0026898) Ken Moreland (manager) 2011-06-27 11:07 |
I've noticed that there are actually two issues here. The first is that a property in the necessary server manager object disappeared so that subdivision value never makes it to the appropriate internal filter. I'm fixing that. The second issue is that subdivision of line elements is not supported by the internal filter. Rather, only surface elements are subdivided. Thus, the fix will not have any effect on the attached test.vtk. It will, however, fix the problems with, for example, the quadraticTetra01.vtu data set (both in the ParaViewData repository and attached to this bug report for convenience). I do not intend to fix this latter problem. It is a missing feature for which I am not sure has a use case. If automatic subdivision of line elements is necessary, open a separate bug. |
(0026901) Ken Moreland (manager) 2011-06-27 13:39 |
Branch 12315-display-subdivision-broken Merged commit d7c2a66f85563e99722c24c5bd93b0b1474df0d3 |
(0026903) Burlen (developer) 2011-06-27 17:36 |
To handle line elements (VTK_QUADRATIC_EDGE cells) a user could run the tessellate filter instead. |
(0026925) Utkarsh Ayachit (administrator) 2011-06-30 14:17 |
For Developers: These issues are slated for gatekeeper review on July 1, 2 pm EDT. |
(0026942) Utkarsh Ayachit (administrator) 2011-07-01 15:31 |
Deemed not ready for merge since test is failing on kargad. http://www.cdash.org/CDash/testDetails.php?test=103317970&build=1290252 [^] |
(0026945) Utkarsh Ayachit (administrator) 2011-07-02 11:06 |
Also look at the following: Baselines don't seem to match up. http://www.cdash.org/CDash/testDetails.php?test=103477901&build=1293791 [^] |
(0026966) Ken Moreland (manager) 2011-07-05 17:26 |
The bad baseline images are caused by bug 0010676, which is of too low importance to fix. Instead, I've disabled the render-server test, which invokes the problem. |
(0026968) Ken Moreland (manager) 2011-07-05 17:29 |
The test on kargad seems to be failing in a place unrelated to changes in this bug. The test is successfully running, creating all 4 test images, passing the comparisons to the baseline images, and finishing. At some point either at the end of the test script or after the test script finishes a seg fault occurs. I am reassigning the bug to Utkarsh to see if he can figure out why the seg fault happens. |
(0027005) David Partyka (developer) 2011-07-15 14:35 |
Still not passing on Kargad. |
(0027047) Utkarsh Ayachit (administrator) 2011-07-21 19:18 |
Scheduled for gatekeeper review on Jul 22, 2011 at 2 pm EDT. |
(0027069) Utkarsh Ayachit (administrator) 2011-07-22 14:13 |
Merged to git-master. |
(0027378) Alan Scott (manager) 2011-08-17 18:59 |
Tested development branch, local server, Linux client. As stated below, now works with quadricTetra01.vtu, but not test.vtk. |
2011-06-24 19:46 | Burlen | New Issue | |
2011-06-24 19:46 | Burlen | File Added: test.vtk | |
2011-06-27 10:49 | Ken Moreland | Assigned To | => Ken Moreland |
2011-06-27 10:56 | Ken Moreland | Status | backlog => todo |
2011-06-27 10:57 | Ken Moreland | File Added: quadraticTetra01.vtu | |
2011-06-27 11:07 | Ken Moreland | Note Added: 0026898 | |
2011-06-27 13:38 | Ken Moreland | Status | todo => active development |
2011-06-27 13:39 | Ken Moreland | Note Added: 0026901 | |
2011-06-27 13:39 | Ken Moreland | Status | active development => gatekeeper review |
2011-06-27 17:36 | Burlen | Note Added: 0026903 | |
2011-06-28 21:08 | Utkarsh Ayachit | Project | TBD => Sandia |
2011-06-30 14:17 | Utkarsh Ayachit | Note Added: 0026925 | |
2011-07-01 15:31 | Utkarsh Ayachit | Note Added: 0026942 | |
2011-07-01 15:31 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
2011-07-02 11:06 | Utkarsh Ayachit | Note Added: 0026945 | |
2011-07-05 16:57 | Ken Moreland | Status | backlog => todo |
2011-07-05 16:57 | Ken Moreland | Status | todo => active development |
2011-07-05 17:26 | Ken Moreland | Note Added: 0026966 | |
2011-07-05 17:27 | Ken Moreland | Assigned To | Ken Moreland => Utkarsh Ayachit |
2011-07-05 17:29 | Ken Moreland | Note Added: 0026968 | |
2011-07-08 14:18 | Utkarsh Ayachit | Topic Name | => 12315-display-subdivision-broken |
2011-07-08 14:18 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2011-07-08 14:18 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
2011-07-08 14:18 | Utkarsh Ayachit | Resolution | open => fixed |
2011-07-15 14:35 | David Partyka | Note Added: 0027005 | |
2011-07-15 14:35 | David Partyka | Status | gatekeeper review => todo |
2011-07-20 11:25 | Utkarsh Ayachit | Status | todo => active development |
2011-07-20 11:25 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2011-07-20 11:25 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Ken Moreland |
2011-07-21 19:18 | Utkarsh Ayachit | Note Added: 0027047 | |
2011-07-22 14:13 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2011-07-22 14:13 | Utkarsh Ayachit | Note Added: 0027069 | |
2011-08-17 18:59 | Alan Scott | Note Added: 0027378 | |
2011-08-17 18:59 | Alan Scott | Status | customer review => closed |
