0012579 | ParaView | (No Category) | public | 2011-09-07 11:23 | 2016-08-12 09:58 | ||||
Reporter | Paul Edwards | ||||||||
Summary | 0012579: Line chart display bug when loading a statefile | ||||||||
Description | The "Display" tab in the "Object Inspector" does not populate the "Use Data Array" combo box in the "X Axis Data" section when it is set up from a state file. I've attached a script that generates a statefile (saves to /tmp/mystate.pvsm) | ||||||||
Project | TBD | ||||||||
Attached Files | ![]() | ||||||||
(0027460) Paul Edwards (reporter) 2011-09-07 11:29 |
Also, the combo box never gets updates when filters/sources earlier in the pipeline. E.g. plot something created in the calculator, then rename the array name with the calculator - it stays the same in the display tab but will also give the error: ERROR: In ParaView/VTK/Charts/vtkPlotPoints.cxx, line 635 vtkPlotLine (0x34e6010): No X column is set (index 0). |
(0038067) Kitware Robot (administrator) 2016-08-12 09:58 |
2011-09-07 11:23 | Paul Edwards | New Issue | |
2011-09-07 11:23 | Paul Edwards | File Added: create-state.py | |
2011-09-07 11:29 | Paul Edwards | Note Added: 0027460 | |
2016-08-12 09:58 | Kitware Robot | Note Added: 0038067 | |
