0014234 | ParaView | (No Category) | public | 2013-08-15 10:31 | 2013-12-24 19:32 | ||||
Target Version | Fixed in Version | 4.1 | |||||||
Summary | 0014234: Python trace not capture creating of views from plugins correctly. | ||||||||
Description | Python trace not capture creating of views from plugins correctly. To reproduce, try this: + Start ParaView + Load the QuadView plugin + Close active 3D view + Start Trace + Create "Quad View" + Stop Trace The trace shows that the view must be created using the following: QuadView = CreateRenderView() Which is incorrect. It must be CreateView("QuadView"). | ||||||||
Project | Sandia | ||||||||
Topic Name | 14234_fix_trace_views | ||||||||
(0031464) Utkarsh Ayachit (administrator) 2013-08-15 10:34 |
commit dd5e0246dfa428d504b7d1b78891a66c57456dc0 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Aug 15 10:32:23 2013 -0400 BUG 0014232: Fix tracing of non-standard view creation. When tracing creation of views from plugins, for example, the trace ended up suggesting to use "CreateRenderView" incorrectly. Fixed the logic to view the view's name and call CreateView(viewname) instead. Change-Id: If46ea19863ffc9cfa8222b11d5d7b73bd190e7ee |
(0031478) Utkarsh Ayachit (administrator) 2013-08-16 13:48 |
Topics merged into master: 0014218_fix_color_preset_issues 13029_fix_auto_apply 14158_fix_double_range_slider 14185_fix_component_name 14204_fix_domains 14233_fix_disconnect_button 14234_fix_trace_views better_disconnect_error_v2 serverside_only_reader (VTK) update_to_master |
(0032059) Alan Scott (manager) 2013-12-24 19:32 |
Tested local server, master, linux. |
2013-08-15 10:31 | Utkarsh Ayachit | New Issue | |
2013-08-15 10:34 | Utkarsh Ayachit | Topic Name | => 14234_fix_trace_views |
2013-08-15 10:34 | Utkarsh Ayachit | Note Added: 0031464 | |
2013-08-15 10:34 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-08-15 10:34 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-08-15 10:34 | Utkarsh Ayachit | Resolution | open => fixed |
2013-08-15 10:34 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-08-16 13:48 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-08-16 13:48 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-16 13:48 | Utkarsh Ayachit | Note Added: 0031478 | |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
2013-12-24 19:32 | Alan Scott | Note Added: 0032059 | |
2013-12-24 19:32 | Alan Scott | Status | customer review => closed |
