0013088 | ParaView | (No Category) | public | 2012-04-13 10:10 | 2012-10-29 17:04 | ||||
Reporter | Sebastien Jourdain | ||||||||
Assigned To | Sebastien Jourdain | ||||||||
Target Version | Fixed in Version | 3.98.0 | |||||||
Summary | 0013088: Calculator produce invalid results | ||||||||
Description | The calculator gives incorrect results for multiblock unless the variables have the same index internally. This can be reproduced with the steps below: 1. Create a python source that outputs vtkUnstructuredGrid with the following script: def add_scalar(ds, val): arr = vtk.vtkDoubleArray() arr.SetName("Scalar"+str(val)) arr.SetNumberOfComponents(1) arr.SetNumberOfTuples(8) for i in range(8): arr.SetTuple1(i, float(val)) output.GetPointData().AddArray(arr) output = self.GetOutput() npts = 8 pts = vtk.vtkPoints() pts.InsertNextPoint(-3.0, -1.0, -1.0) pts.InsertNextPoint(-1.0, -1.0, -1.0) pts.InsertNextPoint(-1.0, 1.0, -1.0) pts.InsertNextPoint(-3.0, 1.0, -1.0) pts.InsertNextPoint(-3.0, -1.0, 1.0) pts.InsertNextPoint(-1.0, -1.0, 1.0) pts.InsertNextPoint(-1.0, 1.0, 1.0) pts.InsertNextPoint(-3.0, 1.0, 1.0) output.SetPoints(pts) output.Allocate(1,1) ids = vtk.vtkIdList() for i in range(npts): ids.InsertId(i,i) add_scalar(output, 1) add_scalar(output, 2) output.InsertNextCell(vtk.VTK_HEXAHEDRON, ids) 2. Create a second python source that outputs vtkUnstructuredGrid with the following script (notice the change in order when adding the scalars): def add_scalar(ds, val): arr = vtk.vtkDoubleArray() arr.SetName("Scalar"+str(val)) arr.SetNumberOfComponents(1) arr.SetNumberOfTuples(8) for i in range(8): arr.SetTuple1(i, float(val)) output.GetPointData().AddArray(arr) output = self.GetOutput() npts = 8 pts = vtk.vtkPoints() pts.InsertNextPoint(-3.0, -1.0, -1.0) pts.InsertNextPoint(-1.0, -1.0, -1.0) pts.InsertNextPoint(-1.0, 1.0, -1.0) pts.InsertNextPoint(-3.0, 1.0, -1.0) pts.InsertNextPoint(-3.0, -1.0, 1.0) pts.InsertNextPoint(-1.0, -1.0, 1.0) pts.InsertNextPoint(-1.0, 1.0, 1.0) pts.InsertNextPoint(-3.0, 1.0, 1.0) output.SetPoints(pts) output.Allocate(1,1) ids = vtk.vtkIdList() for i in range(npts): ids.InsertId(i,i) add_scalar(output, 2) add_scalar(output, 1) output.InsertNextCell(vtk.VTK_HEXAHEDRON, ids) 3. Group the two python sources together 4. Use the Calculator filter to pass through Scalar1 See output below: | ||||||||
Project | TBD | ||||||||
Topic Name | 13088-calculator-multi-block-fix | ||||||||
Attached Files | ![]() ![]() ![]() | ||||||||
Relationships | ||||||
(0028483) Sebastien Jourdain (manager) 2012-04-17 11:05 |
diff --git a/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.cxx b/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.cxx index 37eec77..9cc728f 100644 --- a/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.cxx +++ b/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.cxx @@ -17,6 +17,7 @@ #include "vtkCellData.h" #include "vtkDataObject.h" #include "vtkDataSet.h" +#include "vtkFunctionParser.h" #include "vtkGraph.h" #include "vtkInformation.h" #include "vtkInformationVector.h" @@ -73,6 +74,9 @@ void vtkPVArrayCalculator::UpdateArrayAndVariableNames { unsigned long mtime = this->GetMTime(); + // Make sure we reparse the function based on the current array order + this->FunctionParser->InvalidateFunction(); + // Look at the data-arrays available in the input and register them as // variables with the superclass. // It's safe to call these methods in RequestData() since they don't call |
(0028484) Sebastien Jourdain (manager) 2012-04-17 11:07 edited on: 2012-05-23 11:30 |
