| 0013916 | ParaView | (No Category) | public | 2013-02-27 17:12 | 2013-05-18 20:00 | ||||
| Assigned To | Yumin Yuan | ||||||||
| Product Version | 3.98.1 | ||||||||
| Target Version | Fixed in Version | 4.0 | |||||||
| Summary | 0013916: Windows - error selecting spreadsheet row | ||||||||
| Description | There is an obnoxious bug in Windows (doesn't seem to occur in Linux). 3.98.1, Windows, local server. * Open Can.exo. All vars on. Apply. * Integrate Variables filter. Apply. ( You will now see a spreadsheet highlighted, with one row.) Click on this row, trying to highlight the row. This row will disappear, and the title row above will appear highlighted. Needs to be fixed for 4.0. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 13916_spreadsheet_sel_windows | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0030690) Utkarsh Ayachit (administrator) 2013-05-03 13:56 |
Yumin, Before you attempt to fix this, check if the topic on stage, named "14045_fix_selection_speadsheet_view_bug", already addresses this issue. The commit is: commit d0063360322e25cc582909e7a2f40373d0f94c59 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri May 3 13:22:53 2013 -0400 BUG 0014048. Selected rows weren't cleared when selection changed. Selected rows weren't cleared when selection changed, rather the notification that the rows were cleared wasn't sent. Fixed that. Also fixed the random header highliting issue (the header for the spreadsheet view would occassionaly go *bold* as the selection changed. Change-Id: Id49a79f01c54101fbbbbc0e376747a084e3932c9 |
(0030693) Yumin Yuan (developer) 2013-05-03 17:17 |
14045_fix_selection_speadsheet_view_bug did not fix it. This is an issue only on Windows, "painter->setPen(option.palette.color(cg, QPalette::HighlightedText)" is not enough to draw highlighted text in tableview, it also need to set up the brush, "painter->fillRect(option.rect, option.palette.brush(QPalette::Highlight));" |
(0030707) Sebastien Jourdain (manager) 2013-05-07 16:42 |
Merged into master commit a5a8ac523485b8612cfbad98736325178bb773a1 |
(0030713) Alan Scott (manager) 2013-05-07 19:14 |
Tested windows, local server, master. |
| Notes |
| Issue History | |||
| 2013-02-27 17:12 | Alan Scott | New Issue | |
| 2013-05-03 13:54 | Utkarsh Ayachit | Assigned To | => Yumin Yuan |
| 2013-05-03 13:56 | Utkarsh Ayachit | Note Added: 0030690 | |
| 2013-05-03 14:08 | Yumin Yuan | Status | backlog => todo |
| 2013-05-03 14:08 | Yumin Yuan | Status | todo => active development |
| 2013-05-03 17:13 | Yumin Yuan | Topic Name | => 13916_spreadsheet_sel_windows |
| 2013-05-03 17:13 | Yumin Yuan | Status | active development => gatekeeper review |
| 2013-05-03 17:13 | Yumin Yuan | Fixed in Version | => git-next |
| 2013-05-03 17:13 | Yumin Yuan | Resolution | open => fixed |
| 2013-05-03 17:17 | Yumin Yuan | Note Added: 0030693 | |
| 2013-05-07 16:42 | Sebastien Jourdain | Status | gatekeeper review => customer review |
| 2013-05-07 16:42 | Sebastien Jourdain | Note Added: 0030707 | |
| 2013-05-07 19:14 | Alan Scott | Note Added: 0030713 | |
| 2013-05-07 19:14 | Alan Scott | Status | customer review => closed |
| 2013-05-18 19:58 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
| Issue History |
