| 0013210 | ParaView | (No Category) | public | 2012-05-29 16:04 | 2016-08-12 09:59 | ||||
| Reporter | Sven Buijssen | ||||||||
| Assigned To | Chris Harris | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 3.14.1 | ||||||||
| Summary | 0013210: vtkExodusIIWriter segfaults while attempting to save wavelet source | ||||||||
| Description | Refactoring of Exodus writer in mid May 2012 has introduced a regression into git/master: Sources - Wavelet - Apply File - Save Data - File name: foo.ex2 - Files of type: Exodus II file - Ok Ok => segfault in vtkExodusIIWriter.cxx:1645-1646 due to attempted array out of bounds access as 'numElts' is 0: if (numNodes == 0) { numPoints = blockIter->second.EntityNodeOffsets[numElts - 1] + blockIter->second.EntityCounts[numElts - 1]; } | ||||||||
| Project | TBD | ||||||||
| Topic Name | 0013210_parallel_exodus_fix | ||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0028658) Chris Harris (developer) 2012-05-30 09:51 |
A fix for this has been pushed to VTK: http://review.source.kitware.com/#/t/747/ [^] |
(0028661) Utkarsh Ayachit (administrator) 2012-06-01 14:41 |
Merged in master, if applicable. |
(0028875) Alan Scott (manager) 2012-07-19 16:41 |
Chris, It dies remote server. Linux, remote server, Master. I just followed your excellent directions below. |
(0028876) Alan Scott (manager) 2012-07-19 16:42 |
Making it high priority, since if it doesn't work remote server, it doesn't work. Further, this is the main way we write out datasets. |
(0028910) Chris Harris (developer) 2012-07-24 16:19 |
I am unable to recreate this problem. I can connect to a remote server and write out a file without a crash. Is the remote server running master? |
(0028916) Sven Buijssen (reporter) 2012-07-24 17:29 |
Using a debug build of the git master branch on Linux x86_64, the segfault is gone when having connected to a single, separately started pvserver (both 'mpirun -np 1 /path/to/pvserver' and 'pvserver' work). But having connected to a dual server, pvserver crashes while trying to save with: % mpirun -np 2 /scratch/pv-git-build/bin/pvserver Waiting for client... Connection URL: cs://host:11111 Accepting connection(s): host:11111 Client connected. Warning: In /scratch/pv.git/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 780 vtkPExodusIIWriter (0x1c9ed90): Attempting to proceed without metadata Warning: In /scratch/pv.git/VTK/IO/Exodus/vtkExodusIIWriter.cxx, line 780 vtkPExodusIIWriter (0x18990d0): Attempting to proceed without metadata [host:13327] *** Process received signal *** [host:13327] Signal: Segmentation fault (11) [host:13327] Signal code: Address not mapped (1) [host:13327] Failing at address: 0xfffffffffffffffc [host:13326] *** Process received signal *** [host:13326] Signal: Segmentation fault (11) [host:13326] Signal code: Address not mapped (1) [host:13326] Failing at address: 0xfffffffffffffffc [host:13327] [ 0] /lib/libpthread.so.0(+0xf8f0) [0x7f086c6338f0] [host:13327] [ 1] /scratch/pv-git-build/lib/libvtkIOExodus-6.0.so.1(_ZN17vtkExodusIIWriter21WriteBlockInformationEv+0x19e) [0x7f087fed75ba] [host:13327] [ 2] /scratch/pv-git-build/lib/libvtkIOExodus-6.0.so.1(_ZN17vtkExodusIIWriter9WriteDataEv+0xdce) [0x7f087fed0ce0] [host:13327] [ 3] /scratch/pv-git-build/lib/libvtkIOExodus-6.0.so.1(_ZN17vtkExodusIIWriter11RequestDataEP14vtkInformationPP20vtkInformationVectorS3_+0xc5) [0x7f087fecfe7d] [host:13327] [ 4] /scratch/pv-git-build/lib/libvtkIOExodus-6.0.so.1(_ZN17vtkExodusIIWriter14ProcessRequestEP14vtkInformationPP20vtkInformationVectorS3_+0x225) [0x7f087fecfc9d] [host:13327] [ 5] /scratch/pv-git-build/lib/libvtkCommonExecutionModel-6.0.so.1(_ZN12vtkExecutive13CallAlgorithmEP14vtkInformationiPP20vtkInformationVectorS3_+0x8d) [0x7f086860b30b] [...] When using Multi-Core via AutoMPI instead (Edit - Settings - General - Use Multi-Core), the server crashes while saving with a different error message: % /scratch/pv-git-build/bin/paraview -dr Process started AutoMPI: SUCCESS: command is: "/scratch/openmpi/gcc4.4.3/1.4.3/bin/mpiexec" "-np" "2" "/scratch/pv-git-build/bin/pvserver" "--server-port=50577" AutoMPI: starting process server -------------- server output -------------- Waiting for client... AutoMPI: server sucessfully started. ERROR: In /scratch/pv.git/VTK/Parallel/Core/vtkSocketCommunicator.cxx, line 812 vtkSocketCommunicator (0x32db740): Could not receive tag. 188969 |
(0028921) Chris Harris (developer) 2012-07-25 10:32 |
Ok, so this is a problem with the parallel implementation. I can recreate this using the instruction above. |
(0028923) Chris Harris (developer) 2012-07-25 11:56 |
This appear not to be a bug introduced by the refactoring for VTK modular. I ran the same test with 3.14 and see the same behavior. |
(0028925) Chris Harris (developer) 2012-07-25 13:37 |
Also fails with 3.12 |
(0038220) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2012-05-29 16:04 | Sven Buijssen | New Issue | |
| 2012-05-30 09:35 | Chris Harris | Assigned To | => Chris Harris |
| 2012-05-30 09:51 | Chris Harris | Note Added: 0028658 | |
| 2012-05-31 08:35 | Chris Harris | Topic Name | => 0013210_parallel_exodus_fix |
| 2012-05-31 08:35 | Chris Harris | Status | backlog => gatekeeper review |
| 2012-06-01 14:40 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-06-01 14:41 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-06-01 14:41 | Utkarsh Ayachit | Note Added: 0028661 | |
| 2012-07-19 16:41 | Alan Scott | Note Added: 0028875 | |
| 2012-07-19 16:41 | Alan Scott | Status | customer review => todo |
| 2012-07-19 16:42 | Alan Scott | Note Added: 0028876 | |
| 2012-07-19 16:42 | Alan Scott | Priority | normal => high |
| 2012-07-24 16:19 | Chris Harris | Note Added: 0028910 | |
| 2012-07-24 17:29 | Sven Buijssen | Note Added: 0028916 | |
| 2012-07-25 10:32 | Chris Harris | Note Added: 0028921 | |
| 2012-07-25 11:56 | Chris Harris | Note Added: 0028923 | |
| 2012-07-25 13:37 | Chris Harris | Note Added: 0028925 | |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038220 | |
| 2016-08-12 09:59 | Kitware Robot | Status | todo => closed |
| 2016-08-12 09:59 | Kitware Robot | Fixed in Version | 3.98.0 => |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| Issue History |