diff --git a/Common/vtkFunctionParser.cxx b/Common/vtkFunctionParser.cxx index e955af7..da7f678 100644 --- a/Common/vtkFunctionParser.cxx +++ b/Common/vtkFunctionParser.cxx @@ -564,6 +564,12 @@ int vtkFunctionParser::DisambiguateOperators() } //----------------------------------------------------------------------------- +void vtkFunctionParser::InvalidateFunction() +{ + this->FunctionMTime.Modified(); +} + +//----------------------------------------------------------------------------- bool vtkFunctionParser::Evaluate() { int numBytesProcessed; diff --git a/Common/vtkFunctionParser.h b/Common/vtkFunctionParser.h index f81ff2c..e3c7724 100644 --- a/Common/vtkFunctionParser.h +++ b/Common/vtkFunctionParser.h @@ -234,6 +234,10 @@ public: // Check the validity of the function expression. void CheckExpression(int &pos, char **error); + // Description: + // Allow the user to force the function to be re-parsed + void InvalidateFunction(); + protected: vtkFunctionParser(); ~vtkFunctionParser(); ====> Done (http://review.source.kitware.com/#/t/702/ [^]) |
(0028485) Sebastien Jourdain (manager) 2012-04-17 11:09 |
Those are the 2 patch needed to fix the issue. Although with the current changes on VTK, we will wait to apply them once VTK/master will be in synch with ParaView/master. Otherwise user that need it could patch their current sources... |
(0028500) Utkarsh Ayachit (administrator) 2012-04-20 13:51 |
merged into master, where applicable. |
(0028637) Sebastien Jourdain (manager) 2012-05-23 08:02 |
Now that ParaView is using VTK/master, we can apply this patch... |
(0028669) Utkarsh Ayachit (administrator) 2012-06-01 14:41 |
Merged in master, if applicable. |
(0028873) Sebastien Jourdain (manager) 2012-07-19 16:27 |
Tested by loading the multi-block file and apply a calculator computation using on of the array and make sure the result is the same on both block regardless the ordering of the array names that differ for each block... |
2012-04-13 10:10 | Sebastien Jourdain | New Issue | |
2012-04-13 10:10 | Sebastien Jourdain | Assigned To | => Sebastiennn Jourdain |
2012-04-13 10:10 | Sebastien Jourdain | File Added: image001.png | |
2012-04-13 11:42 | Sebastien Jourdain | Relationship added | has duplicate 0012929 |
2012-04-17 09:02 | Sebastien Jourdain | Status | backlog => todo |
2012-04-17 09:02 | Sebastien Jourdain | Status | todo => active development |
2012-04-17 11:05 | Sebastien Jourdain | Note Added: 0028483 | |
2012-04-17 11:07 | Sebastien Jourdain | Note Added: 0028484 | |
2012-04-17 11:09 | Sebastien Jourdain | Note Added: 0028485 | |
2012-04-17 11:10 | Sebastien Jourdain | Status | active development => gatekeeper review |
2012-04-17 11:10 | Sebastien Jourdain | Resolution | open => fixed |
2012-04-17 11:16 | Sebastien Jourdain | Topic Name | => 13088-calculator-fix (On Seb computer...) |
2012-04-20 13:50 | Utkarsh Ayachit | Fixed in Version | => git-master |
2012-04-20 13:51 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-04-20 13:51 | Utkarsh Ayachit | Note Added: 0028500 | |
2012-05-23 08:02 | Sebastien Jourdain | Note Added: 0028637 | |
2012-05-23 08:02 | Sebastien Jourdain | Status | customer review => active development |
2012-05-23 11:30 | Sebastien Jourdain | Note Edited: 0028484 | |
2012-05-29 13:30 | Sebastien Jourdain | Topic Name | 13088-calculator-fix (On Seb computer...) => 13088-calculator-multi-block-fix |
2012-05-29 13:33 | Sebastien Jourdain | Status | active development => gatekeeper review |
2012-06-01 14:41 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-06-01 14:41 | Utkarsh Ayachit | Note Added: 0028669 | |
2012-07-19 16:25 | Sebastien Jourdain | File Added: MultiBlock-ArrayDifferentOrder.zip | |
2012-07-19 16:27 | Sebastien Jourdain | Note Added: 0028873 | |
2012-07-19 16:27 | Sebastien Jourdain | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
