| 0014054 | ParaView | (No Category) | public | 2013-05-07 16:03 | 2013-05-21 16:26 | ||||
| Assigned To | Yumin Yuan | ||||||||
| Product Version | git-master | ||||||||
| Target Version | Fixed in Version | 4.0 | |||||||
| Summary | 0014054: crinkle slice the glyph is wrong | ||||||||
| Description | If you slice with a crinkle slice, then glyph, the whole dataset will be glyphed. Master, Linux, local server. Open can.exo. Apply. Slice filter. Crinkle slice on, Show plane off. Apply. <Important> - go forward one time step. (otherwise, scales are bad and paraview may hang). Glyph filter. Apply. Notice that the whole can is glyph-ed - not just the slice. This is a bug. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 14054_slice_crinkle_bug | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0030776) Yumin Yuan (developer) 2013-05-15 15:36 |
I have a fix on VTK-Gerrit (http://review.source.kitware.com/#/t/2765/ [^]), but it won't be merged into master until VTK6.0 is branched, because we are in code-freeze. |
(0030802) Yumin Yuan (developer) 2013-05-20 14:00 |
Fixed wrongful logic for ExtractOnlyBoundaryCells in vtkExtractGeometry. The ExtractOnlyBoundaryCells is not working properly due to some logic errors in deciding when to extract cells if both ExtractBoundaryCells and ExtractOnlyBoundaryCells are on. Fixed it. Change-Id: I0574c672507ca610b1e77272d12f4e8acc3efa0c |
(0030806) Utkarsh Ayachit (administrator) 2013-05-21 11:06 |
SUMMARY --------------------------------------------- Topics merged into master: 14054_slice_crinkle_bug 14072_splash_default_off 14075_coprocessing_script_generator fix-install-www-rules fix_multiblock_inspector_issues fix_python_paths update_vtk |
(0030809) Alan Scott (manager) 2013-05-21 16:26 |
Excellent. Tested master, remote server, Linux. |
| Notes |
| Issue History | |||
| 2013-05-07 16:03 | Alan Scott | New Issue | |
| 2013-05-13 10:51 | Utkarsh Ayachit | Assigned To | => Yumin Yuan |
| 2013-05-13 15:23 | Yumin Yuan | Status | backlog => todo |
| 2013-05-13 15:23 | Yumin Yuan | Status | todo => active development |
| 2013-05-15 15:36 | Yumin Yuan | Note Added: 0030776 | |
| 2013-05-20 14:00 | Yumin Yuan | Topic Name | => 14054_slice_crinkle_bug |
| 2013-05-20 14:00 | Yumin Yuan | Note Added: 0030802 | |
| 2013-05-20 14:00 | Yumin Yuan | Status | active development => gatekeeper review |
| 2013-05-20 14:00 | Yumin Yuan | Fixed in Version | => git-next |
| 2013-05-20 14:00 | Yumin Yuan | Resolution | open => fixed |
| 2013-05-21 11:03 | Utkarsh Ayachit | Fixed in Version | git-next => 4.0 |
| 2013-05-21 11:06 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2013-05-21 11:06 | Utkarsh Ayachit | Note Added: 0030806 | |
| 2013-05-21 16:26 | Alan Scott | Note Added: 0030809 | |
| 2013-05-21 16:26 | Alan Scott | Status | customer review => closed |
| Issue History |
