| 0014236 | ParaView | (No Category) | public | 2013-08-16 13:18 | 2016-08-12 09:59 | ||||
| Assigned To | Kitware Robot | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 4.0 | ||||||||
| Summary | 0014236: vtkImplicitFunctionToImageStencil doesn't work in ParaView | ||||||||
| Description | + Rebuild ParaView with Module_vtkImagingStencil Cmake variable ON + Load attached XML as a plugin. + Try creating the "Implicit-Function To Image-Stencil" source. + You'll get errors: Generic Warning: In /home/utkarsh/Kitware/ParaView3/ParaView/VTK/Common/DataModel/vtkDataObjectTypes.cxx, line 303 NewDataObject(): You are trying to instantiate DataObjectType "vtkImageStencilData" which does not exist. ERROR: In /home/utkarsh/Kitware/ParaView3/ParaView/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx, line 658 vtkPVCompositeDataPipeline (0x20b9d80): Algorithm vtkImplicitFunctionToImageStencil(0x26c9770) did not create output for port 0 when asked by REQUEST_DATA_OBJECT and does not specify a concrete DATA_TYPE_NAME. Generic Warning: In /home/utkarsh/Kitware/ParaView3/ParaView/VTK/Common/DataModel/vtkDataObjectTypes.cxx, line 303 NewDataObject(): You are trying to instantiate DataObjectType "vtkImageStencilData" which does not exist. | ||||||||
| Project | Kitware | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0038437) Kitware Robot (administrator) 2016-08-12 09:59 |
| Notes |
| Issue History | |||
| 2013-08-16 13:18 | Utkarsh Ayachit | New Issue | |
| 2013-08-16 13:18 | Utkarsh Ayachit | File Added: ImageFilters.xml | |
| 2016-08-12 09:59 | Kitware Robot | Note Added: 0038437 | |
| 2016-08-12 09:59 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:59 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 09:59 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
