0012929ParaView(No Category)public2012-02-13 12:152012-10-29 17:04
ReporterPaul Edwards
Assigned ToSebastien Jourdain
StatusclosedResolutionduplicate
PlatformOSOS Version
Product Version
Target VersionFixed in Version3.98.0
Summary0012929: Calculator gives incorrect results for multiblock datasets
DescriptionThe calculator gives incorrect results for multiblock unless the variables have the same index internally. This can be reproduced with the steps below:
1. Create a python source that outputs vtkUnstructuredGrid with the following script:
def add_scalar(ds, val):
                arr = vtk.vtkDoubleArray()
                arr.SetName("Scalar"+str(val))
                arr.SetNumberOfComponents(1)
                arr.SetNumberOfTuples(8)
                for i in range(8):
                                arr.SetTuple1(i, float(val))
                output.GetPointData().AddArray(arr)
output = self.GetOutput()
npts = 8
pts = vtk.vtkPoints()
pts.InsertNextPoint(-3.0, -1.0, -1.0)
pts.InsertNextPoint(-1.0, -1.0, -1.0)
pts.InsertNextPoint(-1.0, 1.0, -1.0)
pts.InsertNextPoint(-3.0, 1.0, -1.0)
pts.InsertNextPoint(-3.0, -1.0, 1.0)
pts.InsertNextPoint(-1.0, -1.0, 1.0)
pts.InsertNextPoint(-1.0, 1.0, 1.0)
pts.InsertNextPoint(-3.0, 1.0, 1.0)
output.SetPoints(pts)
output.Allocate(1,1)
ids = vtk.vtkIdList()
for i in range(npts):
    ids.InsertId(i,i)
add_scalar(output, 1)
add_scalar(output, 2)
output.InsertNextCell(vtk.VTK_HEXAHEDRON, ids)
2. Create a second python source that outputs vtkUnstructuredGrid with the following script (notice the change in order when adding the scalars):
                for i in range(8):
npts = 8
    ids.InsertId(i,i)
3. Group the two python sources together
4. Use the Calculator filter to pass through Scalar1
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
 Relationships
duplicate of 0013088closedSebastien Jourdain Calculator produce invalid results
  Notes
(0028513)
2012-04-23 10:18
Duplicate of BUG 0013088, and that one's already fixed in git-master.
 Issue History
2012-02-13 12:15 Paul Edwards New Issue
2012-04-13 11:42 Sebastien Jourdain Relationship added duplicate of 0013088
2012-04-23 10:18 Utkarsh Ayachit Note Added: 0028513
2012-04-23 10:18 Utkarsh Ayachit Status backlog => closed
2012-04-23 10:18 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2012-04-23 10:18 Utkarsh Ayachit Resolution open => duplicate
2012-04-23 10:18 Utkarsh Ayachit Fixed in Version => git-master
2012-04-23 10:19 Utkarsh Ayachit Assigned To Utkarsh Ayachit => Sebastiennn Jourdain
2012-10-29 17:04 Utkarsh Ayachit Fixed in Version git-master => 3.98.0
